There is currently no relevant specific information
26650 Battery 5500mAh 3.7V High Capacity-High Drain Flat Top Li-ion Orbtronic
26650 Battery 5500mAh REAL capacity 3.7V Li-ion High Drain Hybrid IMR| Orbtronic
Average Rating: 4
Price: USD 10.95
Does the GT-FC40 in M21C have good throw and beam rendition?
Also, can all Convoy L6’s be run on 2 x 26350s in shorty mode?
Oh yes...
Yes, I have one :)
Yes, there are a couple of real world photos in my review - see link in my signature. The light is half way between being floody and throwy.
Simon, did I see you are working on a larger cutout reflector for the M21B?
I just received my S11 GT FC-40, and love it. I would like it even more in a single 21700 host like the M21B though!
Hi Simon,
Few hours ago i received my new C8+ CSLNM1 and M21A CULPM1, unfortunately the M21A LED is not centered correctly
I had a similar problem on another convoy light with osram. IMHO that light you have is capable of 1000m throw. Shining it on a wall just 10 feet away with produce artifacts from the lobes. When I took mine outdoors, The distortion all went away or was impossible to detect. Again, IMHO there is nothing wrong with your light. The Osram led is less forgiving than say an XHP70.2.
M21B reflector for XHP70.2 and FC40 is in production
Pyrokiwi:Simon, did I see you are working on a larger cutout reflector for the M21B? I just received my S11 GT FC-40, and love it. I would like it even more in a single 21700 host like the M21B though!
I wish that was also available in S16. This is on the wishlist for my next order… :heart_eyes:
S16 or M21B with SFT-40 5000K/6500K (8A constant current driver)
S16 or M21B with FC40 3000K/4500K
S16 or M21B with XHP70.2 4000K
… plus some more of your great flat top adapters for 3X21A and 4X18A.
Received the 3X21A SFT-40 model today from Simon - Thanks! Posted some first impressions here: https://budgetlightforum.com/t/-/67266
L6 can not work with 26650 without additional 5mm magnet spacer.
Can Convoy make any flashlight without bug, or you get what you pay for?
I think you should have more respect for one of the few people who has always cared about our community.
Simon does not deserve a comment like this.
Simon, are you planning a S21B with GT-FC40?
This was asked a few pages back:
ch1ir:Simon will the GTFC 40 be offered in the s21? Also will the sft be offered in warmer tints? Thank you as always
The size of the S21 flashlight is too small. If the FC40 LED is installed on it, the heat will be too large, so I have no such plan.
At present, the factory only produces the 6500K version of sft40. I have not heard that they have plans to produce medium white light and warm light.
Simon Mao: Pyrokiwi:Simon, did I see you are working on a larger cutout reflector for the M21B? I just received my S11 GT FC-40, and love it. I would like it even more in a single 21700 host like the M21B though!
I worry about the heat……
I am using L6 with 2x26650 W/O any problems.
Because the flashlight must be compatible with 65mm to 70mm batteries, if you use 65mm batteries. It will be significantly shorter, and now I provide the corresponding accessories.
I am using Orbtronic 26650.
This one:
Average Rating: 4
Price: USD 10.95
It’s not difficult to produce corresponding reflector. I just worry about the heat.
