Nobody had taken a flashlight and water cooled it. There were water cooled lights but none were flashlights. So I thought it would be a challenge to try. It took some time drawing things on cad, changing direction and modifying while building it.
There are still problems too with water loss over time. Guess it is evaporating thru the silicon tubing or the water pump.
I just drain it until it’s time to use it again.
The copper cooler is the heart of the light.
Used an aquarium submersible water pump and aluminum tubing for a radiator.
At one time during development, it was just plain ugly.
But pretty bright, even during the daytime.
In the end, its fun doing the unusual stuff, not to show off, but to pass on ideas or examples of what can be done by applying ” Thinking outside the Box “.
I appreciate that you are trying things outside the norm, great idea! Now maybe a liquid nitrogen one? So you don’t need a radiator or pump or tubing? Maybe a short tube the size of a battery put in the instead of one battery to really cool things down? Or a couple of them in the battery space with a belt worn battery pack with a cable hook up to the flashlight body to power it? I guess the skies the limit!
Thanks for listening, Dave……
Welcome to BLF! Sofirn has some good stuff
Discount codes are entered at checkout, before you pay. Make sure you do not click “buy it now” but go to your checkout/cart payment screen once you have placed the items in your amazon cart and have logged in to your account, but havent yet paid. At that point there should be a box on the screen to enter discount code(s)
Thank you azj for enlightening me. I have never noticed the box for discounts but I’m going to try it now!
May your flashlights be bright,
Dave……
Sorry azj but it didn’t work. I couldn’t find a box or an option to put the discount code in. I took a screen shot but I don’t know how to add the screen shot to my post.
Dave….
Okay I read the super fine print at the bottom of the upper paragraph under the loaded cart and here is the phrase: “Do you have a gift card or promotional code? We’ll ask you to enter your claim code when it’s time to pay.” I didn’t realize I had to click the gift card check box to enter. I was looking just for the promotional box. My bad………
Dave………
Thank you azj, that worked! It’s on the check out screen. Now for my other problem, I was so pissed off I threw out the other numbers that sofirn sent me for two other lights. Is there anyway to retrieve those on this website? They sent them to me on this site?
Thanks,
Dave……
Okay, I figured out how to retrieve my codes. Boy, I’m a mess.
Dave……
Hi! You will quickly find out there’s a light for everything. Check out 1Lumen.com for guides and reviews for choosing the right ones. You will also find out you can never have just one
Sirstinky, well I have bought 6 in less than a week, so I think your right about never having just one! Now I need to find the perfect keychain light for both me and my wife. I’ve been looking at the Rovyvon Aurora line and I’m kinda leaning towards either the 8 or 9 series. Any thoughts on any keychain lights?
I forgot, I also like the Astrolux K2.
And the Xtar T1
The D18 requires cells with protruding (+) contacts on the cells.
I’d recommend Sanyo UR18650NSX, but they are sold out everywhere I looked domestically. They are a great high power cell with a slightly raised (+) pole so they work in lights that require “button tops”. The benefit here is that there is no added resistance or cost associated with ‘button tops’, however minimal. I would stay in the 2.5Ah class of cells, personally, but many run 30Qs and they would do you just fine as well. The Samsung 30Q is the all-around champ, so you can’t go wrong with them.
Thanks JaredM for checking on me, When I ordered from Hank I asked him about the batteries and he emailed me with his recommendation “Samsung 30Q BUTTON TOP | 18650 Samsung 3000mAh INR18650-30Q High Discharge Button Top” so that’s what I bought. I just received them today, along with these “K40 | 21700 Vapcell INR21700 K40 4000mAh 30A High Discharge Flat Top” for my Astrolux EC03. I hope those are good enough for the Astrolux?
Thanks,
Dave….
I’ve lost trust in Vapcell recently and haven’t kept up with all of their cell code names. I stick to buying non-rewrapped cells whenever possible. Research those here and see if they have any reports of low voltage and self-discharge. I’d check all of them with a volt meter before first charge. If below 3.6V I’d be suspect of them, below 3.3 and I’d file a refund request but maybe still try them out, below 3 V just forget about using it.
Vapcell used to be a top-tier supplier, but since C19 induced shortages, they’ve started using new chinese cell suppliers that haven’t all worked out.
Thanks Jared, I’ll get out the old Fluke and test them all. So far I picked up the Emisar D18, Sofirn Q8 Pro, the SC31 Pro [5000K], the SC31 Pro [6500K], the SC21, also the Astrolux EC03. Just getting started.
Dave
I don’t know anything about those but I’ll hang out here and read the threads and eventually know what I’m not doing?
Dave…
I’d love to see comparisons between the D18 and Q8 pro! I think at first you might prefer the wow factor of the Q8, but in time (especially if you post pictures of outdoor scenery/foliage) you’ll see how any lumen advantage of the CW Cree emitters will lose their luster to the smile inducing quality of the 219B
EDIT: what color body did you choose for the D18?
The vapcells are 3.527 and 3.528. All the Samsungs are 3.44 with change.
Strangely the Samsung’s, every one of them [8] are 3.448. That’s too weird.
