20mm or 22mm?
1) Convoy S11 (GT-FC40 3000-3200k) [left] vs Convoy S11 (GT-FC40 5000-5500k) [right]
2) Convoy S11 (GT-FC40 4000-4500k) [left] vs Convoy S11 (GT-FC40 5000-5500k) [right]
3) Convoy S11 (GT-FC40 3000-3200k) [left] vs Convoy S11 (GT-FC40 4000-4500k) [right]
4) Convoy S11 (GT-FC40 4000-4500k) vs Convoy S2+ (Nichia 219B SW45K R9080, 7135x8, SMO)
Wow, BOTH please
Simon Mao: id30209:Simon,
would it be possible to make Ramping driver but 6V/3-4A?
That could be solution for everybody that want specific output. Since it’s already avialable in 3V…20mm or 22mm?
Wow, BOTH please
The main reason I have not used ramping mode extensively is that it is more suitable for forward switch. But currently most of my flashlights use reverse switches, I don’t know if many users will mind it.
And I never used ramping driver...
I am using all kind of FW's: Bistro, H17Fx, Dragon, Crescendo, Guppy's and they all fit the reverse switch. The thing is in the operator, not the driver
Seems like there is 3x21A with SBT90.2 now.
Techno:My 219B S2+ 4500k just came in today. The LED is pretty nice.
The description for the 219B S2+ seems to be wrong. It’s the regular Biscotti, which requires 10 taps to go into config mode, not 20 taps.
And doesn’t work properly with the lighted switch. With the lighted switch installed, the light just stays in one mode and refuses to switch modes.
Sorry, I found that the old 7135*8 driver is still installed in some flashlights. Please PM me and tell me your address, and I will send you the new driver
Hi,
I don’t know how to solder, and don’t have the tools too. The old driver is OK on the first S2+ sw45k which was received.
Will let you know once the 2nd one arrives if it still has old driver. I ordered the lighted switch with 2nd light and was expecting it to work.
Hi,
With standard switch (without lighting) the old driver works well. Change the switch it’s very easy, only need a tweezers.
Just saw this on FB:
Convoy M21E 21700 flashlight ,type-c charging port,XHP70.2
Beautiful design!
Super stunning!
I can’t wait to get my hands on it!
Just saw this on FB: Convoy M21E 21700 flashlight ,type-c charging port,XHP70.2 30.19€ 13% OFF|Convoy M21E 21700 taschenlampe, typ c lade port,XHP 70,2 SST70 XHP 70,3 HALLO|Taschenlampen| - AliExpress !https://i.imgur.com/iMv8Ak2.png! !https://i.imgur.com/o39bTMD.png!
i see the driver area (around the button and charging port) is the same as astrolux FT03 or Mateminco.
gregor:Just saw this on FB: Convoy M21E 21700 flashlight ,type-c charging port,XHP70.2 30.19€ 13% OFF|Convoy M21E 21700 taschenlampe, typ c lade port,XHP 70,2 SST70 XHP 70,3 HALLO|Taschenlampen| - AliExpress
Impulsive as I am I just ordered one black/5000K. The stud instead of a spring with the short tail spring may cause some crushing on longer cells. I know driver area is limited and this method gives a little extra. Tail spring needs to reflect this as a bit longer. I have three other lights that have crushed the tops of cells. Haikelite HK4S was so bad I had to grind down the stud 4 mm’s just for unprotected cells.
The 4000k in the S11 is so darn nice. It really does compare very well to the 219B sw-4500k. My S11 seems to be a bit more rosy than the one shown above… But, that could just be the recording.
Pioneman K45-C…
I like the Pioneman K35 design. There are using Convoy drivers. Are we expecting a similar Pioneman K35 host with Convoy Name S???
Hmmm… Pioneman related to Convoy?
So are there any differences between the reflector in the M21C/D to the M21E?
Probably, the E looks like a C8 size head,44-45mm while c and d are 55mm
New convoy T3 !{width:70%}https://i.imgur.com/d3DKRJY.jpg! It is listed as a pre order at $999 with no specs “here”:11.6€ 30% OFF|Convoy T3 taschenlampe, hohe CRI, AA 14500 taschenlampe, XPG2 219B 219C LH351D 519A 13 gruppen|Taschenlampen| - AliExpress There is also a “s12”:30.43€ |Convoy S12 mit IR LED, infrarot 850nm 940nm|Taschenlampen| - AliExpress and a “s2+”:10.81€ 32% OFF|Convoy S2 + mit IR LED, infrarot 850nm 940nm 18650 taschenlampe|Taschenlampen| - AliExpress with IR emitters.
posted on facebook: Convoy T3, similar to T2 with 12 groups driver for AA/14500 battery
I hope it is a floodier/wider angle reflector than the one in the M21C, but we will have to see.
