sb56637
August 17, 2021, 1:49pm
207
Locking this thread for a while until tempers calm down.
freeme
(youtube.com/@1thedeals)
August 30, 2021, 3:30pm
209
Shared.
[quote=andy19x]
I'm interested!
[/quote]
freeme
August 30, 2021, 4:06pm
210
Initial bezel design is rather aggressive. Fortunately they listened to my advice to tone it down, else shredded pants and backpack stories would arise later.
TMaxxJJ:
So managed to do a quick test tonight. Was a bit tricky as I had to try and do 12m inside, and was struggling to read the meter at that distance, so I’m taking these with a pinch of salt. I got 1.95Mcd. Really need to try a further one outside with someone giving me a hand. Anything around 5 or 6 meters is just pointless with this light, it just whites out the whole area and blinds you! Also, this light uses the original LEP module with a mirror, so at shorter distances there’s a black hole in the middle of the beam. I wouldn’t be surprised if it’s still focusing at 12m. Took some quick comparison shots as well: !{width:50%}https://i.imgur.com/H1oQJ3i.jpg ! !{width:50%}https://i.imgur.com/nc2P5HA.jpg ! And the bezel makes this cool shot: !{width:50%}https://i.imgur.com/LWT03ui.jpg !
TMaxxJJ
(TMaxxJJ)
August 30, 2021, 5:53pm
211
I don’t mind it, I think it looks good!
Now this thread is unlocked again, I can share my findings. I thought this light just had high-low, but it actually has turbo, with a double click from on or off. Whilst playing with it inside I thought a double click just took it to high, and high and turbo are that intense I couldn’t tell the difference. So when I took my initial readings, I was only reading high. I’ve taken some more reading since and got the following:
Low - 619Kcd
High - 1.7Mcd
Turbo - 2.38Mcd!
All taken at 6m whilst wearing sunglasses! Haha
Still need to try and do some at around 20m when I get chance.
andy19x
(andy19x)
August 30, 2021, 6:44pm
212
TMaxxJJ:
Low - 619Kcd
High - 1.7Mcd
Turbo - 2.38Mcd!
That’s amazing! Can’t wait for your 20m measurements mate
freeme
August 30, 2021, 6:45pm
213
Over 3.08km? Quite impressive throw indeed. What about stepdown or tailcap amp reading?
TMaxxJJ:
I don’t mind it, I think it looks good! Now this thread is unlocked again, I can share my findings. I thought this light just had high-low, but it actually has turbo, with a double click from on or off. Whilst playing with it inside I thought a double click just took it to high, and high and turbo are that intense I couldn’t tell the difference. So when I took my initial readings, I was only reading high. I’ve taken some more reading since and got the following: Low - 619Kcd High - 1.7Mcd Turbo - 2.38Mcd! All taken at 6m whilst wearing sunglasses! Haha Still need to try and do some at around 20m when I get chance.
TMaxxJJ
(TMaxxJJ)
August 30, 2021, 8:19pm
214
I don’t have the equipment to do step down readings, but I did do some amp reading. I need some thicker gauge wire really, but this is what I got:
Low - 1.1A
High - 2.9A
Turbo - 3.6A
Have mine and it is very impressive! I wouldn’t change the bezel I think it looks excellent!
Forever
(Forever)
August 31, 2021, 12:25am
216
I’m interested. Can I still get in on the group buy?
Luigilot
(Luigilot)
August 31, 2021, 7:48pm
217
Mine was shipped 25.8. to Europe, probably the second batch?
lemma
(lemma)
September 1, 2021, 12:32am
218
Just got mine. Very happy with the quality. Thank you freeme. I cannot distinguish the high from the turbo at all, which is not surprising and not important since the differential is relatively small.
Theodore41
(Theodore41)
September 1, 2021, 5:38am
219
I have ordered one,thank you.
warzi1975
(warzi1975)
September 1, 2021, 11:02am
220
When you double click from low to turbo you can clearly see the difference between high and turbo.
Robert
freeme
September 1, 2021, 2:40pm
221
Theodore41
(Theodore41)
September 2, 2021, 2:58pm
222
I put a type c cable to charge the battery,but I hadn’t seen any green/red light to show if the battery is charging,or it is in low voltage stage.Is it OK?
freeme
September 2, 2021, 3:17pm
223
Is it USB Type-C to USB-A or Type-C to Type-C cable?
freeme
September 2, 2021, 5:08pm
225
Is the battery close to 4v? Try discharge the capacity by activating Turbo for a minute or two first?.
Theodore41:
Type C to type A.
Theodore41
(Theodore41)
September 2, 2021, 5:29pm
226
It was 3.6V,so I put the battery in a charger at 2.5A to charge it.
