Trustfire T21R is a rechargeable tactical flashlight with high performance.
T21R has extremely high reliability and operability, up to 2600 lumens, with intelligent temperature control and low voltage warning, powered by a (2170zero) rechargeable lithium ion battery; adopting USB Type-C charging technology, IP68 level dust-proof and waterproof, can be used in complex and changeable outdoor environments; tactical switch on the tail cap,change modes switch on the neck, and anti-drop height up to 1 meter, let you use it in outdoor and work environment with confidence.
I see you have it mounted on a rifle / long gun, are you going to include / offer a pressure switch pad to replace the tailcap for “Tacticool” situations?
In the description “Using the international patent latest generation of LUMINUS SST-40 LED, life of 50000 hours”. I like little lights 228 meters, 2600 lumens. Perfect for little throw, lots of spill. The biggest problem here is it only has a 24.6mm body for a 21+mm battery. This helps bring the weight down to 71.8 Grams giving turbo run of just seconds. This is more a 18650 light since 21700 capacity is not going to get used here.
Hello,
the LED is CREE,and it has five modes,moonlight,Middle mode,High mode,Extreme high mode,strobe mode.
it’s use 21700 battery,ip68 level of protection,Type-c charging.
please visit our product: https://www.ebay.com/itm/194258511729
