【convoy】H4 and B35AM options are updated
I think an S12 with 219b would work very well. With the 6A driver that’d be 2A per emitter. The 219b is great for triples. I built an S2+ triple with the 5A driver and 3 SW45k emitters.
For the S2+, is it possible to just purchase the tail end of a host?
I’ve dropped and banged my S2+ so many times on its tail end that the magnet no longer fits
Suitable copper MCPCB in production
available now ,i got them today ,i will add links in two days
no seperate tail , maybe you have to buy a host
Any news about a link to order S16 with SFT40 and 8A CC driver yet? I would also love to see FC40 3000K in the S16 or M21B. :LOVE:
Any news on 26800 tube l7?
Great news, thank you :+1:
S16 SFT40
Great thank you. Are the new 3X21A flat top adapters (molding not CNC-made) ready for shipping yet? I would like to order two more flat top adapters each for 4X18A and 3X21A along with my next order (S16 with SFT40).
How do you think about FC40 in S16? If it works in S11 I feel confident it would work very nicely in S16, too. :)
26800 tube
Thanks Simon they look great
yes ,new adapter now ,
i dont have reflector for S16 FC40 ,
M21B FC40 will available in two days
Great. I will wait for M21B FC40 to become available and then get back to you via PM.
You got me, I just ordered 5 of them 26800 extensions. Those 26mm PCB board for series connection, please consider 21mm and 18mm sizes.
ok,i will produce some
when to expect 26800 extensions for S11?
So i’ve got Nichia B35AM 5000K R9080 and installed iz in S21B.
AMAZING BEAM!
But it get’s realy hot on 100% so i’ll go with 3A driver instead of 4A (22mm single cell boost)
Best high CRI emitter right there. I did a quick color test of a 3500k B35A, good tint, great beam uniformity, great color rendering with very slightly oversaturated reds (good).
Simon could you look into sourcing it ? You already have several boost drivers (6V) suitable for it, the only downside of this LED is the footprint as it doesn’t have a neutral thermal pad, it requires a new MCPCB and the dielectric thermal conductivity/thickness plays a big role in the MCPCB’s performance.
edit : Actually you already have an MCPCB compatible with it : 16mm copper MCPCB for nichia 276A
Both use the same land patern :
B35AM datasheet
276A datacheeet
Awesome test the freeman.
Although Convoy is using thick AR coated lenses, this emitter just stayed at BBL and with ton of lumens.
Yeah i think those Nichia 276 MCPCB are good for it!
