Portable 12v electric air pump for tires... Any gems out there under $50?
Yay!
Thanks for you detailed feedback.
I dont mind specifying the inflation target, dont need a preset for basketballs, bikes, and cars.
I have the same pump ordered.
when you pumped for 90 seconds, how many total PSI did that deliver. (I dont know what your target PSI is for your tires…)
You’re welcome. I mentioned that I lowered my tire to 10 psi below its normal pressure, so that was the amount I inflated in about 90 seconds. But I’ve tested it again just to be sure, timed it with a stopwatch. My car tire pressure went from 26 PSI to 36 PSI in exactly 100 seconds. Body of pump barely got warm. Braided hose was fairly warm. Nothing hot.
excellent data
when my unit arrives I will do that test Four Times in a row, as that would be my actual intended use case scenario.
If the new pump can handle that task, it will let me reduce Cargo by removing the much larger and heavier Viair kit, that includes a loooong airhose, plus battery clamp wiring, and requires running the motor.
the new tech battery powered pumps have auto shut off… thats a big plus
not having to run the car motor is also a big plus for me
There is a $10 off coupon right now, so $29.99.
^ It’s a very good value considering what else is out there and respective pricing.
Yeah, for my previous corded air pump, I’d have to use a 12V socket in the armrest console, hit front/back of one side, then pass the pump through the cabin to the other side to do the other two. VERY nice not having to deal with a cord, and… if by some chance the battery is low, the 12V power cord is a fantastic backup. The other thing is, the backlit LCD is so very visible in any light. Frankly, the engineer who designed the previous air pump we tried (silver cylindrical shape with LED display) should’ve suffered a reduction in pay for that hugely glaring mistake. Obviously no one did any real world testing of the pump before putting into full production.
I just got the same pump and tested it
dropped a tire by 15 psi and pumped it back up. Did not time it.
My handheld tire pressure gauge said the tire was at 40psi and I dropped it to 25psi… the airpump said that was 18psi.
I then set the pump to stop at 36psi, it stopped at 36.5, and that measured 43psi on my tire gauge… the gauge on the tire inflator reads low by 7psi…
likes
the pump is rather quiet
the hose is long enough to easily reach the tire valve
the unit stands stable on the ground
the auto stop works great
love the battery operated feature, super convenient not to run power cords and not to run the motor.
there is a lighter cord coiled into the bottom of the unit and the hose also fits in that gap… convenient storage.
room for improvement:
the pressure gauge in the unit reads 7 psi low
the hose got hot after 15psi, and battery dropped to 1bar
When I did the test I had not fully charged the battery, though it was at 4 bars.
Immediately after the test it had dropped to 1 bar and a few minutes later it had rebounded to 2 bars.
Although I has originally considered doing a total of 40psi inflation test, I did not contiue the test after 15psi, to avoid overheating and overdischarge… I waited 1 hour for the unit to cool down, then plugged in to charge
Im not sure it is realistic to expect this little pump to put out a total of 40psi, without a recharge or at least a cooling break.
I like it and want to keep it, just for the convenience of adjusting my tires by 5psi, if not 10.
Am wondering if I should ask for a replacement with a more accurate PSI gauge?
@xevious is your tire pump PSI meter reasonably accurate?
Please note that you need to fully charge the battery fully before using.
I think there may be a “recalibration” necessary for the charge indicator by fully charging. When I got mine it was showing 3 bars. It took 8 hours to achieve the 4th bar. The whole pump shouldn’t take more than 10 hours to charge from depleted. In any case, I used my pump a few times now. Still showing 4 bars.
As for accuracy, mine tends to show 1 ~ 2 PSI above actual. It does this pretty consistently. So when I pump, I just add a couple PSI for good measure. I normally do this anyway with other pumps as I know detaching and manually checking air levels can lose about 1 PSI.
I would be unhappy with a full 7 PSI off. That’s too much. I’d see about a replacement. You might want to try your luck at ordering a 2nd one, then if it’s more accurate, just return the previous one.
Just an alternative… If you’re primarily topping off tires on sedans or motorcycles, a high quality bicycle pump is pretty quick and doesn’t have much to break.
I’m not talking about the Wmt special pump, I’m talking about the large, relatively expensive pumps by specialty brands that are meant to put high pressure into those road race bikes. I had two (can’t find one after moving twice), and the one I didn’t misplace is still going strong after 20 some years. If I remember tomorrow I’ll check the brand name of the one I still have/use.
I don’t recommend them for truck tires, but for tires on sedans it takes me about 10 pumps for 1 psi. when I’m going from 27 to 33 psi. Even quicker on motorcycle tires.
I did try one that I bought at Wmt (I think it was a Schwinn), and I gave it away after trying it on one tire it was so bad.
That reminds me… I do have a mini bicycle tire pump stashed in my spare wheel well. It’s just in case my main pump is missing or non-functional. Can do the job while also providing good exercise.
I just received a second Avid Cube pump.
The inflation pressure gauge reads 34.5
My first Avid Cube pump is almost identical, it reads 35psi
my handheld tire pressure gauge reads 41psi
It did take many hours to fully charge the first Avid pump… Im returning the second one.
At some point I will go test the Avid pump im keeping, and will find out if it is capable of airing up 4 tires by 10 psi each, without overheating.
thanks to all who contributed, to help spend money… lol
and for sharing your experiences
Sorry to hear of the disappointment. Interesting how the askew reading is consistent among 1st & 2nd purchases. I guess with these things, there’s a lot of “luck of the draw.” At least Amazon has unencumbered return processes. I’ll try putting mine through more challenging paces and see how it handles the load, then report back.
Frankly, for the price paid it’s not bad. But I would’ve paid double for the same air pump (design/size/performance) with more robust build quality, weight, and warranty.
its all good
I dont expect perfection from a cheap plastic pump
I think the only warranty is if it fails in the first 30 days… I can return it
so it is important to me, to do a thorough test promptly… just to know if it can handle pumping 40 psi total, in one sitting, without melting… LOL
update
I went softroading, dropped tire pressure by 13psi, and had a great time.
I used the Avid Cube inflator, on battery power to air up 3 of the tires. They took about 4 minutes each. The battery was showing 1 bar remaining. I decided to use the cig lighter cord for the last tire (with car motor running). It also worked great.
It was 60F outside, and the pump did not feel like it was overheated. Im quite impressed and happy to own the unit.
There were a couple of glitches.
  1. The unit kept shutting off after a couple of seconds. I learned that was caused by my failure to push the pump conne ction far enought onto the tire valve stem.
3. On the 3rd tire, the hose blew off the valve stem clamp on the pump. This started blowing the air out of the tire really fast. But, I was there watching.
Managed to push the air hose back onto the fitting, and completed inflating the 3rd and 4th tires without drama.
When I got home, I plugged the airpump into its charging cord and it took about 6 hours for the charge indicator to turn green.
Im keeping the little Avid Cube pump…
Recommended
^ Thanks for the update, Jonathan. I haven’t had any mounting issues with mine. Clamping onto the value works well, doesn’t pop off. I still find the clamp is a little cheap feeling, but hopefully it’ll hold up for the long haul.
I deflated each of the 4 tires I have by around 12 PSI. After the inflating the 2nd tire, the pump started to feel a bit warm, the air hose a little hot near the entry point into the pump. By that point, it was showing 3 bars. Inflating the 3rd tire showed 2 bars and the pump got warmer. A few moments after it was done, the power level went back up to 3 bars. I went right to the 4th tire, no waiting, and about 50% of inflation, the pump did an auto shut-off. The air hose near the exit of the pump was really hot, almost too much to continue touching for a few seconds. I waited 5 mins, then continued pumping. It finished no problem. 2 bars.
I did notice that as the pump got warmer, it became less accurate in showing PSI. Whereas when cool it showed more PSI than actual, gradually as it got warmer it became parity, and then started showing fewer PSI than actual… by about 3 PSI.
So overall, I felt good about the experiment. Given the duty I just put it through, It was comforting to see that it still had 2 bars of power left.
Stupid me, I forgot to bring with me the power cord for recharging it. Annoying that it doesn’t have a USB-C connector. Well, at least the 12V cigarette lighter socket cord can be used in a pinch for inflation. Pity that it doesn’t have a mode whereby you can utilize the 12V for recharging.
yes, car charging would be good
I have not tried but my guess is the USB charger cord would work in a car USB also…
but it takes a really long time…
fwiw, it was not the air hose clamp that blew off the tire valve, that stayed on… it was the actual hose that blew off the clamp… which meant the tire was blowing out all the air I had just pumped in… really fast
but I still really like the pump
this morning I used it to just match up a couple tires by a couple of psi… really easy and convenient :+1:
Whoa… so where the hose mates to the valve clamp—it came right off? How hard was it to reattach it?
This post when it came out got me interested in one. So I’ve been reading Amazon reviews a day here and there for the last week or so. What I get so far is…. “Got so hot, burned my finger”, “Can’t even blow up a soccer ball”, “Took forever to go from 28-32psi, “Shrader valve fell off” etc. So I guess I’ll keep reading till I find a good decent one. :smiley:
correct
the rubber hose slid back onto a hollow tube about 1/2” long that sticks out of the shiny metal part of the clamp.
it was easy, and did not come off again… even though there is no glue and no clamp, just a metal tube pushed inside the rubber hose…
btw, I live at 7000 feet, I wonder if that might be the reason the gauges in the pump read 5-7 psi low… I dont mind… I just ask for 32 psi when I want 37
I have not posted a review on Amazon, I dont usually think about doing that. (maybe I should?)
imo this thread is more honest, more thorough, and more useful than Amazon reviews…
also bear in mind these pumps have a 10 minute duty cycle,
it is normal for a pump to get hot,
especially when exceeding the duty cycle like xevious and I have been doing…
ambient temperature also affects how hot the piston and hose connection get
pumping at 90F is more challenging, heatwise, than pumping at 60F
realistically, these pumps are intended to pump up One low tire, in order to get to a repair shop… they work great for that… it only takes about 4 minutes to add 15 psi…
the unit is small, light, good tactile buttons, clear PSI display, shuts off automatically when it reaches set pressure, works on its own internal battery, plus cig lighter socket… and $10 off
whats not to like? :wink:
Actually, this intrigues me. Looks like it should be possible to replace the clamp part then. Install a superior one or even one with a screw threaded end.
maybe, but I actually like the clamp, because it protects my aluminium valve stem threads
my Viair pump uses screw on hose,
and I have to be careful not to damage my valve stem threads…
