Unno. Only guess might be its acidity vs other stuff, maybe mold prefers a low pH.
That’s why when I had that opened can of tomatoes, I had to use ’em up quick, so made that shukshaka or shakazulu or whatever it’s called.
Yeah, I just tossed out an unopened package of romaine. I thought the bags had little holes in ’em like potatoes, but nope, sealed. Brown soup at the bottom from pent-up water.
Mentioned that I had an unopened bag when I got 2 more, was eating salad salad salad ’til I was sick of it. Got my bowl, got some dressing, go for the bag, and ewwww. Nope.
Was late, had 2 small ’taters from the old bag that I wanted to “use up”.
Could boil ’em and just salt ’em afterwards, fry ’em and add a dollop of sour cream, etc., but figured a onion would go nicely, and it did.
Didn’t want the ’taters to be underdone inside, so did my garlic trick and added a little water to steam/boil ’em. The starch from the ’taters, the last hints of water as it boiled out, and the original butter, made a sort of light creamy buttery “sauce” that I wasn’t expecting, but was really good.
Whole bulb of garlic, of course, so no vampyres should be haranguing me for a while.
Mooshed ’em in one of these Amazon.com courtesy of vipon (7fitty, pretty nice).
Leftover italian bread, so put it to good use. Not dry, yet not too greasy, just toasted enough to get flaky without burning the bread or overbrowning the garlic. Same water + butter trick in a frying pan to cook it through first.
Peeled the individual cloves (really old and sprouty ones pretty much come off when you look at ’em, but these I had to scrape the skins off with my nails and then rinse repeatedly to make sure all the “strings” came off), then dumped ’em in the pan with butter and fried ’em a bit, then added water to make sure they were cooked through, then waited for all the water to boil out and the butter would “fizz” under medium heat, then once boiled out with just garlic/butter left behind, I scooped that onto the bread.
Probably a bit more tedious than necessary, but it worked.
Yeh, pretty much exactly like in the pix. Once they get finely chopped, they get flung to the inside-wall. Thought I’d have to scrape ’em down to chop leftover chunks, but nope. The space between blade-tip and wall probably determines the size of the chunks and makes sure they don’t end up pureed into moosh.
I’ve yet to find a good EVOO, not that I really tried all that hard. Too many are “colored” with olive taste, like non-EV. I usually end up using it just to fry potatoes and onions and the like.
Just got it today, only et 2 individual balls so far.
Was dumped into a box, and it opened inside. When I heard them rattling around and felt the the weight of the box actually shift on tilting, I said, “Oh, this can’t be a good thing…”.
Same box pictured in the ad, but with a plastic sheet across the top and under the lid, which was busted open. First thought maybe someone in the factory opened it and grabbed a handful then just snapped the lid back on, but not really. Counted (yeah, I actually counted) something like 244 (vs 240 on the label).
Yep, just like I remember ’em. Start out sweet, then you get the burn for the next 80%, then back to sweet again. Was doing my best George Takei “Ohhhhhh myyyy!” when the burn started.
Can’t order from Amazon here as shipping is ridiculous and customs can be a problem but there are sellers on the local online shopping platform that import American candy so I’m keeping my eyes open. I made the mistake of telling my daughter about Atomic Fireballs and now she’s bugging me about them. If I make a special request then the price quadruples and I’m pretty chea…thrifty.
Those Jolly Rancher Fire Stix were OK, don’t know if they still make them.
Thanks for the link.
Edit: Just checked again and a seller has them on a preorder basis for $44.70 plus $35.81 shipping for the 4.05 lb tub. Nope.
