Is It safe to use...?
22 posts / 0 new
Motardos
Last seen: 2 months 5 days ago
Hi all,
Newbie question… I have just received this Liitokala 21700 Lii-50E inside a Convoy S21A. I already have a few li-ion batteries and know they are hazardous and must be handled/used with care. So far all my batteries have arrived perfectly evenly flat but I am not an expert. Can I safely use it in my flashlights?
Hope some more experienced members here can share their opinions.
Cheap Li-ion batteries are not easy to get where I live by the way. Otherwise…
Thanks.
peg matite
peg matite's picture
Last seen: 15 hours 14 min ago
I would not use that cell.
pepinfaxera
Last seen: 1 min 37 sec ago
Liitokala is not to be trusted but I have several without any problem.
The problem I see with that is its appearance, a cover placed in a tacky way. “Chabacana”. Don’t use that battery
Liitokala is not a manufacturer of batteries, only a marketer and although it has items that go more or less well, others are quite far from …
By the way, there are several addresses to liitokala, suppose they are copycats who take advantage of the publicity of the name.
But that one with that aspect to know where it comes from.
Being from Spain you could make this consultation in:
Foro Linternas en Español
ForoLinternas, Registrarse
ForoLinternas, Cargadores y baterías
Sorry for my bad English
(google translator) , (https://www.deepl.com/translator)
SIGShooter
SIGShooter's picture
Last seen: 3 hours 53 min ago
If it was me I’d remove the wrapper to see if the cell body was damaged or if it was just a poor wrapping job. Afterwards if there’s any doubt then just get rid off it.
Onthebrightside
Onthebrightside's picture
Last seen: 1 week 4 days ago
At first I thought it was the wrapper but upon further inspection it appears the actual battery casing is damaged. I would put it in the bin personally. I would try to replace it with a new cell directly from the manufacturer of the cell and not one that is rewrapped. Not worth burning your house down IMHO. Hope this helps. Cheers.
Lightbringer
Lightbringer's picture
Last seen: 4 hours 41 min ago
Could just give it to someone you hate.
Henk4U2
Henk4U2's picture
Last seen: 3 hours 32 min ago
I would not use this cell. If this cell came IN a flashlight, it must have been damaged before putting it in. This looks like physical damage caused by a fall, or lying UNDER an object, like the bottom of a pile. Certainly NOT the result of carefull handling.
Contact the seller. You have a contract with the seller: you deliver good money, he delivers a good product.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
rngwn
rngwn's picture
Last seen: 5 days 18 hours ago
Should have smashed it with a rock or something. At least make it go out with a bang. tongue-out
(For obvious reasons, do it outdoors.)
Boaz
Boaz's picture
Last seen: 1 min 31 sec ago
 I would contact the seller ....get a new cell coming  and then cut the bad wrap off to see what's really going on .  It's gotta look worse than it really is .
freeme
freeme's picture
Last seen: 7 hours 53 min ago
Not safe to use. Please send in for proper battery disposable.
1thedeals.comyoutubeAstroluxNealsgadgetsolight
Oli
Last seen: 4 hours 19 min ago
More inspection would need to be done. Take the wrap off and see what those dents really look like. Inspect both ends and then make a decision. If I was on a deserted island and had no other choice I would use it but otherwise I would not. It’s hard to believe that somebody put a wrap over those dents. You did not say where you got the flashlight and or battery.
You can't compare the big flashlight in the sky to the little flashlight in your hand.
Lightbringer
Well, he kinda did (S21A), but dunno if that’s a legit come-with cell or if he got the light secondhand.
Oli
I don’t believe for a second that Simon shipped that out like that
Lightbringer
Hence the “secondhand” part. Seriously doubt Simon would let something like that get by him. Maybe a “reseller” or something, no idea.
zoulas
zoulas's picture
Last seen: 8 hours 41 min ago
Its dented, what more proof do you need? What difference does it make if it was dented and then wrapped vs dented after wrapped.
Do you think this car was dented then painted?
Oli
Some people are more curious than others. They want to understand how and why things failed. How things are put together. Some people talk and don’t really add anything to the conversation.
Motardos
Thank you all for your replies.
Following your advice I have already contacted the seller and will properly dispose of the battery.
I have little hope I can get a new one alone tbh. Getting Li-ion batteries by airship is not an option (dangerous goods restrictions) and living in an island does not help either.
That’s why I usually buy them as a bundle.
To be fair I must say I’ve bought a few flashlights with batteries from this Seller in the past and always received them all in perfect condition (not so the boxes) with an excellent customer service so no complaints at all till now.
For those of you asking about the hidden damage, I have removed the wrapper…
raccoon city
raccoon city's picture
Last seen: 7 hours 36 min ago
Yikes!
I would recycle that one.
sarge12
Last seen: 1 week 1 day ago
Nope…any dents in a li-ion battery gets chucked. The dent can easily result in an internal short and venting of the battery. It is just not worth the risk.
kennybobby
kennybobby's picture
Last seen: 5 hours 40 min ago
It looks like it spun loose in the holding fixture and a chuck jaw took a little bite.
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
snakebite
snakebite's picture
Last seen: 6 days 5 hours ago
QC FAIL!
discharge and recycle.
yesterday!
that was dented before wrapping.
Motardos
Update: Just to comment that after contacting the Seller he has honoured his good reputation and offered a battery replacement.
I will certainly keep on buying from his shop in future. His customer service is the best guarantee Thumbs Up
