Lumintop GT Mini/Micro NM1 - current readings ??
5 posts / 0 new
TIFisher
Last seen: 1 day 1 hour ago
Does this make sense???…….
I have both mini and micro in Osram CSLNM1.TG, and took them out the other night to do an informal throw comparison. For reasons that escaped me, the micro (Lumintop 14500 “High drain” cell) actually seemed not only brighter, but more intense in throw than the mini (18650 Samsung 30Q). Both cells were fully charged. Today I pulled out the DMM and measured current draw on turbo for both (same cells as described). The micro drew 2.600 Amps, while mini was only pulling 1.878 Amps (???)!!
I’m kinda stumped here, and a little disappointed the mini doesn’t appear (to the nekkid eye) to be giving the increase in performance over the micro I would have expected (seemingly worse even). Any ideas why this would be the case?
ArtieT59
ArtieT59's picture
Last seen: 3 hours 34 min ago
I’m interested too, bc I’m considering buying one of them
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
Aalsen
Last seen: 9 months 3 weeks ago
That is weird. Matt Smith does a comparison with the mini and micro on youtube, and the mini seem brighter than the micro.
d_t_a
Last seen: 1 day 12 hours ago
I just got a GT Mini NM1 the other day.
Doing current measurement, it appears that by default, the ramp ceiling level uses around 2.4A, while Turbo uses around 2.8A max, which explains why there’s very little difference from Ramp Ceiling to Turbo mode.
(strangely, the manual included for the GT Mini NM1 indicates that GT Mini (CSLNM1) is up to 3.8A <= I only got 2.8 Amps max, so brightness is not that bright (compared to Convoy C8+ Osram NM1 which I measure to be around 4.4 Amps) GT Mini (XPL-Hi) is up to 4.5A GT Mini Pro (XHP50.2) is up to 9A
Other notes: – GT Mini NM1 uses Anduril 1, it has factory reset function, and also does 15-clicks Anduril version check… BUT this appears to be a modified Anduril, since the version check blinks out a bogus date-code.. (version blinks out 1969-07-02).
Video below shows the Anduril version check date code result for the GT Mini NM1
mattlward
mattlward's picture
Last seen: 16 min 12 sec ago
The output could be limited in the FW. It would be a bear to do, but maybe reflash with a stock version and see if it changes?
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
