Not at all. Your drivers are perfect for it (6V/3A and 12V/2.5A)
Sorry. L7. And it does not have spring from driver side.
zoulas: Tangra:L6 can not work with 26650 without additional 5mm magnet spacer.
Can Convoy make any flashlight without bug, or you get what you pay for?I am using L6 with 2x26650 W/O any problems.
Ok, no spring then fuggetaboutit.
Tangra: zoulas: Tangra:L6 can not work with 26650 without additional 5mm magnet spacer.
Rear spring is very small.
Actually, this model is springs-free!
3*XHP70.2 is in design now
Any news about Convoy 3X21A 3*XHP70.2? When will it be available?
Any update on l7 26800 extension tube?
Simon, if possible I’d like to request you to make a special run of 2-26800 tubes for your L series. Maybe a sample run? I now you’ve stated that you’ll be making extensions, however a few may prefer solid one piece tubes. Part of the Convoy success is you make a very solid product.
I would have to agree with others… an S21 with this LED would be awesome… Besides… who runs on turbo?
Simon
Are you planning on a GT-FC40 version of the 4x18A?
I would love to upgrade mine, but unfortunately the XHP70.2 is 6V instead of the 12V the GT FC40 LED needs.
When a 12V driver is available, please let us know.
I agree, an S21 with the gt fc40 would be awesome. Those wanting prolonged use with fewer heat concerns could easily use one of the mode groups with a 50% max mode.
Simon Are you planning on a GT-FC40 version of the 4x18A? I would love to upgrade mine, but unfortunately the XHP70.2 is 6V instead of the 12V the GT FC40 LED needs. When a 12V driver is available, please let us know.
I have build one with Tamagotchi driver. Amazing high cri pop can!
The only thing i need is 25mm MCPCB for FC40 :)
Tamagotchi driver? Do you have more info?
26800 extension tube will be available in one week
Simon
ok ,i will produce suitable driver
Yokiamy:Simon
Thank you!
If you don’t feed it when it demands, it dies?
Yokiamy:Tamagotchi driver? Do you have more info?
That made me grin
I have striped 4x18 driver and used it to piggyback this one.
30mm 12V/5A
From OFF:
1Click – ON
2C – turbo on/off
3C – strobe. hold to change strobes.
4C – soft lock on/off.
5C – soft lock with beacon. 4C off.
HOLD – moonlight.
Click + hold – battery check 1-5
6C - enable or disable a backlight button.
2C + hold – beacon on/off
From ON:
1C – off.
2C – turbo on/off.
hold – 4 modes loop.
Click + hold – reverse to low mode.
I have striped 4x18 driver and used it to piggyback this one.30mm 12V/5A
From OFF:
1Click – ON
2C – turbo on/off
HOLD – moonlight.
From ON:
1C – off.
2C – turbo on/off.
Interesting, did you loose the USB charging function?
Yes. But i never use it anyway…
