Best light for a sailor
34 posts / 0 new
CvR_XX
CvR_XX's picture
Last seen: 2 months 2 days ago
Hey All,
For years I’ve been rocking just my armytek wizard pro v3 as my light source to go when sailing and camping. I just had some issues with it so I decided to buy a Skilhunt H04 as a backup. As a lantern, I’m using the blf lt1 one which I’m really happy with although I’m really longing for the mini version to hang up in my little tent.
The one thing that is missing is a handheld light to be used as some kind of searchlight. This light will need to be a thrower and needs to be bright with reasonable battery life. I’m thinking of the Sofirn C8G. It will be used to spot obstacles on the water while sailing and help with activities when I’m at my scouting.
What do you guys recommend? Any tips are welcome.
ps.:
My case for the lt1 has just arrived:
Yokiamy
Yokiamy's picture
Last seen: 13 hours 35 min ago
Please define reasonable battery life, as this will be a big part of the search.
Also, how long do you plan it to use on turbo? (Due to possible stepdowns)
Nice case btw, which one is it?
Is it the JBL case?
Unheard
Unheard's picture
Last seen: 12 min 24 sec ago
Smile, you cannot kill them all.
CvR_XX
CvR_XX's picture
Is it the JBL case?
Yes it is the jbl case. Works great with the stuff to hang up the light.
It will be used for a couple of hours at the time so it needs to have at least that runtime. I almost never run my lights on such a turbo that thermal trottling will start.
CvR_XX
CvR_XX's picture
Another thing I would like to add is that my budget is around 50 euros. This light will really be my extra light when my armytek headlight is not powerfull enough.
Yokiamy
Yokiamy's picture
I do have a Convoy L21A with XHP35 which might fit your needs, barely used.
I also have the current king of LEP laser flashlights the Maxtoch L2K, which would be excellent on water since you wont have any spill that might disorient you on water and it has great runtime.
That one exceeds your budget, but i’m willing to sell it.
dthrckt
dthrckt's picture
Last seen: 1 hour ago
Haikelite HT35. Search lights with lots of spill are often useless on the water, mist causes so much back scatter you can’t see a thing.
Convoy Z1 if you’d like lighter weight and more compact but similar functionality.
Lightbringer
Lightbringer's picture
Last seen: 3 hours 3 min ago
Open water = fog + mist + spray. Don’t want spill from a regular reflector light, so that leaves either a tight TIR, an aspheric, or a LEP.
Aspherics (zoomies) are best and cheapest, but the least waterproof due to the moving head. The JaxMan Z1 (nice version of the Cometa, which I got) would be great.
A tight TIR like the 2 Acebeams (L17/L19??) might work great, but don’t recall their cost.
A LEP would be best for longest “punch”, but they’re the priciest.
ch1ir
Last seen: 2 hours 14 min ago
This
Emisar D⁴, Astrolux C8, BLF A6, Sofirn sp36aV2, Reylight Mini Pineapple, BLF 348 KillZone, Lumintop IYP07, Emisar D18, Boruit D10, Manker e01, Ultrafire z1, Massdrop titanium AAA, Astrolux HL01, Armytek Wizard Pro Nichia, Tacklife LFL3A, Astrolux FT03, Zanflair T1
Sirstinky
Last seen: 1 min 37 sec ago
Something with a very narrow TIR optic or LEP. LEPs are over $100 euros for a cheap one though. I recommend the Acebeam L17 or L18. The L17 is closer to your budget around $50 euro, but the L18 is the next best choice becsuse the beam is more useful and it takes 21700 batteries for longer runtime. Its around 70 euro.
Clayson
Last seen: 3 months 2 days ago
Have you thought about the 4×18a convoy that uses 4 nateria 18650? should last long enough. A hotter xhp70 led should give little reflection. If you prefer to play star wars use 4×18s with sbt90.
Generic Zoomie Xml LED
Nitecore NU 17
Thorfire Q8
dthrckt
dthrckt's picture
If new to flashlights, hearing recommendations of Lep mixed with Tir, for use on the water could be confusing.
I love tir flashlights, but you can’t see several hundred meters with them on the water in any but the clearest situation.
zoulas
zoulas's picture
Last seen: 25 min 48 sec ago
Anyone that even tries to answer this question is really giving you bad advice. At the end of the day, it’s up to you. A flashlight is a tool. What kind of tool you use is up to you.
dthrckt
dthrckt's picture
I always assume the questioner knows that, and is looking for the reasons some models fit specific uses. Otherwise there would just be 1 or 2 flashlights. I don’t want to live in that world.
CvR_XX
CvR_XX's picture
I just ordered and received the acebeam L18. Apparently I ordered batteries without a protection circuit. Is that a problem?
dthrckt
dthrckt's picture
I’ll be interested to hear if you feel it still has too much spill on the water.
I don’t see where Acebeam claims the L18 has low voltage protection, but reviews state it does, and you have a battery level indicator, I wouldn’t worry about protected batteries.
https://1lumen.com/review/acebeam-l18/
wle
wle's picture
Last seen: 4 hours 7 min ago
i;d think a ‘sailor’ would also need something floody, pocketable, and still pretty bright
i use my FW3A about 50 times a day
i never miss having a ‘throwy light’
well i mean i have a couple, i may use them 3 times a year
it sounds like you need one, but you also need something for close up situations, which it seems would occur frequently also.
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
zoulas
zoulas's picture
A light should fit your needs, not your occupation. There is no best light for a mechanic or a doctor or a sailor for that matter.
dthrckt
dthrckt's picture
Depends on the vessel!
Bort
Bort's picture
Last seen: 22 min 40 sec ago
How far away do you need to see?
100m, 500m, 1000m, 2000m?
The further, the higher the cost.
The fog is a good point made above, if this is not an issue and all you need is say 250 meters a low cost carefully selected may handle it.
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
dthrckt
dthrckt's picture
Bort wrote:
How far away do you need to see.
Forever
Bort
Bort's picture
dthrckt wrote:
Forever
OP is out of luck then Crying
Even sunlight is not forever Tired
CvR_XX
CvR_XX's picture
The use case for me is mostly spotting marks on the water which don’t have lights. I think a thrower is a great light for that. Apart from that it’s great to amaze friends with the range :-p.
For everything else than this I use my armytek wizard Pro headlamp. You need both hands while sailing and you can set it exactly to the amount of light you want. Especially the moonlight modes are great because you retain night vision. In my opinion good moonlight modes are way better than red lights.
I also just got my lt1. That’s probably great for inside the cabin although lighting is almost all ready installed there.
CvR_XX
CvR_XX's picture
Most sailors I know use headlamps. You need your hands and you need licht very local.
Bort
Bort's picture
A C8 will give you plenty of throw, also i have a Nitecore P30 with 600 meters of throw, i think there are a couple updates that throw much further.
Bort
Bort's picture
Perhaps a solid/permanent mount is the answer?
pirate joe 22
You need a light that is waterproof, and will float.
jacktheclipper
jacktheclipper's picture
Last seen: 8 hours 7 min ago
A no-spill pencil beam is the best when hunting for channel markers at night .
Especially when you’re trying to preserve your night vision .
What I do
CvR_XX
CvR_XX's picture
For my personal use I disagree. If a light drops overboard it’s probably at night. The chances that I will be able to recover it are very tiny. I think its beter to have some rope attached. That’s what I do with most of my sailing stuff anyways.
cyclops
A sailor needs a fleshlight. Big Smile
PSA – Don’t Google it.
NeutralFan
NeutralFan's picture
Last seen: 2 days 19 hours ago
How about the Convoy L21B (SFT40): Review & Beamshots? It takes the bigger 21700 battery so more run time than an 18650 and looks like a great thrower based on the review!
I’d rather use my flashlight around the house than turn on the lights.
