TMaxxJJ
(TMaxxJJ)
August 30, 2021, 5:53pm
211
I don’t mind it, I think it looks good!
Now this thread is unlocked again, I can share my findings. I thought this light just had high-low, but it actually has turbo, with a double click from on or off. Whilst playing with it inside I thought a double click just took it to high, and high and turbo are that intense I couldn’t tell the difference. So when I took my initial readings, I was only reading high. I’ve taken some more reading since and got the following:
Low - 619Kcd
High - 1.7Mcd
Turbo - 2.38Mcd!
All taken at 6m whilst wearing sunglasses! Haha
Still need to try and do some at around 20m when I get chance.
andy19x
(andy19x)
August 30, 2021, 6:44pm
212
TMaxxJJ:
Low - 619Kcd
High - 1.7Mcd
Turbo - 2.38Mcd!
That’s amazing! Can’t wait for your 20m measurements mate
freeme
(youtube.com/@1thedeals)
August 30, 2021, 6:45pm
213
Over 3.08km? Quite impressive throw indeed. What about stepdown or tailcap amp reading?
TMaxxJJ:
I don’t mind it, I think it looks good! Now this thread is unlocked again, I can share my findings. I thought this light just had high-low, but it actually has turbo, with a double click from on or off. Whilst playing with it inside I thought a double click just took it to high, and high and turbo are that intense I couldn’t tell the difference. So when I took my initial readings, I was only reading high. I’ve taken some more reading since and got the following: Low - 619Kcd High - 1.7Mcd Turbo - 2.38Mcd! All taken at 6m whilst wearing sunglasses! Haha Still need to try and do some at around 20m when I get chance.
TMaxxJJ
(TMaxxJJ)
August 30, 2021, 8:19pm
214
I don’t have the equipment to do step down readings, but I did do some amp reading. I need some thicker gauge wire really, but this is what I got:
Low - 1.1A
High - 2.9A
Turbo - 3.6A
Have mine and it is very impressive! I wouldn’t change the bezel I think it looks excellent!
Forever
(Forever)
August 31, 2021, 12:25am
216
I’m interested. Can I still get in on the group buy?
Luigilot
(Luigilot)
August 31, 2021, 7:48pm
217
Mine was shipped 25.8. to Europe, probably the second batch?
lemma
(lemma)
September 1, 2021, 12:32am
218
Just got mine. Very happy with the quality. Thank you freeme. I cannot distinguish the high from the turbo at all, which is not surprising and not important since the differential is relatively small.
Theodore41
(Theodore41)
September 1, 2021, 5:38am
219
I have ordered one,thank you.
warzi1975
(warzi1975)
September 1, 2021, 11:02am
220
When you double click from low to turbo you can clearly see the difference between high and turbo.
Robert
freeme
September 1, 2021, 2:40pm
221
Theodore41
(Theodore41)
September 2, 2021, 2:58pm
222
I put a type c cable to charge the battery,but I hadn’t seen any green/red light to show if the battery is charging,or it is in low voltage stage.Is it OK?
freeme
September 2, 2021, 3:17pm
223
Is it USB Type-C to USB-A or Type-C to Type-C cable?
freeme
September 2, 2021, 5:08pm
225
Is the battery close to 4v? Try discharge the capacity by activating Turbo for a minute or two first?.
Theodore41:
Type C to type A.
Theodore41
(Theodore41)
September 2, 2021, 5:29pm
226
It was 3.6V,so I put the battery in a charger at 2.5A to charge it.
freeme
September 2, 2021, 5:36pm
227
By right it should work if inserted battery is 3.6V. It is better to identify the issue first. You might want to try different battery, cable, and input source?
Dydi92
(Dydi92)
September 2, 2021, 6:17pm
228
Trying to buy it from Banggood but none of the coupons available seem to be working, am i too late for the sale or is something up with the codes?
freeme
September 3, 2021, 9:19am
229
I have already replied your pm.
For those who received my earlier pm. Perform these steps to reveal our latest code:
hiyaside
(hiyaside)
September 4, 2021, 4:47am
230
Could I please have a group buy coupon code? Interested in this WP3 for the specs alone.
