[1900k edition is in!] WTS: 1900k-5800k 5mm LED 95+ CRI
I love that we have so many options to choose from but I’m out of the loop. Can someone point me to a good host for these please?
The current obvious host is the Sofirn C01. But be careful which colour to choose, we found out that black, red and green have a potted driver (can not be modded), and blue, brown and orange are not potted (easiest modding host ever).
https://sofirnlight.com/c01-aaa-flashlight-5mm-3400k-led-95-cri-p0152.html
Or
Cool, thanks. I mistakenly recalled they were all potted, so I’d dismissed them as an option. Glad to to hear some colors will make an easy host for these 5mm LEDs.
A good option for the -EX model is the Nitecore Tube.
1900k Emitter under 365nm UV light
Compared to the rest of the C01 trio I modded (lowest CCT emitter on the right)
Nice! I bought some!
FWIW,
some time ago I’ve shown a 1:3 mix of the 5800K and 2300K resp. LEDs. Now that I got that Opple Lightmaster, I measured:
Payment sent for a pack of 50 1900K leds tracked to Taiwan
That is nicely under the BBL, Unheard, does the Opple give the duv value too?
No, I need to convert x,y by hand:
gives –0.0051
Interesting, but not very natural, I would not want it for an EDC light.
Here's the CRI test results from Djozz for 19K-C (1900k).
Cool! My package has hit US customs the last time I checked.
Awesome!!! A true candlelight warm hi CRI!
I’ve been using the 2400K for such, but will HAVE to get some of these now.
Will there be any output/current/voltage data on these?
Thanks again for finding and offering these gems to the community.
You can look at the table in the OP (unless you want a graph data, which I don't have right now). I have updated table with the new emitter since it's introduction.
I would be interested. Should I expect that the lumen output would be even higher than the 3200K-EX?
If you're interested, you can put your name in here (with size & quantity):
https://budgetlightforum.com/t/-/66585
I'm keeping the record so I can pull the trigger once it hits the threshold. For now, the interest is only ~15% of the set threshold, so I need a lot more interest in the project so I don't end up losing a lot of money.
Done
I realize this is about upgrading the stock LED in the C01 to the EX LED, but can someone give more details? Thanks…
I'm going to repost Djozz's modding here. It's about the 22 Ohm resistor on the board.
In his case, he did the opposite by instead of bridging the resistor, he opted to replace the resistor with larger value of 220 Ohm to reduce the input into sub-lumen and extend the battery life.
https://budgetlightforum.com/t/-/51879/3184
In his picture, you can see the "221" resistor (220 Ohm) on the left. In the stock boards, you will see "220" (22 Ohm) instead. That's the resistor you need to bypass to increase the drive current.
Also, I have an old Black Diamond headlamp that use to have an incandescent bulb that I am thinking of modding with 14 of the 32K-C-EXs wired in parallel. It is setup for three AAs, but I can easily modify it to only use two AAs instead (and would use NiMH batteries). Anyone see an issue direct driving all those LEDs with that setup? I have actually already had 14 LEDs in it a long time ago and just always used three partially depleted alkaline cells to keep from over-driving the LEDs too much. From old emails I see the ordered the LEDs in 2003 from some guy named Brian Lam; they were suppose to be 8000mcd white LEDs.
Looking closer at the chart in the original post of this thread, it appears I could actually use the 34K-A ones and get 22lm of output (per LED) driving them with 120mA which is only a bit lower than the 27lm for the EX model. Is that correct or am I missing something?
