Anyone's ThruNite Ti2's not work on AAA Eneloops?........
Just cut the top coil off. ANNNNNNNDDDDDDDDD!!!..………………………….
Still doesn’t work.
Bought the 10-pak for $29.99. Shipping was $5.95.
I cut bottom coil.
I interpret the issue differently.
to me it sounds like the positive on the battery is not reaching the positive on the driver.
because the battery is on a spring, the body tube can still move forward to contact the pill… unless arow55 is correctly solving an issue with the spring being at maximum compression, preventing body tube contact to negative ring on pill. If I understand arow55 correctly, his Ti2’s did not work until he cut the spring… I dont understand, but, if it works… well… maybe worth a try before returning the 10 pack.
I think (pure guessing without evidence yet), that the issue is because the eneloop positive post is wider and is hitting one of the parts on the driver. We confirmed by photo that the component is mounted slightly closer on the Ti2, than on my Olight i3e.
btw, the reason the components are on the battery side, is because the other side has the LED mounted directly to the board, no wires. imo the intent was to make the flattest driver possible. They did succeed at that.
whether the eneloop issue is spring length or positive post width, remains unclear to me
I would speculate that chipping the insulation off the component that is too close to the brass post on the driver, could enable a Ti2 to become eneloop friendly, without cutting the spring… I dont know if chips of insulation getting broken off by the battery, is the actual reason that arow55’s lights started working… Im glad he got them to work though, either way… Im not trying to doubt the report, that spring cutting was associated with a non eneloop friendly Ti2, becoming less prejudiced against phat posts.
Try jumping the negative contact of eneloop. That should tell you something.
“Try jumping the negative contact of eneloop. That should tell you something.”……
Already did that right from the get-go when I was too lazy to pull the pill. :laughing:
When I got mine all they had were black and green. The tan look nice.
Wow. All I can say is cutting a coil off the big end worked on mine. Mentioned it on a thread about ti3 deal.
“…….whether the eneloop issue is spring length or positive post width, remains unclear to me
I would speculate that chipping the insulation off the component that is too close to the brass post on the driver, could enable a Ti2 to become eneloop friendly, without cutting the spring… I dont know if chips of insulation getting broken off by the battery, is the actual reason that arow55’s lights started working… Im glad he got them to work though, either way… Im not trying to doubt the report, that spring cutting was associated with a non eneloop friendly Ti2, becoming less prejudiced against phat posts.”
Ya know, I didn’t intentionally initially chip the components corners either. That happened when I put a little extra torque rotating the head. I heard a slight ’krik!” and I thought, well Notta now it’s
really fooked up. :laughing: Anyway even beyond that obscene abuse it still werks. Tough little flash!
Anywho, since I got 9 more still in their boxes I suppose I could very carefully grind off more of the component’s base and see if that’ll werk. Or I can cut off ANOTHER coil. :open_mouth:
Watt the heck ACT II. Off with another coil it is! :laughing: :beer:
Stay tuned. I’ll be back. :open_mouth:
arow55 can you post a photo of the pill in one of your Ti2… Im looking to see the position of the components, and whether one of them has a corner chipped off
duh!… LOL
thanks for taking (another) one for the team
makes no difference what end of a spring you cut… move along
we already confirmed that battery lengths are the same, and that the positive post on the Eneloop is phatter than on the Primary battery
IF my hypothesis is correct
the correct fix is to create a way for the positive post on the battery, to reach the brass post on the pill
either chip away at the interfering component, or put a small magnet or solder blob on the battery positive post… or if you want to live dangerously, drop a little ball of tin foil onto the brass post on the pill, and hope it does not short to any other component… :wink:
and then return those Stupid Lights… LOL
Try putting a small solder blob on the positive of the battery —- it might not be protruding far enough to make contact
Yeah it’s sexy.
All I can tell ya is that it’s a cute little sucker and wood be great muggle gifts. I mean it’s as simple as it gets plus it’s built well rugged.
I can only imagine that right now they’ve prolly sold thousands of these and if most were of this run they got a BIG warranty problem on their hands. Somebody in QA/Engineering…….
“Sung Yu! I need see in office RIGHT NOW!!! Bring vaseline!!!” :laughing: :open_mouth: :person_facepalming:
Already did that too right from the get-go. Still no werkyquerky.
Notta didn’t just fall off the carrot truck. :laughing: :beer:
Got picture but don’t know how to post. Never posted picture on this forum.
Anyone else finding this stubidly and morbidly entertaining?……
Me real-time goin’ back and forth surgerying on this poor Ti2, the gallery looking down from up in the balcony, until maybe watt’s only goin’ be left is the tail end with the lanyard loop. :laughing: :open_mouth:
YOU’RE NOT GONNA BELIEVE IT!!!
Cut another coil off the spring so all that was left was about 5mm.
IT WORKED!!! :laughing:
Arow55………………….’’YOU CRAZY BASSTURD!!! I READ YOUR BOOK!!!.” Gen. George S. Notta, Retired.
PS. Jon, I don’t know watt to say. This shouldn’t have werked. :student: :laughing: :person_facepalming: :+1: :beer:
PSS. I cut off enuff of the spring coil that if ya just freely drop in the Eneloop the top insulation face is about 1mm higher than the tube. That’s a lot of difference. :open_mouth:
Gad to hear that — something has you stumped though
Got er’ fixed per above thanx to Arow55!!! (He may be a mad genius or sumthin’.) :nerd_face: :student: :open_mouth:
Glad to hear it. That proves that I too am notawhackjob.
My man, this just goes to show that BLF is the BEST!!! You’re now in Notta’s Hall of Fame. :laughing: :+1: :beer:
PS. Anyone messes with Arow55 messes with me. He’s a BLF Made Man. :laughing: :cowboy_hat_face: :open_mouth:
PSS. Now I got 9 more to do. Anyone need 9 each slightly abused 5mm tall spring coil pieces? :smiley:
