ThruNite Catapult Mini
14 posts / 0 new
UrbanSurvivor
Last seen: 2 weeks 5 days ago
Wanted to share a quick review with some beamshots of the new Catapult Mini.
Here are a few more specs!
LED: OSRAM KW. CSLNM1.TG
Reflector: PMMA TIR
Body Material: T6061-T6
Surface Finish: Premium Type HAIII
Water Resistance: IPX-8 ( 2m)
Impact Resistance: 1.5 meter
Battery: 1100mAh 3.7v 18350 (included)
Charging : USB-C
Weight : 115.4 g / 4.07 oz ( w/ battery)
Dimensions: 80.98mm/ 3.19in x 40mm/ 1.59”
Max Output: 680 lumens
Max Runtime: 106 Hours ( 0.5 lumens low)
Distance : 598 meters ( Max)
Intensity: 89,600cd ( Max)
Edited by: UrbanSurvivor on 07/29/2021 - 11:17
desmondkun
Last seen: 1 day 13 hours ago
An error occured. Please, try again later
Take care of your flashlight and your flashlight will take care of you.
UrbanSurvivor
Thanks for letting me know, it should be working now.
defloyd77
Last seen: 5 days 8 hours ago
Can you see much of a difference between firefly and low mode? I just received my Mini today and there doesn’t seem to be any difference between the two levels, firefly looks way too bright for .5 lumens.
TIFisher
Last seen: 10 hours 15 min ago
Good review, and impressive little thrower. The recessed lanyard attachment is pure genius IMO. My number one complaint about most budget light designs are the tail cap profiles and lanyard cutouts or dimple profiles. I absolutely despise scalloped caps and roughly milled dimple holes on short barreled lights (to include standard 18650/21700/26650 single cell tubes). Thrunite really nails it here.
If I didn’t already have an overabundance of NM1 lights, I’d be all over this. Still might as I’m intrigued by the TIR optic.
Any idea how this compares to the Manker MC13?
djozz
djozz's picture
Last seen: 8 min 40 sec ago
Thanks for the review, I like these reviews that are not too long.
The Catapult Mini looks nice and useful but the throw is IMO not “incredible” (as you mention) even for its size, TIR lights never are, using the same led in a similar size reflector light gives you substantially more throw. I do like TIR flashlights though, they have in my opinion a great beam with the perfect ratio between spot and spill.
Lightbringer
Lightbringer's picture
Last seen: 1 hour 58 min ago
Were those 2 skunks at about the 2½ min mark? LOL
defloyd77
I just got a response from Thrunite
“loose the tailcap first, and then long-press the switch while screwing down the tailcap again, and then you could find the firefly mode, slowly single press the switch to choose the lumens of the firefly mode that you like, when you find the brightness you like, double click the switch to confirm, and then single click to turn off the flashlight.”
It worked and wow, there are a lot of firefly output options!
woodyt
Well done thank you
NorthernHarrier
NorthernHarrier's picture
Last seen: 2 days 14 hours ago
Does anyone know if it’s possible to use a battery with this light that doesn’t have the proprietary plastic circular wall around the button?
"However vast the darkness, we must supply our own light." - Stanley Kubrick
Bob_McBob
Last seen: 14 hours 11 min ago
According to Zeroair the proprietary cell isn’t required and it works perfectly fine with regular flat top unprotected cells.
https://zeroair.org/2021/07/15/thrunite-catapult-mini-flashlight-review/
NorthernHarrier
Thanks for the info! Thumbs Up I didn’t see that comment online.
xevious
xevious's picture
Last seen: 2 hours 37 min ago
ZeroAir complained that the Catapult Mini charged the battery to 4.25v… anyone else have a slight overcharging problem like this with their Catapult Mini?
Hank33
Hank33's picture
Last seen: 4 hours 36 min ago
Nice and I’m interested in smaller lights these days. Ones that take 14500 or smaller batteries. Hmmm, might have to grab this one.
