https://www.amazon.com/sofirn-Flashlight-Rechargeable-Charging-Batteries/dp/B099WWTW33/
We have a link! Code please for the Sofirn Q8 Pro.
How long will the Q8 Pro run at max output before stepping down? And how many lumens does it step down to?
Code for the Q8Pro please.
Iām sorry, Iāve changed into the valid link. Do you need a code?
:laughing: PM sent!
PM sent! Thank you!
The link works now but I need a code. Thanks Sofirn
Switch OFF state, double-click to the maximum brightness, it can maintain at least 10 minutes.
Yes, the code has been sent to your message!
Sent request for code in PM.
Thank you.
Hi, itās $23.99 with the battery on our website.
How is that a good deal? The SC21 is $21 on your own web site.
I would a q8 pro code!
PM sentļ¼Thank you!
PM sentļ¼Thank you!
habeba86:I would a q8 pro code!
Thank you!
Rexlion:How long will the Q8 Pro run at max output before stepping down? And how many lumens does it step down to?
How is this possible? I just received mine and turbo lasts about 25 seconds and then after 2 minutes max the light has dropped down to so dim its pretty much unusable.
Edit- Switched to advanced UI and run time seemed substantially better. Ill calibrate now and should be good.
Would love to see this model using the SFT-40
Sofirn:Switch OFF state, double-click to the maximum brightness, it can maintain at least 10 minutes.
I am interested in getting this light. Did you fully charged your batteries? With 11000 lumen, it will be pulling a lot of current.
Yes just topped off with my miboxer. I switched to advanced ui and turbo seemed substantially longer. Ill check it out tomorrow and then calibrate and redo. I have no idea if switching ui should do anything but it seemed to.
Edit. Did recalibrate and change step down temp and it holds turbo significantly longer.
Requesting Q8 Pro code please. Thanks!
