boruit broke bc10
21 posts / 0 new
ROMzombie
Last seen: 2 months 4 days ago
boruit broke bc10
Hello, I bought this flashlight about 3 years ago from Fastech.com and it stopped working. It only turns on if the usb charger is attached. I have checked the battery and it's charged and will run another light. I asked Fastech if they will ask the manufacturer if they would sell me the LED driver. They said it will cost me $15. Is that a reasonable price?  Should I look into an aftermarket driver instead?
video of problem: https://youtu.be/M5kJ6xj9irc
Quadrupel
Quadrupel's picture
Last seen: 6 hours 33 min ago
Dismantle. How all looks inside?
ROMzombie
I haven’t got that far. It looks like it disassembles through the bezel. It appears a special tool may be required. Something can be rigged, I think….. There is nothing to grab onto with a strap wrench.
Funtastic
Funtastic's picture
Last seen: 2 hours 38 min ago
Get a rubber mat or even the rubber strap of your wrench, push the light into the mat as hard as you can and twist. I’ve sometimes used double sided tape on the mat to give it more grip. Works most of the time
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
Kos70
Last seen: 5 hours 57 min ago
Rubber slippers work well ...
ROMzombie
I was thinking something similar – a rubber cork that the bezel can be pushed into and twisted.
ROMzombie
I’m not having much luck taking the bezel off. If or when I do, do you think I should purchase the original driver or an aftermarket?
**edit – I think it will have to be the original as I think the switch is attached to the driver board rather than wired in.
NeutralFan
NeutralFan's picture
Last seen: 20 min 41 sec ago
$15 for a replacement driver seems like a reasonable price to get this flashlight working again.
But I would take it apart ahead of time to see if there are any obvious issues. Like a loose retainer ring.
If you decide to get a replacement driver, you will need to take it apart anyways, so why not take it apart now to see if there are any issues?
I’d rather use my flashlight around the house than turn on the lights.
Funtastic
Funtastic's picture
Yes, have you cleaned all the contact points and checked any retaining rings, if any, are tight?
ROMzombie
The first thing I did was clean the contacts. The pcb looks like it doesn’t move or isn’t loose. I have found that it came on for a bit and I cycled through the modes then shut it off and it won’t come back on again. Something must be loose inside then.
I still have not been able to remove the bezel. I have tried heating it up with a hair dryer but that didn’t work either.
edit – I got it off!
I imagine the switch needs to be pulled up and out:
image: https://ibb.co/YdGwQ2S
edit – does anyone know how to lift up the switch?
edit – the switch has a bezel as well and it unscrews. its all apart now. I don’t think there is any way i could tell what is wrong with this:
!https://ibb.co/gShSrZs!:
:https://ibb.co/v4nxhxn
ROMzombie
I think I found the problem. See the cracks in the solder? Are there any components that are very heat sensitive if I use a hair dryer to re-flow the solder?
NeutralFan
Looks like you found the issue!
Why not just reheat the cracked solder joints with a soldering iron? I would also add some more solder to make it stronger.
ROMzombie
The iron I have – the tip won’t fit too well at the far side of the solder joint. I’m worried about burning whatever that large box component is.
I think what caused it was dropping that heavy battery into the tube holding it vertically. It would be better if they used a spring on both ends.
edit – it worked for a few minutes but now it’s back to working only while plugged in. I’ll have to try again.
SIGShooter
SIGShooter's picture
Last seen: 4 hours 38 min ago
A hair dryer won’t get hot enough to melt the solder.
ROMzombie
I have a heat gun. I have used a hair dryer before, when I couldn’t find my heat gun, on something else. 1500 watts is pretty hot if you hold it very close. But that could burn out the dryer maybe due to air flow restriction.
LumenHound
LumenHound's picture
Last seen: 6 days 13 hours ago
That’s a very tight space to use a heat gun. The risk of unsoldering nearby components is high.
Make a temporary soldering iron tip extension by tightly wrapping the entire shaft of the tip with a piece of solid copper wire and extending it past the tip the distance you need then give it a snip.
Friction will keep the bare copper from sliding and you should get more than enough heat transfer to the end of the copper wire to reheat the solder on both sides of the broken connection to the point where it will bridge the gap.
ROMzombie
Thanks, I’ll have to try that sometime. I didn’t catch your post in time. Here is my result. I need a lot of practice but at least the torch is working now.
Yeah, I made a mess in there. My hand shakes a little bit so solder got all over the place and I don’t have a wick or suction.
ROMzombie
Well, in the end I could not get it working properly. I purchased a new driver. I told them that I think there should be a spring on the positive end as that may have contributed to the cracks in the solder (from dropping the heavy battery in there). They actually listened to me or they already made the change.
Correllux
Correllux's picture
Last seen: 16 min 51 sec ago
Interesting driver there, definitely would have had trouble finding something to work without the OEM.  I've had a very similar behavior from a Lumintop light and am working with them to get the correct driver now.  They sent me one but it was completely the wrong thing.  If you have a toaster oven that will get up to 450°F-500°F it would be worth a shot to put it in there carefully for a reflow.  It probably wouldn't be hot enough for lead-free solder but maybe.  I'm not a fan of the brass buttons either but it does make sense for high current applications.
Glad you got the part to fix it up!  Seems like a nice enough light that it's worth the cost.
ROMzombie
Would the insulation on the attached wires able to handle 500°F?
The hair drier I used once for a video card made the cold or cracked solder joints shiny but that was probably just on the surface removing a visible crack over a still present crack underneath . It worked for a bit but did not last
Correllux
Correllux's picture
Probably would be wise to remove them first.  All the wire I have says 200°C and 205°C...so around 400F.  I think I'd worry more about toasting some chips and would look up reflow specs for at least a couple.  Just a thought for a last ditch rescue effort.  Or maybe jab each one with a soldering iron, which would be a much safer reflow.  I'm going to try to diagnose my dead Lumintop driver but I may end up trying this just to see what happens.  It's really curious how the battery power wouldn't make the light run but it could still function via the charging power/port.  Mine did the same, but it's an XHP35 12v boost driver.
