With lion 1.5v AA you absolutely can tell nothing at all about the charge state other than 1.5v>>>>>>>0.0v, due to the circuitry.
You can tell āsomethingā about NiMh. Not perfect, but itās something.
Decent NiMh have more capacity, and far more current capability. They have less parasitic draw again due to the circuitry. LSD NiMh can retain voltage much longer, and cost WAY less.
Lion AA are expensive.
Eneloops are rated for over 2000 cycles. Thought lithium was less. Can keep them topped off ready to use. Lithium? Besides they are so useful for devices all around the home.
ChibiM, who runs the Eneloop101 site, and had the opportunity to interview Fujitsu (Eneloop parent) battery engineers, believes they are equivalent to 1st generation Eneloops:
I donāt know if he is still active in testing, but it will be great if AACycler is able to test a set. I would bet HKJ will do a test, but he mainly tests capacity and charging characteristics, not cycle life.
Just finished charging up the dark grey Laddaās (2450mAh ones). Bought 3 packs (12 batteries) on 8-10-21. Yes, they are marked as āMade in Japanā. These all had an embossed date code of 2103. Iām taking that as March 2021. So, if this is correct, and assuming worst caseā¦,(end of March), that is around 4 months of sitting aroundā¦actually being shipped from Japan to where ever to southern California to the IKEA store I purchased them from. Here are my findings so far. They may be about 1mm longer than the white ones. I have not measured them, but they seem to stack differently and slightly tighter than the white ones. Just an observation. After the first discharge/charge cycle in my AccuPower IQ338XL charger, set to the non changeable default discharge of 500mAh and the charge setting of 700mAh, these came in with a residual charge of 1789mAh to 1934mAh discharge out of the box and 2616mAh to 2886mAh taking some 4 hours 16 minutes to 4 hours 43 minutes to charge, with 15 to 21 milli ohms of internal resistance on the 1 cycle. I did all 12 batteries. Then after the first 12 discharge/charge cycles were accomplished, I put them all in the charger to do them 1 more time. After the 2nd discharge/charge cycle, the discharge ranged from 2462mAh to 2669mAh. They all seem to discharge over their rating of 2450mah. The charge cycle ranged from 2586mAh to 2884mAh taking some 4 hours 13 minutes to 4 hours 42 minutes to charge with 15 to 30 milli ohms of internal resistance. They seem to behave just like the white Laddaās so far. I have quite a few of those that I have been using and testing for the last 2 years. The test AAās AAAās (12 of each) have shown to be above their ratings and the shelf life are still above 85% of listed capacity at 15 months of sitting on the shelf, which I believe to be fantastic. Will try to update in a year to give youāal some feelings into the low self discharge of the new style batteries.
Just assume that theyāre legit Fujitsu/Eneloop HiCaps.
Just assume that as such, youāre get between 2-3 years of life out of them before their I.R.s rise to the point that your AccuPower charger will reject them.
Just use them and abuse them.
I no longer buy HiCaps for the above mentioned reason, but in certain apps, they can be worth the scratch.
Just donāt expect 5-10 years out of them.
Just remember that chargers arenāt uniform across the board. My LaCrosse BC-700 reads about 10% higher than my Maha C9000 on NiMH and that charger is similar to your charger.
My two Opus BT-4100s read about 5-10% higher than my Maha.
Fujitsu, on the other hand, currently owns the factory. This single factor is the only one capable of producing these low self-discharge nickel-metal hydride batteries, and it supplies many brands such as Amazon, Fujitsu, Panasonic, andā¦ IKEA.
The white LADDA batteries were not that good long term.
I have empirical data from tests which proves that LADDA (At least the NiMh AAA did not do so well long term.
They tend to lose their capacity more so than comparable NiMh rechargables over time. Consistently.
Itās not a great difference, I would say they lose 20% more of their capacity than some comparable NiMh AAAās.
Most likely due to their chemical composition. I have a plethora of LADDAās and I compare them with a number of other brands through a rather
exhausting set of tests.
That said, the batteries they are being compared to are āCOMPARABLEāā¦.meaning, they are from the same circa dates as the Ladda.
I cannot speak for later batteries from LADDA (Ikea) or from competitive brands.
Bottom lineā¦ā¦itās not a great lossā¦and there are BETTER substitutes in the same price range. Some of which would surprise most people I suspect.
I have 3 of those IQ338XLs along with my MC3000ās and various other chargers / discharge testers.
If you want 4 different results from any of those batteries, just repeat the test in a different slot.
BTW, 127milliohms is as high as the IQ338XL will read, regardless of the batteries actual IR
I canāt.
Since 2017 Iāve bought hundreds and hundreds of batteries and havenāt needed to buy new NiMh batteries lately. In more than a year actually.
Iām just using up the old stock until the capacities are too low to continue using them.
The batteries that were ābestā last year may not be this year. Factories change. Materials change, manufacturing processes change etc etc.
I can only speak for the batteries Iāve had and used / tested over the last 4 years.
IKEA still sells the 2450 and now the 1900. Wrapper says Japan, imported through IKEA Mexico. Wrapper is now brown. Iāve been wanted ikea priced rewrapped regular eneloops and it appears this is it.
