ShyOne
(ShyOne)
July 29, 2021, 7:37pm
29
Yes, a flashlight powered by a LiIon battery “could” indeed turn into a pipe bomb.
I DO NOT know the odds of this happening… BUT, I WOULD THINK THEY ARE EXTREMELY SLIM.
It would be an EXTREMELY RARE occurance.
alpg88:
yes it can and it has, there are several thread with pics on cpf, iirc, in one instance, the light destroyed a balcony glass panel, and made the owner bleed. but it is very unlikely scenario, especially if you do not use crappy cells,
I recall reading the post about the incident alpg88 mentioned above.
I have searched for the thread about the incident but cannot find it.
It was an eye opener for sure….
ShyOne
(ShyOne)
July 29, 2021, 7:42pm
30
Chevy should have changed the name to the “Lightening Bolt” ….
ShyOne:
alpg88:
CPF posting on Olight incident
Lawsuit on Olight explosion
Another CPF post
Lightbringer:
I remember reading the story (mightta been on CPF) about a guy whose light went supernova as he was carrying it, blew out the front glass and reflector, and shards from same ended up in his leg/foot.
Not Fun.
I had an incident back in my teens with dads car (’70s Ventura/Sprint). Stomped on the loud pedal to get onto the main drag from a parking garage, pedal got hooked under the floor mat, and I’m rocketting towards the cars in front of me stuck at a light.
Bam! Shift into neutral, reach down, yank back the entire floor mat, and hit the brakes. Over and done in like 2-3sec. Shiite, even I was impressed how well I handled that. :laughing:
Interesting about the Bolt. Let it burn itself out, eventually, like those Pennsylvania coal mines. :laughing:
Good Gawd. Sounds absolutely fooking HAIRrowing. I bet ya lost a few curlies or ya GREW sum IDK. :laughing:
PS. I gotta sneakin’ suspicion that the floor mat thing is watt’s mainly to blame when people think their throttle stuck wide open all of a sudden.
ShyOne
(ShyOne)
July 29, 2021, 9:35pm
33
Thank you SIGShooter for those links.
I found the one we were referring to above…
TK Monster Explosion
ShyOne
(ShyOne)
July 29, 2021, 10:21pm
34
A true Diesel Runaway has nothing to do with a stuck throttle cable
It is a scary thing to behold…. and depending on the size of the Diesel engine can be downright frightening!! Especially if you cannot stop it & it runs until meltdown……
I’m thinking if a flash is gonna go Bikini Atoll at least it can turn into a rocket first then explode harmlessly in the atmosphere. That’s why I’m open to drilling a hole in the tail.
If you just get single cell lithium ion flashlights, the risk is pretty low.
Or, you could just stick to Eneloops.
Geoduck
(Geoduck)
July 29, 2021, 10:59pm
37
I remember a post on cpf many years ago where a guys light,(probably a Surefire) running 2 cr123 started making a whining noise and he pulled it out of it’s holster and it was extremely hot. He no sooner set the light down on the counter when it exploded blowing out the end and sending the light flying through the air like a missile where it hit a sliding glass door shattering the glass and putting a huge dent in the frame of the door. So a light might not blow up like a pipe bomb but fly through the air like a missile.
I can’t get my head around it.
Oli
(Oli)
July 30, 2021, 2:14am
39
On any car with an automatic transmission built within the last few decades and beyond you can turn the key off (while driving) and the steering wheel is not going to lock unless you put the transmission in park and then turn the switch even further to the position where you can remove the key. If you’re on a highway you can steer to the side without issue without power steering fairly easily with two hands. You can get a couple of pumps of the brakes. But don’t pump them, just step on it and don’t let go. You can also just pop it in neutral and the computer is not going to let the engine rev beyond a very safe level. Some cars today won’t go much over 3,000 RPM in neutral. With push button starters you often need to hold the button down for three seconds or press it 3 times on some vehicles if you are in Drive. You should experiment with all of these methods with your foot to the floor at various speeds. Again the steering wheel will not lock. You won’t hurt anything with any of the above. And you can restart the car while still rolling in neutral at any speed if you want to bail out of any of your experiments.
Oli:
On any car with an automatic transmission built within the last few decades you can turn the key off and the steering wheel is not going to lock unless you put the transmission in park and then turn the switch even further to the position where you can remove the key. If you’re on a highway you can steer to the side without issue without power steering fairly easily with two hands. You can get a couple of pumps of the brakes. But don’t pump them, just step on it and don’t let go. You can also just pop it in neutral and the computer is not going to let the engine rev beyond a very safe level. Some cars today won’t go much over 3,000 RPM in neutral. With push button starters you often need to hold the button down for three seconds or press it 3 times on some vehicles if you are in Drive. You should experiment with all of these methods with your foot to the floor at various speeds. Again the steering wheel will not lock. You won’t hurt anything with any of the above.
Good to know. :+1:
Also don’t forget your emergency brake in case you’re outta pedal brake from panic pumping it too much. :laughing:
Yep, that's what I do.
I like to get high quality cells and chargers to reduce the risk.
CRC:
Those are two opposing statements lmao.
Im trying to avoid having to know about all that.
That is going beyond my abilities.
Oops.
I obviously misread your earlier post.
So, we have different strategies for acquiring cells and chargers.
I had a 14500 just leak in my GTmicro. No kaboom. No earth-shattering kaboom. Just clear ook leaking out from the beastie.
Must’ve caught it fairly quickly, ’cause no permanent staining of the battery-tube or anything, not even the springs or driver.
Does anyone else remember a thread on here years ago of a Skyray King literally exploding?
This guy was using cheap bundled cells, so obviously junk Chinese crap that were unstable
Turned it on for a few minutes on Turbo, heard popping sounds
Turned it off, placed it down and left the room
BOOM!
The shrapnel blew out his apartment window
He had photos of the aftermath. I’ve search in the past for hours and can’t find the thread maybe it was on candlepower
I don't remember seeing photos of the aftermath, so I'm guessing that wasn't on BLF.
I found the thread on candlepower, it’s different to what I thought it was, but still an explosion
Ah, I see it was already posted
Just a case of using dangerous batteries though
Bort
July 30, 2021, 4:32am
47
Dear god! Those look more like grenade fragments
alpg88:
I think i remember that one, lived in an apartment, insurance did cover it iirc.
MtnDon:
I believe that if something happens tocause a cell in a flashlight to “have an event” the cell will most likely catch fire rather than explode like a bomb. That would, I believe blow out, melt, the tail switch if there is one, or/and blow out, melt the reflector or optics in the front, or/and even theside switch aperature would also vent. No shrapnel flying about, but a “road flare” that could start a fire.
Interesting theory.
JamesB:
There is one case of death caused by an Olight flashlight exploding while the poor user was holding it in his mouth, there has been quite a few documented cases in the past on CPF of catastrophic flashlight explosions, these were mostly used with CR123 in series , also some intances of loud but harmless popped tail switch rubber.
I only use single cell lights, so hopefully that cuts the risk substantially
The proverbial flashlight is between 100 and 4000 lumens (Olight I3e to Convoy M3C).
kennybobby:
Yes, If a lithium cell exploded in a flashlight, then indeed it would blow the light apart. It would be a Bad Day.
Most quality cells have over pressure vents that will open if the internal temperature goes up due to any of the various failure scenarios; venting should prevent an explosion.
Thats good.
SIGShooter:
ShyOne:
alpg88:
Another CPF post
HF poisoning :person_facepalming:
Geoduck:
Thats insane.
Funny how i got many mocking replies in this thread for even asking the question.
It's a good thread.
I think some people just don't want to think about the remote chance that lithium ion batteries can be dangerous.
