I think that is right
this is the primary design advantage of sideswitch lights, which are all electronic switch designs,
most tailswitches are mechanical not electronic
exceptions being Novatac, HDS, FWxx and Noctigon Kxx
eSwitch on the tail makes them fatter
:student:
this sounds like the best explanation, mine did ramp up and simply ignored the switch… it has happened at least 3 separate times, after I had both head and tail off… and was trying the clip at both ends and screwing around with the body orientation too.
definitely check that the retaining rings are not loose. mine had a loose retainign ring in the head… but it is tight, and Ive still had the assembly short, with ramping… its just a thing that happens after having both ends off, such as when installing and removing the clip, or such…
