Sofirn told me via email that these will be available on Amazon sometime in July, so Iāll wait for that to order.
I am a big fan of Sofirn lights (my current EDC is an SC31 Pro 18350, and thereās an SP35 sitting on my nightstand). Iām not all that enamored with this light.
First, itās long at 73mm. Iām sure a lot of that length comes from the reflector to focus the LH351D to such a nice beam (as shown in the video review). But the Olight Baton 3 (63mm) is 10mm shorter than the SC21, the S1 Mini (54mm) is 9mm shorter than the Baton 3, and the Fenix E16 (51mm) is 3cm shorter than the S1! This thing is longer than the Thrunite T1, which is an 18350 light!
Second, I am doubtful of the runtime/output numbers. The SP10S claims its high mode is 310 lumens for 2 hours 11 minutes (of which that output is inflated) using the same LED. It seems suspicious that this light can maintain 400 lumens for an hour and a half utilizing a battery that has near the same capacity battery as the SP10S. Also take into account that the SP10S claims 80 lumens for nine and a half hours, where the SC21 claims 100 lumens for only four hours. Something seems offā¦
Third, if this uses the same ramping software as the SP32 and the SP35, then it has the same problem of its ramping curve. Those lights ramp way too linearly, as it takes the same amount of time to increase the same amount of lumens throughout the range. As an example, if it takes the light a quarter of a second to increase 100 lumens, thatās a lot more noticeable when at the bottom of the ramp than at the top (where itās not easy to distinguish that increase in output). Trying to adjust the lower end becomes much more difficult, where the difference between 5, 20, and 100 lumens is dramatic.
To me, this one seems like a swing and a miss for Sofirn, as well as a missed opportunity to bring a small (around 60mm) 18350 light to market.
Just got mine today. Nice light but not revolutionary. Memory mode is disappointing (changed my mind on memory mode). My OnTheRoad M3 Pro is stuck to the metal stem of my bed side table lamp. This one might attach to the fridge, only have 3 torches in the kitchem atm.
Size reference of come of my short stuff: L-R Astrolux K2, Amutorch E3S, Sofirn SC21, OnTheRoad M3 Pro, Astrolux S41 & Lumintop FWAA
Inbuilt battery, 20350, 16340, 16340, 18350 & 14500
Canāt believe that nobody passed an info from Redditā¦
Barry agreed to make a batch of SC21 Anduril if his electronics team confirm itās doable :)))
Thatās ācause we want SP10S first!
In pink, please :+1:
Honestly... i like SP35 UI, simple and waaaaay better than hold for off crap so if only this can be improved on SP10 i'd be more than happy. Colors...whatever LOL
SP35 UI improvements over the SP10S are fantastic. Thereās something I love about the Sofirn UI when used in stepped mode that others like Olight donāt do. Itās what I call the ādead zone.ā Thereās a time between a single click and a long press where the UI does nothing. This works fantastically if you accidentally donāt hold the button down long enough for a long press. If the light is off and you want moonlight, but donāt hold the button long enough for it to turn on, nothing happens. Mainly, it does not turn on in memorized mode, blinding you when you wanted moonlight. If the light is on and you donāt hold the button long enough for a mode change, the light does not shut off on you, leaving you in the dark.
Two other things dealing with moonlight over Olight: Sofirnās UI does not memorize moonlight and takes much less time for a long press to actually turn on.
Thatās the ugly part.
When Iām away, I always leave my S1R at moon level. I bet if Iād take the Sofirn, I would blind myself a couple of times.
I can see a person preferring moonlight to be memorized, especially with Olightās long delay to access it through shortcut. But with the short time the Sofirn UI takes to access it, it doesnāt seem worthwhile to have it memorized too. I leave my SP35 in eco mode (which is around 6-7 lumens) and then have direct access to two low modes.
Wellp, I like the setup of my EC50, which has zero blinkies and is simplicity personified.
Pressānāhold goes to moonlight, no need to memorise anything. 2click goes right to highest, also no need to memorise anything. Regular click takes me to the last-memorised setting, which is typically just regular low or maybe the next-higher setting. SO I have immediate access to 3 discrete modes/levels.
My MH20 is a little different. Hold a half-press for moonlight, hold a full-press is turbo, regular click takes you to last-memorised. Regular click takes you to last-memorised, sure, but it does remember and memorise both moonlight and turbo if thatās what you got to, even by shortcut.
Either way, I never got blinded by either, as I can always always always start from moonlight with no surprises. I donāt see any bother with taking the shortcut to moonlight if only to be sure thatās where youāre starting.
Whatās the advantage of not having it memorized, longuylander?
I really wanted to like this light but so far I couldnāt :zipper_mouth_face:
Namely due to the comparison with other lights (non consensual ones, eventually)
This SC21 is longer than an S1R / S1R II (16340); it is also longer than the Skilhunt M200 with shorty tube (from Astrolux ) and an 18350 that has more capacity. Slimmer than the last one, of course, but even so, not much
I know it may have some virtues, but I couldnāt find one that would lead me to buy this light! I am not bashing, just saying that others suit me better!
And I hope the ones who get it like it and that it works fine
As Lightbringer mentioned, a light that has a shortcut to moonlight but doesnāt memorize it gives three different modes for the light to be turned on. The shortcut can always be used to get to moonlight, so memorizing it only takes away one of the regular modes for direct access. Which is why itās great that most lights donāt memorize turbo either, but give direct access to it. Again, just a personal preference.
Yeah, Anduril can do that as well as Zebralights. I like both, but in this format, I prefer the Olight UI. One click for moon saves old men in the middle of the night in hotel rooms. Difficult enough to remember where I am.
So I kind of wanted one, and I got a code from the Sofirn thread. But after hearing about a possible anduril version Iām holding out.
Iām usually anti-memory but works well with this one. From off - press and hold for moon light, dbl click for turbo or single click for last used mode.
Two concerns - 1) I havenāt tested runtime but the battery seems to run out quick - parasitic drain?
2) The magnet is WEAK! Torches similar size in rank of magnet strength:
uTorch S1 mini 16340 strongest
Eagle Eye X1R 18350 middle
OnTheRoad M3 Pro 16340 middle
Sofirn SC21 16340 weakest
Thatās pretty lame. I hate a weak magnet on a flashlight. I want to hear that clack when i throw it on rebar.
Yup. D4S [CLANG] E12R [BANG] E07x [KAPOW] PL47G2 [PLONK] SC21 [PFFT]
I had the M3 Pro stuck to the vertical metal stem of my bedside light. Itās been hanging there since christmas. Stuck the SC21 below the M3 and it had slid down by morning. Sad.
D4S is my gold standard for tail magnets. Are you saying the E07 is stronger? I donāt have one of those. Yet.
