It’s a sort of GTmicro type light and gives it a good run for its money, but for me there are more than one deal-killers.
“Breathing” sideswitch. F’n creepy, only choices are breathing and off, no steady. Okay, I can turn it off, but what’s the point of a lit switch, then?
Weird-ass UI. Not as backward and counterintuitive as on the E05, but bad enough. Only shortcut is for blinkies, nothing (as in zero) for moonlight/turbo.
So as is kinda typical for Wubens, fantastic hardware, trash UI. :weary:
Ordered b4 you posted. I’ll probably return it. I’m sure I’ll be disappointed compared to 3 soonfires for nearly the same price. I wonder when Amazon will cut me off. I return a LOT.
I politely beg to differ. It’s not a super-flexible UI like Anduril, but nor is it meant to be. It’s meant to be dead simple. Would I have liked shortcuts? Yes. Does that complicate things for everyday users? Perhaps. This thing has 3 modes; to me having shortcuts isn’t going to make-or-break a UI when you only have 3 modes. At least it’s click-on, click-off.
Just like I’m not about to toss out my E05 because it is a fantastic piece of hardware, but there’s nfw I’d EDC the beastie simply because of its backwards UI.
My gf has a set’n’forget approach. Set the light to the brightness she likes, then it’s just on/off. Nothing wrong with that if it’s what you want.
But for (seemingly) most people here who want andouille 3+ for even a squeezy-type coin-cell keychain light, a backwards UI might not fly.
I’m too dumb for Andruil tbh. Maybe someday I’ll memorize it and find it more useful. I’d like to try Andruil 2, maybe I’ll make fewer mistakes (that end up w/ light in whacky mode).
Thanks for that. I will put up with ramping from high and a few other UI quirks, but these? Nah. OSRAM CSLPM1 and CULPM1 emitters are still relatively new… there will be more deals like this with other lights having a better UI. Can wait!
Thank B’harni the TO46R has that dual-switch setup, else its UI would be f’ed, too.
Wuben’s got some really good lights, but the crappy UIs make them (to me at least) nigh unusable. Again, personal choice, if you can get used to it, etc., B’harni bless ya.
I’m holding the Wuben E6 in my hand right now.
From off- single click turns on in last mode, then, long press to cycle through l-m-h-l-m-h…. or double click goes to strobe mode, single click to off.
From off- long press does nothing.
From off- double click goes into random strobe mode. Double click again to get SOS. Long press does nothing. Single click turns off.
I have not found any moonlight or turbo modes.
So, click on, click off. Double click any time to get strobe. While on, long press to cycle through L,M,H.
I just posted the Wuben UI. It’s not like the Manker. It’s very simple and basic.
Click on. click off.
While on, long press to cycle through low, medium, high.
Double click from off or on and get the strobe.
I did try the 10 second long press and it had no effect.
Edit- forgot the lock out. From off, click 4 times to lock out. Unlock with 4 clicks.
Yup, I reviewed it at 1Lumen. Very simple 3 mode UI. Click on, clock off.
I also had thought about the Manker similarities. Never owned one though. Unlike the Manker that had a pill, bilakos’ review shows the LED and driver both being mounted on top of a shelf. A very interesting and compact design with what should be good thermal path.
Yea, the Manker is 2 mm shorter, 1 mm thinner at the head. JM's review of the T01 here is probably why I bought one. There's just so many similarities around the switch specially, and clearly the styling is different, and the E6 is certainly modernized with the LED, etc.
Actually the low amp LED that throws is like perfect for this design. I should mod my T01 the same way. Way back my intent was to mod it with a driver swap but it didn't work out, can't recall details why, but small driver PCB were hard to come by back then.
That E6 LED/driver design is a major issue for a driver swap mod.
