How to keep twisties together in a pocket or purse?
22 posts / 0 new
slmjim
slmjim's picture
Last seen: 9 hours 6 min ago
Although not the exclusive domain of 1xAAA's, this may be an issue mostly affecting small twisties as a group.  Specifically, I'm asking about the Olight i3EOS, Sofirn C01s & it's variants. Likely other 1xAAA and 1xAA twisties I'm not familiar with.
The i3EOS on my wife's key ring came apart in my pocket.  Luckily, both the head and battery were still in my pocket but, I can see this happening in a less-secure environment where the head might be lost altogether.  The same thing can happen with the C01s and variants.
I placed a small piece of masking tape on her i3EOS that straddles the head & tube to prevent rotation.  Effective, but ugly.
I like to gift this kind of light, but would like also to reduce the risk of lights becoming useless due to not staying together in a muggle's pocket/purse because the head disappeared.
Does anyone have a suggestion on an elegant method to keep spontaneous pocket disassembly from occurring with twisties?
slmjim
Smile! It makes others wonder what you've been up to.
Time is more valuable than money.
You can get more money, but you cannot get more time.
Edited by: slmjim on 01/18/2021 - 10:56
jon_slider
jon_slider's picture
Last seen: 4 hours 42 min ago
never had it happen, but, if it did, I would reach for some sticky grease to use on threads and O ring
for example automotive dielectric grease is readily available and very inexpensive. aka bulb grease
Henk4U2
Henk4U2's picture
Last seen: 10 hours 12 min ago
1/ Thicker grease
2/ Thicker O-ring
3/ Squeeze (only!) one of the components (head or body) a tiny bit elliptical in a vise (grip pliers).
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
pennzy
pennzy's picture
Last seen: 15 hours 10 min ago
Same thing happens to my twisties. Teflon plumbers tape on the treads will add some resistance . Experiment with the amount. Doesn’t take more than about 2 turns.
Unheard
Unheard's picture
Last seen: 9 hours 16 min ago
My i3E has been on my keychain for years and this never happened. Obviously a different story when kept alone in a pocket. But then I’d say a twistie is not the right choice as teflon or a more viscous grease will make activating the light an unpleasant experience. If I were in your situation, I’d consider something like the amazing TINI2 or a light with a tailswitch that’s flush with the body, e.g. a Drop Tool.
Smile, you cannot kill them all.
pennzy
pennzy's picture
I can still activate with one hand. Just add enough to add resistance but not too much.
Chicken Drumstick
Can’t say it has been an issue for me. Although some lights have looser heads than others.
Maybe consider switching to a Maglite Solitaire though. They are pretty unique in the fact they are head tight for off, while every other AAA light is head loose for off.
ReManG
Last seen: 7 months 3 days ago
You can wrap the teflon tape pretty thick and then actuate it several times until it is smooth to twist. It will keep the head on and lets you “tune” how far you unscrew the head to make it minimal twist to turn on, as it stays in place well.
Lightbringer
Lightbringer's picture
Last seen: 1 hour 27 min ago
For zipper-pulls (kinda catastrophic if the head unscrews and falls off, I’d think), I use scotchtape, not masking tape. Same idea, though.
Thicker fatter O-rings are nice, too, but (intentionally) make it harder to twist/untwist.
I like the idea of the i1R(?) that has a captive head, but still wouldn’t keep such a light on a rock-tumbler of a keychain. Then again, that’s just me. LOL
turkeydance
turkeydance's picture
Last seen: 5 hours 56 min ago
short-term method:
extra-hold hair gel on threads.
longer-term:
glue stick.
no clue:
deformation of thread path
before a disconnect point.
KnotSoMuch
KnotSoMuch's picture
Last seen: 1 week 5 days ago
For all my AA, AAA & CR123 twisties, I use a plumbing O-ring (such as Danco brand), readily available in multiple diameters & thicknesses at any hardware store. Just roll the right size ring over the head and down into the groove where the head meets the battery tube. When you retrieve the light from your pocket, it's a seemless process to roll the ring halfway up the bezel with one hand, while providing extra grip in order to rotate the light on & off, also with one hand. I find it's an ideal, low-profile, unobtrusive solution to secure even the loosest bezel-to-battery tube junctions. The way it enhances your ability to activate the light with one hand by improving the grip is a bonus. .
If any BLF member would like design suggestions or help with tying a customized paracord lanyard or fob for use with lights & knives, please feel free to message me here.
For paracord project ideas, I highly recommend visiting: https://stormdrane.blogspot.com/
Rexlion
Last seen: 6 hours 5 min ago
Wow. I’ve been pocket EDC’ing Maratac AAA twisties for a decade, and I added a Sofirn C01S to the mix about a year ago, but I’ve never had a problem like you describe.
I lubed the Maratac threads with No-Ox-Id. The Sofirn just has factory lube at this time.
== We save the planet from darkness ==
Blackbeard
Blackbeard's picture
Last seen: 46 min 28 sec ago
I1R2 has the captive head, but I have been using both on key chain and haven’t had either separate. For the new year I decided to try the TINI on the keys but in the mode that lasts only 30 seconds before shutdown cause I know this thing is gonna turn on.
slmjim
slmjim's picture
Thanks for the replies everyone.  I hadn't thought about teflon tape.  I'll give that a try.  Also like KnotSoMuch O-ring suggestion & will play with that next time I'm in a hdwe store.
slmjim
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 2 days 16 hours ago
I’ve never had Teflon tape make for a great experience for threads that need to be turned frequently. My advice would be to pony up for a tube of Nyogel 760G, the good thing is it’ll last you literally decades.
Garageboy
Last seen: 4 days 13 hours ago
I retired my Thrunite Ti in titanium because of this. Reached into my pocket to find a disassembled light or a dead battery too many times. Thicker grease didn’t help me, the threads were way too loose (probably so they didn’t gall like my 4sevens Mini II does)
raccoon city
raccoon city's picture
Last seen: 15 min 48 sec ago
Twisties always fall apart in my pocket.
I haven't tried any of the solutions presented in this thread.
My solution: quit purchasing and using twisties.
I haven't bought or used a twisty in years!  :BEER:
ttt
ttt's picture
Last seen: 11 hours 9 min ago
Firelight2
Firelight2's picture
Last seen: 33 min 12 sec ago
This.
Hank33
Hank33's picture
Last seen: 2 days 8 hours ago
I thought this post was about something else twisting in your pockets when I first saw it!:D
Light-saber
Light-saber's picture
Last seen: 2 hours 26 min ago
Lipstick tube holder? Wink
Here’s a fancy one made of leather:
https://www.amazon.com/Rustic-Leather-Keychain-Holder-Protection/dp/B07B...
Forsythe P. Jones
I’ve never had this happen or come close to being an issue, and I’ve edc’s different twisties since forever. The threaded section is always long enough that it doesn’t ever loosen. I wonder if you are just using lights with crappy machining, and/or body tubes that are too short or cells that are too long. Maybe the answer is get better lights, but failing that, check your O ring.
