From what I’ve read, the W1 Osram emitter has the longest throw, and that’s what I picked for my KR1. The W2 is a bit brighter and has a wider, more useable hot spot but runs much hotter and doesn’t throw quite as far.
To your earlier question about the batteries: I only mostly use my 21700 light’s and buy way more of those batteries so I’m not too well-versed on the 18650 options. But, for my 4 emitter Fireflies PL47G2 (also 21700 yet super tiny) I use a 10A battery. I tried the Samsung 40T which is 25-ish Amps and that one tuned the LED’s purple which is very bad for the emitters. But that same battery on my 7-emitter Fireflies E07 works perfectly fine. So I’d say for a 4-emitter 219B light, stick to 10A. for the 7-8 Emitter 219B lights, the 20-25Amp batteries are usually what will give you full power. One of the things I’m not sure about is how Hank sets his up his lights so it’s entirely possible that 10A will work across the board based on what I think I’m hearing others say, but maybe not so much once the battery starts to discharge.
Now as for your KR1, I don’t have one and I haven’t seen one of these smaller throwers in person with an Osram, but I do know it gets much wider than the same emitter in a much throwier host like the K1. So maybe the Osram would be perfect for what you want. I was gonna suggest the SBT90.2 in that host. I don’t know if Hank does it but I’ve seen a few people have it so maybe he does. It gets hot and steps down fast, but for short bursts, you will love it for spotting animals at night and things like that. Maybe there are more efficient LED’s that throw almost as good and will do what you want, not too sure honestly. But I do know that the SBT90 is monster and would be pretty fun for what you want it for. I love going outside and blasting my SBT90.2 lights.
Maybe a D18 would work even better for outside late-night spotting, it’s a wall of light and should still work great at 100 yards or so. And it might come in handy in may other situations too, but thats a significantly larger light with 3 batteries.
Well let me not further complicate things for you, best of luck. I hope you find something that adds some fun to your walks.
@Lojik, how do you carry your 21700’s? EDCing a 21700 in general seems pretty cumbersome, especially something in copper. Do you use cargo pockets? A pouch? Holster? Fanny pack? I’m curious. I don’t know anything about this SBT90.2! I’m gonna have to look it up. The D18 looks incredible, and is absolutely something I’m going to have to get eventually. And I think your spot on, that it would serve me well for lots of purposes. I don’t mind a big light. If it’s not something I expect to EDC, then as long as it fits in a backpack or cargo pockets I’m into it. I was using 2D and 3C maglites not too many trips around the sun ago. Speaking of, I think it’s weird that there’s so few larger elongated light options these days, like 2x 21700 end on end. Stuff like that. But with all that said, I’m probably not going to get a D18 yet. The KR1 comes in at about half the price, and I’ve already spent so much on the D4V2 and the DT8.
So lemme see if I’m in the ballpark with the emitter options for the KR1:
W1- throwiest option, only cool white, tighter hotspot than W2
W2- brighter, with likely a more functionally spread out hotspot than the W1, but faster battery drain
SST-20- pretty throwy, good balance of cri and power, good tint at higher power, bad (green) at lower power
SST-40- ?
XP-L Hi-?
Not sure how the last two compare to the rest. I have read that the XP-L Hi have better tints than the SST-20 and they have a good color range, but aren’t as throwy and aren’t hi-cri except the warmest one. And I think the SST-40 is what’s in my Warrior Mini, but in a gross 6500k. If I were to use the KR1 most often for shorter durations, and almost always at turbo or high, for the purposes listed in my previous post, am I correct in thinking that an SST-20 would serve me well? Or should I consider the XP-L Hi? Or just go with the Osram for MAXIMUM THROOOOW?
Thanks!
Mark M, jon_slider’s explanations and pictures have been clutch in helping me pick what emitters I want in my first Hank lights! I just wanted to second what you said. I know nothing, but I do know that that s* has been extremely helpful to this noob.
DrDevil, I was initially going to get the sandblasted Ti D4V2, but I emailed him first and he said that he was out, but that a reseller jlhawaii808 had them in stock. I don’t know if he’s out of the antique brass or not, but I probably would have emailed him first. Btw, it looks like jlhawaii808 does have antique brass D4V2 in stock.
Most will say that a 21700 Light is too large to EDC. I’d say it depends on what you’re used to carrying. I don’t like the idea of getting used to carrying the absolute tiniest lights. You’re naturally gonna think everything is too big. I prefer a light that will work for a while usefully. My Nichia lights don’t need ultra high discharge batteries so I can take advantage of the larger capacity batteries. Also, I have been in situations where if I’d have had a smaller true EDC light, it just wouldn’t have cut mustard. So I really am used to the size. When I got the Copper E07( I used to EDC the clear anodized E07). It took like a day to get used to, but when I went back and picked up my other lights, they felt way too light. Now I really love the weight of my Copper E07. And actually, I think of it as an enhanced roll of pennies for protection. You never know when someone might need a little fist kiss. A punch holding that light would pack a wallop. Just normal for a flashlight to weight this to me now. Also, I just pocket it, I usually have a few packet so that’s where it goes.
And FYI, the Pl47g2 21700 light is somehow still shorter than the D4v2.and other 18650 light, actually even some 18350 headlamps. It’s a great light. Used to EDC it but missed that higher output and went back to more full sized lights.
Good deal, DrDevil! I’m curious how quickly that tarnish will rub off in a pocket or hand, because I think that will look great! Like, for example, if the really raised portions of the knurling are brassy and the lower space between them is black.
Can someone help me make the choice between going Osram W1 or W2 vs SST-20 in 4000k for the KR1? I would be mostly using it in high, so the poor tint of the SST-20’s at lower levels wouldn’t be as much of a deterrent. But if my other flashlights are already both nice, hi-cri lights, should I just with the Osram for maximum throw and to juxtapose the KR1 with my new 219b lights? Or go with the SST-20 and have nothing but hi-cri goodness?
I went ahead and went with the SST-20 4000k for the KR1. Decided to stay on theme of high-cri goodness. I couldn’t find almost anything on the web as far as photos of beam shots from this set up go. I hope I’m happy with it! Im sure I will be.
Oooooh I may have gotten really lucky! According to this post on r/Hanklights, the current bin of SST-20 4000k that Hank has is FD2, which should have a much better tint than the recent bad batch. Fingers crossed! Could I really have gotten lucky enough to start collecting Hanklights right when he gets a big batch of 219b in, and when he gets a good batch of SST-20 4000k??
Btw, thanks for those beam shots, d_t_a!
Edit: Hank did confirm that it’s FD2 bins that are in stock currently, if that helps anyone else make a tough emitter decision
