It sounds like the luminance of the SFT40 is similar (but not better!) than the SBT90.2 . Think twice before swapping it into the WT90, you win runtime but maybe not throw.
Yea, thinking it's a draw at best for throw. Hard to do apples-to-apples compare with variables such as the reflector, focusing, etc. I'm sure a reflector that's good for a SBT90.2 is not always the best for a Boost HX, etc...
The more I think about it, probably the best comparison is in an aspheric, and I got a couple with SBT90.2's, the 1504 for example, with swappable pills.
Will34 ,Well worth putting in a C8
I did like you say to upgrade from XPL HI with X5/X6 driver ,thinking a mild uplift in power/throw ,but it’s much better than I expected , now my best C8 thrower overtaking my old champ ,C8+ with a CSLNM1 @ 5amp by quite a bit ,maybe 25% better
They like 6500k because those bins are usually the brightest-lumens sell better than beam quality, remember? The majority of buyers of these are probably manufacturers of optocoupling instruments (like fiber optic stuff, optical scopes, lighting, endoscope, etc) or display illumination, automotive, and so forth. Cars mainly use cool white stuff for accent lighting (or DRLs). That’s mainly where domeless LEDs go anyway…they make the most of what they sell the most, so go figure.
The SFT40 can be pushed close to it’s limit with just one cell so it would probably outthrow the SBT90.2 in a single cell light. For multi cell light the SBT90.2 seems the better choice though it is also more expensive.
TomE, how many amps on the BOSS mod? I think it’s easy to over current this emitter looking at the Vf.
And according to my calculations, SFT40 may outthrow a 90.2 by 5% when both are at their peak. In the real world, the SFT likely pulls a meaningful margin at 30s in anything but massive, multicell lights.
On the BOSS1 with just 1 GOLISI cell, I measured 9.5 amps at 4.12V. Fully charged for the test, it must be higher -- see I didn't note it, so probably didn't measure it. I backed off from using 4 26650's which the BOSS1 is capable of, afraid I'd be past the peak with amps. It's an insane light to say the least, massive, the handle is really quite handy for it, not just for heat but to hold it in one hand.
The #'s posted were just on the single GOLISI. Think the 4 EFEST test was slightly lower results. Yea, could have been over the top, or the old EFEST's lost some power over the years, not sure.
I found the SFT40 on a mcpcb for sale. But I can’t find a driver for it. Any recommendations for 8-9 amps? Also, where to buy? (sorry, I’m a noob) Constant current/single mode is OK. I don’t need extra features. I’m also planning to run with an off-line power supply instead of batteries, if that makes a difference.
Hmmm, thanks for the testing djozz. Maybe Nitecore will use these on their next iteration of P12 and MH series. Would certainly be amazing. Hopefully they bring back the guarded tail-switch and the amazing rubber mode button in the next P12. The P12GT was absolutely perfect and every iteration after that has sucked. Exposed tail-switches (that’s less of a gripe, I can live with a light that can’t tailstand but meh), and the part where they REALLY messed up was in the side switch (which is also the on/off button on their lights without a tail-switch). That button is nearly impossible to find in the dark. It’s the same color as the rest of the light and you can’t feel it. Anyway, this LED seems promising. Might just try modding my old P12GT with this… after I get it fixed that is. I think the P12GT uses a MOSFET driver, would this LED work with that? (I’ve never modded a light before, newbie here so be easy on me ) I know Nitecore uses a lot of proprietary components and they’re a pain to get open, etc. (saw a thread once where someone opened up a P12GT, wish I had the link). Maybe I should just get a C8 and play with that first.
I see it being compared to the SBT 90.2, are they that similar? I have a Thrunite Catapult V6 and that has an XHP35 HI in it, would the SFT40 be a good upgrade for it? I can already see how modding lights can be a rabbit hole into which I could easily fall…
They are not that similar, except in their luminance (candela / sqaure mm), and their beam profile looks similar regarding the large hot spot. the sft40 is a great upgrade
I was comparing triple SFT-40's with a single SBT90.2, but 1:1 comparison, the SBT90.2 at 5700K has a better temp (warmer) and better tint, less green. I still think in raw throw (kcd), they are very close when both are driven hard (SFT-40 about 9 amps, SBT90.2 about 20-24 amps), and for those extra amps you get more lumens with the SBT90.2. They are both 3V, but a XHP35 HI is 12V, so a straight emitter swap in a 12V LED light is out of the question - more serious modding is needed.
Hmm not that similar how? Is there a size difference or is it just the voltage difference, being that the XHP35 HI is 12V and the SFT40 is 3V? Thanks for mentioning it’s a great upgrade Now I’m even more interested. Will likely end up doing it once I learn more. I’ll of course post it on the forum if I do, so that others may do the same if they wish.
Ok, so I’d basically just have to change out the board for another one that’s 3V and install the emitter there yes? So for example, buy an SFT-40 or SBT-90.2 and also get a suitable, 3 volt board and then just install the LED on the board and solder that to my flashlight? Or do these LED’s come preinstalled in suitable boards that I could just “drop in” my flashlight? Basically remove the old one, and solder the replacement in. The SFT-40 would be easier to drive on a single cell light like my Catapult V6, but I do know of a 26650 cell that outputs crazy current (like 45 amps) that I could purchase if I did go the SBT route.
I apologize i was in a rush and didnt finish my thought. the sft40 is aa good upgrade, but it is similar to the xhp35 HI in its design and beam shape. BUT - MORE Importantly - and to further TomE's point, you cannot just drop a sbt90.2 or sft40 in that catapult. and there is no "board" replacement like you were aksing about, it requires chaging the DRIVER in that Catapult so you can run the sbt90 or sft40, or any other 3 volt emitter for that matter. The xhp35 Hi is a 12 volt only emitter, so the driver running voltage is different. so that mod is more involved becasue well you have to find an appropriate driver first (not too hard) bu tthen remove the driver and set the new one in. its more of a pain, and that catapult with xhp35 HI is a pretty nice light, i would say this.
Your better off doing what im doing and buying an astrolux FT03 for aroud $35 shipped, it already has a sst40 mcpcb (the board the LED sits on) so all you need is a heat source and a soldering gun and you can VERY EASILY instal a sft40. once mine comes in i will be doing it, i will try to make a couple short videos of how i do it, if you think itll help?
Anyway good luck and feel free to ask questions. just always remember different voltage (3volt, 6 volt, 12 volt) all need didfferent drivers. and drivers CAN BE a pain in the but to replace, and just finidng the appropriate driver can be tough too. So try to avoid the driver swapping mod in the beginning unless you are buying some convoys and just want to practice it. BUT, LED swaps are easy. and most fun LED's are 3volt (fortunately for us!)
