IKEA kills off LADDA NiMH made in Japan
The best like eneloop have some advantages over lithium maybe give them a try.
To each their own, but as far as I am concerned; Eneloops are the “Gold Standard”. :heavy_check_mark:
In the case of NiMH, you get watt you pay for.
Eneloops.
i’m not going back,but curious, what advantages?
other than safety [tradeoff for lower power and energy density]…
i think the worst thing is, you cannot tell what their state of charge is, like ever…
wle
With lion 1.5v AA you absolutely can tell nothing at all about the charge state other than 1.5v>>>>>>>0.0v, due to the circuitry.
You can tell “something” about NiMh. Not perfect, but it’s something.
Decent NiMh have more capacity, and far more current capability. They have less parasitic draw again due to the circuitry. LSD NiMh can retain voltage much longer, and cost WAY less.
Lion AA are expensive.
Eneloops are rated for over 2000 cycles. Thought lithium was less. Can keep them topped off ready to use. Lithium? Besides they are so useful for devices all around the home.
…or IKEA Laddas!
I’ve never had a Ladda and hope not to. Had a Lana or two in my younger daze though. :laughing:
Seriously, please educate me. Are Laddas truly equivalent to a standard Eneloop?
(Or yer meaning that the other way.) :slight_smile:
ChibiM, who runs the Eneloop101 site, and had the opportunity to interview Fujitsu (Eneloop parent) battery engineers, believes they are equivalent to 1st generation Eneloops:
I don’t know if he is still active in testing, but it will be great if AACycler is able to test a set. I would bet HKJ will do a test, but he mainly tests capacity and charging characteristics, not cycle life.
Good to know.
Thx. :+1: :beer:
I have Japan made AAA laddas working perfectly since 2017. No issues. Eneloop style…
2450mAh LADDAs are 500 cycles only for AA. Are they worth it at $2 a piece?
Most definitely! They are similar to Eneloop Pros, more capacity but less cycles. However they still outlast all other NiMH batteries I’ve used.
Just finished charging up the dark grey Ladda’s (2450mAh ones). Bought 3 packs (12 batteries) on 8-10-21. Yes, they are marked as “Made in Japan”. These all had an embossed date code of 2103. I’m taking that as March 2021. So, if this is correct, and assuming worst case…,(end of March), that is around 4 months of sitting around…actually being shipped from Japan to where ever to southern California to the IKEA store I purchased them from. Here are my findings so far. They may be about 1mm longer than the white ones. I have not measured them, but they seem to stack differently and slightly tighter than the white ones. Just an observation. After the first discharge/charge cycle in my AccuPower IQ338XL charger, set to the non changeable default discharge of 500mAh and the charge setting of 700mAh, these came in with a residual charge of 1789mAh to 1934mAh discharge out of the box and 2616mAh to 2886mAh taking some 4 hours 16 minutes to 4 hours 43 minutes to charge, with 15 to 21 milli ohms of internal resistance on the 1 cycle. I did all 12 batteries. Then after the first 12 discharge/charge cycles were accomplished, I put them all in the charger to do them 1 more time. After the 2nd discharge/charge cycle, the discharge ranged from 2462mAh to 2669mAh. They all seem to discharge over their rating of 2450mah. The charge cycle ranged from 2586mAh to 2884mAh taking some 4 hours 13 minutes to 4 hours 42 minutes to charge with 15 to 30 milli ohms of internal resistance. They seem to behave just like the white Ladda’s so far. I have quite a few of those that I have been using and testing for the last 2 years. The test AA’s AAA’s (12 of each) have shown to be above their ratings and the shelf life are still above 85% of listed capacity at 15 months of sitting on the shelf, which I believe to be fantastic. Will try to update in a year to give you’al some feelings into the low self discharge of the new style batteries.
Confirmed to be made in Japan.
Just assume that they’re legit Fujitsu/Eneloop HiCaps.
Just assume that as such, you’re get between 2-3 years of life out of them before their I.R.s rise to the point that your AccuPower charger will reject them.
Just use them and abuse them.
I no longer buy HiCaps for the above mentioned reason, but in certain apps, they can be worth the scratch.
Just don’t expect 5-10 years out of them.
Just remember that chargers aren’t uniform across the board. My LaCrosse BC-700 reads about 10% higher than my Maha C9000 on NiMH and that charger is similar to your charger.
My two Opus BT-4100s read about 5-10% higher than my Maha.
Chris
Someone should change the title of this post, the new grey Ladda’s are still MIJ. No MIC grey Laddas have been spotted.
https://www.fdk.com/denchi-e/
Fujitsu
Fujitsu, on the other hand, currently owns the factory. This single factor is the only one capable of producing these low self-discharge nickel-metal hydride batteries, and it supplies many brands such as Amazon, Fujitsu, Panasonic, and… IKEA.
Truth Be Told……
The white LADDA batteries were not that good long term.
I have empirical data from tests which proves that LADDA (At least the NiMh AAA did not do so well long term.
They tend to lose their capacity more so than comparable NiMh rechargables over time. Consistently.
It’s not a great difference, I would say they lose 20% more of their capacity than some comparable NiMh AAA’s.
Most likely due to their chemical composition. I have a plethora of LADDA’s and I compare them with a number of other brands through a rather
exhausting set of tests.
That said, the batteries they are being compared to are “COMPARABLE”….meaning, they are from the same circa dates as the Ladda.
I cannot speak for later batteries from LADDA (Ikea) or from competitive brands.
Bottom line……it’s not a great loss…and there are BETTER substitutes in the same price range. Some of which would surprise most people I suspect.
My white Laddas are still going strong. Best value for money NiMHs I’ve used.
