Interesting opinion. I'd settle for Narsilm. Both firmwares have great options in them as well as functional features. It'd be nice to buy those directly from Simon either in complete lights or as spare drivers. I could do without a lot of the extra/fun additions to the firmware but the core features are fantastic and being able to more fully customize to your liking is great. And not having to click 20 times....
Hi Simon,
Is it possible to get a black metal switch (the one that comes in the TAN color) in a red or orange S2+ instead of the silver one?
Thank you!
ok ,i will add a link later
yes,it’s in design,
Ryzbor:Hopefully none since Simon makes lights that are tools and not toys with a fancy gimmick ui.
Interesting opinion. I’d settle for Narsilm. Both firmwares have great options in them as well as functional features. It’d be nice to buy those directly from Simon either in complete lights or as spare drivers. I could do without a lot of the extra/fun additions to the firmware but the core features are fantastic and being able to more fully customize to your liking is great. And not having to click 20 times….
Friends of BLF don’t get me wrong, I did not reject Anduril, I need to spend time communicating with the driver manufacturer. This will mainly involve the compatibility of components.
An interesting phenomenon is that on the Chinese flashlight tieba, many users hate Anduril, they think the function is too complicated.
Hi Simon,
Thank you!
yes, i can change it ,pls note this in the remarks of your order
Alen: Simon Mao: ch1ir:Yes, I appreciate the work and effort you do for us Simon
I have a question?, may I reserve a s21c tint mix or do you think you have enough 219b’s to last until the design is complete
I tried to design S21C on the basis of S21B, but the appearance is ugly. Now S21C is slightly modified on the basis of S12. S21C is the basic version of multi-lens flashlight. In the future, I will launch S21D with direct charging function, or more Functional S21E….
Simon these 219B will be spetacular on triple Tir and even on quad version with adjustable temperature despite the small CCT range,please consider to put some aside for this scope,or are you able to get 219b 2700k? Wish triple will came with features like ramp driver,direct access moon/turbo and memory mode removable at choice
yes,it’s in design,
Simon, I just saw the s12 triple is available in 219b in aliexpress . When I go to order, how to I explain I want a tint mix of sw30, sw35, and sw45? THANK YOU!!!
You want one of each?
Dude, this is SMO reflector and not TIR.
I have S12 with 219B 3500K for a year now and it shows clearly where’s which emitter. Frosting lens might help you
ch1ir:Simon, I just saw the s12 triple is available in 219b in aliexpress . When I go to order, how to I explain I want a tint mix of sw30, sw35, and sw45? THANK YOU!!!
Yes, I want to mix the emitters, I have DC fix if the beam looks goofy!
id30209: ch1ir:Simon, I just saw the s12 triple is available in 219b in aliexpress . When I go to order, how to I explain I want a tint mix of sw30, sw35, and sw45? THANK YOU!!!
Simon should offer a frosted lens as an option then this light would be a no brainer for me. :+1:
Maybe he does, Simon, do you offer a OP triple reflector?
Correllux: Ryzbor:Hopefully none since Simon makes lights that are tools and not toys with a fancy gimmick ui.
Interesting opinion. I’d settle for Narsilm. Both firmwares have great options in them as well as functional features. It’d be nice to buy those directly from Simon either in complete lights or as spare drivers. I could do without a lot of the extra/fun additions to the firmware but the core features are fantastic and being able to more fully customize to your liking is great. And not having to click 20 times….Friends of BLF don’t get me wrong, I did not reject Anduril, I need to spend time communicating with the driver manufacturer. This will mainly involve the compatibility of components.
Simple… D4v2… simple …
Using DC-Fix solves it eventually! No need to produce a frosted glass lens, I guess.
Maybe he does, Simon, do you offer a OP triple lens?
OP triple lens? OP triple reflector, eventually, but not a lens. A glass lens can be clear or “frosted” (for the cases in discussion). An optic may be clear, frosted, single, triple, quad, multiple.
2-26350-P91:Simon should offer a frosted lens as an option then this light would be a no brainer for me. :+1:
ch1ir:Maybe he does, Simon, do you offer a OP triple lens?
Yes I’m sorry I totally meant reflector, I was at work and in a hurry, I corrected it
No problem My brain detected something there so I felt the need to clarify
Is that Anduril in general or just the old version?
ToyKeeper redesigned the UI in Anduril 2 to address the complicated operation.
Guys, see what I got? I received 50 SFT70
Simon Mao: Alen: Simon Mao: ch1ir:Yes, I appreciate the work and effort you do for us Simon
yes,it’s in design,
i dont recommend ,it’s reflector inside.
It will not mix the light evenly like a TIR lens
i have frosted lens sample before,
The luminous flux will suffer a great loss.
2-26350-P91: id30209: ch1ir:Simon, I just saw the s12 triple is available in 219b in aliexpress . When I go to order, how to I explain I want a tint mix of sw30, sw35, and sw45? THANK YOU!!!
Even with OP reflector, the effect is not up to expectations. I still recommend TIR LENS
