I got 3 thermometers (clock/thermometer, clock/thermometer/hygrometer, thermometer/hygrometer), and despite being within inches of each other, always have a consistent 5°F spread.
So I have no idea other than relatively what the true temperature is.
Bought a “precision” glass candy thermometer (long-ass ones at least 1’ long), tried a stable water/ice mixture and boiling water, and even that seemed “off” by 1 grad each.
Same applies with voltmeters, lumenometers, etc. Unless they’re NIST traceable, they’re just educated guesses.
the DUV of sunlight is nominally 0.0032, almost identical to the SST-20 4000k charted above.
This is why that LED may not demonstrate a noticeable green tint, when daylight adapted
the DUV of incandescent is 0.0000, so from that reference, the Tint of sunlight is above the BBL, into the green zone
the LH351d and E21a also tend to have Tint above the BBL, in particular the cooler ones.
It makes sense to me that people that use lights during the day, will prefer Tints that are cooler and greener, more like daylight,
while people who use lights in darker ambient adaptation will appreciate warmer color temperatures and less green tints
sometimes it is useful to emulate sunlight, 5000k+
other times emulating incandescent can be useful 2700-3200k
I think it is helpful to match the color and tint of our flashlights to our ambient white balance
on the warm end, I like my artificial light to be about 500k cooler than ambient, so the beam stands out more easily. So when Im in 3000k ambient, I like a 3500k LED…
it occurred to me that the idea behind the TCR (what people find subjectively pleasing) is contained in the Kruithof Curve
that is, a group of people were asked what color temperatures they like at different Lux, and the results are plotted:
basically, at lower intensity, people like warmer light
“For example, natural daylight has a color temperature of 6500 K and an illuminance of about 104 to 105 lux. This color temperature–illuminance pair results in natural color rendition, but if viewed at a low illuminance, would appear bluish.
At typical indoor office illuminance levels of about 400 lux, pleasing color temperatures are lower (between 3000 and 6000 K),
and at typical home illuminance levels of about 75 lux, pleasing color temperatures are even lower (between 2400 and 2700 K). ”
What makes the rosy tint so popular? I guess we all agree that a flashlight with a duv greater than the duv of the ambient light doesn’t look as nice as one with a duv lower than that. But why?
Maybe that’s the reason, dunno. I asked because I wondered if there’s a paper about it. My first thought was that we’re used to incan lights, and so associate the lower duv with the comfort a child experienced at home. Something like this.
But yes, the higher reflection of red color makes skin look more healthy.
We don’t use flashlights the same way we use sunlight. We don’t use flashlights the same way we use lights in a house. Example: you are standing at one end of a 30 foot long white (walls,floor, ceiling) hallway in a building and you’ve got a light over your head and you’ve got a light that’s down at the end of the hallway 5 feet from the wall and you’ve got one in the middle all mounted on the ceiling. You want to see a painting on the wall down at the end of that hallway. It is a large painting of a deteriorating barn in a field with some blue sky. It is autumn and the field has not been cut. You have the option to turn on any single, double or triple combination of lights that you want. These are all bare bulbs shining in all directions. And you have three different bulbs that you can put in any position you want. One 2700k, one 4500k, and one 6500k. What bulbs do you put where and what do you turn on?
It seems to be due to both perception of what light looks “white” at different illumination levels and color temps, and that greenish/positive duv light often looks especially bad. I can’t really explain why it does to me either, but I’ve hated the light from greenish, low CRI florescent tubes all my life. Interestingly some florescent lights are very rosy instead, even when 70 CRI or lower. Keep an eye out for differences in temp/tint of florescent tubes right in the same or adjacent fixtures next time you’re around them.
I have one fluorescent tube left (nostalgia). My Opple measured a little over 2700K and a positive duv. It does not bother me at all, but yes, usually I prefer rosy over greenish tints. But I cannot really tell the difference between positive and negative duv. Yesterday I made experiments (not blind ones, obviously, I know my lights). With fully adapted eyes, I cannot identify the tint of light reflected from a white surface. Of course, there are limits. A sw45k D200 is outside of those limits. It is so much off that even my camera cannot find a correct WB. I’ve linked two reviews with some pictures in this thread, some of them show a rosy background. That was actually a white sheet of paper, and the light source was a sw45k, dedomed behind honeycomb TIR optics. I left it as it is since it was basically ok, but it was interesting to note that AWB didn’t work.
Ok, my idea about green/rosy is, when comparing two lights with different characteristics, one looks greenish, one looks rosy. This is really always the case in the NW range of CCTs. To me it shows the perceived tint is not necessarily tied to duv.
It is all a mystery.
Thanks for the paper and the presentation. The data is interesting by itself, even if it gives no hint about the psychology behind all this. I need to learn much more about it.
Edit: Maybe Whacky is not so wrong with his TCR. In some sense, at least. Interesting topic anyway.
Thanks for posting this.
As a layman in this area, I have made observations of CRI ratings in lights I’ve purchased and seen inconsistencies. This video helps explain that. Isn’t it bizarre that it has taken so many years to reach this premise that should’ve been obvious back when CRI was first established? Or was it a matter of the right people coming along who could offer up a new way of looking at light rendering?
Is it safe to say that while CRI has its merits, it’s a narrow mathematical practice that misses other variables?
I can appreciate a very keen interest in TCR for lighting sources in photographic applications. Though I’d expect professionals would be sourcing very specialized lights for that purpose and using filters to compensate. If TM-30 helps this out, that’s great. The “High CRI” lights we’ve been buying are targeted to consumers who have above average light knowledge & needs, plus the hobbyist. And yeah, they’re not all created equal or necessarily representative of claimed temperatures. And thankfully minus-green filters are available to make corrections when very much needed.
I haven’t seen the whole video, but I wonder if a TCR indication is established as part of an average. Not just in colors across the spectrum, but also with respect to the quality of ambient light, such as a sunny day versus a cloudy day… or morning versus noon.
Any opinions or facts on the mixing of LED color temps to increase TCR or actual CRI?
I built a work light w/ 2 x 50W COB LEDs, 1 CW, 1 WW. Works amazing for painting walls, you can easily see where you’ve missed a spot even painting white on white (eg repainting ceiling).
That’s a 4 emitter light that I modified. WB on 4300, seems slightly more green and purple than to my eye.
Obviously, they blend together at even 3 feet.
I don’t know what duv is, but I am curious as to why I should or should not mix 4 high cri emitters with different color temps when I upgrade this ?8 year old mod.
They’re xlm2. What would give me the greatest TCR?
I feel like true color rendition value should have candela factored in, and that’s probably my point more than specific emitters… If what I need to see well doesn’t have enough light on it…
Probably limited to dedomes or HI for this, if it still had reflectors, probably different. Maybe lh351d? I have read a little on the latest super high cri, but for this light they sound low power with lenses or reflectors.
duv is a measure for how far a color is away from BBL. If you mix very low and very high CCTs, the beam can become unpleasently rosy (i.e., too extreme).
Have a look at:
(Mixing colors specified with the CIE xy chromaticity diagram)
Resulting duv can be calculated based upon x,y that you calculated with the formula stated in the above link:
You get x,y from the manufacturers datasheet or by measuring.
It increases color saturation a bit, which is an example of the things that CRI don’t show but TM-30 does, you can have two lights with an R9 of 50, with one the reds are undersaturated and with the over oversaturated (which in general isn’t as much of a problem).
