I think this is mainly caused by the arrangement of the chips.
It reminds me of CREE MCE
no problem to produce 1800-2000K LED ,but the voltage is 12V
I think there is no need to worry.
For new suggestions, my idea is not “reject” or “accept”, but “small production” or “mass production”
Sari33:Simon,can GT FC40 manufacture made 1800k~2000k Led high Cri 3535 and 5050 size at 3V?
Can’t find these CCT at 3V in high Cri and standard sizes.Let me know if you find others source
I would use them on small host, maybe the boost driver is too large
Found this
S15?
Simon....when you're not busy...:)
Can you find a better spring solution for the M3 light? I think others have noticed it also but with the single spring in the tail it just isn't strong enough to keep the weight of the 26650 cells in contact with the brass button on the driver when set down on the tail, so the light cuts out. I notice with mine that if I'm on moonlight and set it down gently, it will cut out and actually shut off the light. On any normal/higher mode it will blink but not shut off. I've tried stretching the spring but of course that wasn't enough. It seems like at the base of the spring coils there is about 2-3mm of space that the spring will lower into as weight is put upon it, reducing the spring length maybe extra than was designed? But with the brass button on the driver instead of a spring, there is no give/support for when the battery moves in the tube. The spring quality is excellent, maybe just needs to be longer or made of thicker wire? Someone posted a photo here where they cut a small piece of rubber tubing to put below the spring to limit its travel/compression but that seems less than ideal solution. It's a minor but important small defect in an otherwise wonderful flashlight design.
And what's this S15 photo...?!! I like that.
Looks like a redesigned and slightly beefier version of the s2+, not sure if it’s legit and made by Simon.
I found it here .
S15?
Ah…looks like TIR S2+ with redesigned body
TIR? Looks like a standard SMO reflector to me.
More shots of this ‘S15’. I’ve never heard of this model. Is it a knock-off? Prototype? Really old stock?
Simon, can you comment on this?
From the Shopee listings it comes in SST20 but only 5000K or 6500K. Roughly $12 converted to USD.
id30209:Ah…looks like TIR S2+ with redesigned body
Possible…i’m on the phone
seems to be with pill.For single emitters I prefer the design of the Blf A6 where it’s very easy and quick change lenses
Simon shows the optics for his upcoming quad - the S21c
photo and info credit: u/kanakana2
u/kanakana2 says: “According to Simon on FB, the host is still in production, 2 months out”
Simon Mao: Sari33:Simon,can GT FC40 manufacture made 1800k~2000k Led high Cri 3535 and 5050 size at 3V?
what’s max input current?
Simon….when you’re not busy…
Can you find a better spring solution for the M3 light? I think others have noticed it also but with the single spring in the tail it just isn’t strong enough to keep the weight of the 26650 cells in contact with the brass button on the driver when set down on the tail, so the light cuts out. I notice with mine that if I’m on moonlight and set it down gently, it will cut out and actually shut off the light. On any normal/higher mode it will blink but not shut off. I’ve tried stretching the spring but of course that wasn’t enough. It seems like at the base of the spring coils there is about 2-3mm of space that the spring will lower into as weight is put upon it, reducing the spring length maybe extra than was designed? But with the brass button on the driver instead of a spring, there is no give/support for when the battery moves in the tube. The spring quality is excellent, maybe just needs to be longer or made of thicker wire? Someone posted a photo here where they cut a small piece of rubber tubing to put below the spring to limit its travel/compression but that seems less than ideal solution. It’s a minor but important small defect in an otherwise wonderful flashlight design.
And what’s this S15 photo…?!! I like that.
i asked the factory to shorten the middle tube of flashlight ,it will be changed in the futurn ,
currently Users can use 26mm board to fill the gap
As a low-cost flashlight, S15 is only used for my salesperson to sell on shopee LAZADA
Yes ,you found it
At the same time, I plan to launch a S21A SST20 flashlight, the price will be low, suitable for ordinary users.
Sari33: Simon Mao: Sari33:Simon,can GT FC40 manufacture made 1800k~2000k Led high Cri 3535 and 5050 size at 3V?
I would use them on small host, maybe the boost driver is too largewhat’s max input current?
2.5~3 Ampere would be enought with Duv below BBL at very low current
