Canāt say it has been an issue for me. Although some lights have looser heads than others.
Maybe consider switching to a Maglite Solitaire though. They are pretty unique in the fact they are head tight for off, while every other AAA light is head loose for off.
You can wrap the teflon tape pretty thick and then actuate it several times until it is smooth to twist. It will keep the head on and lets you ātuneā how far you unscrew the head to make it minimal twist to turn on, as it stays in place well.
For zipper-pulls (kinda catastrophic if the head unscrews and falls off, Iād think), I use scotchtape, not masking tape. Same idea, though.
Thicker fatter O-rings are nice, too, but (intentionally) make it harder to twist/untwist.
I like the idea of the i1R(?) that has a captive head, but still wouldnāt keep such a light on a rock-tumbler of a keychain. Then again, thatās just me.
For all my AA, AAA & CR123 twisties, I use a plumbing O-ring (such as Danco brand), readily available in multiple diameters & thicknesses at any hardware store. Just roll the right size ring over the head and down into the groove where the head meets the battery tube. When you retrieve the light from your pocket, it's a seemless process to roll the ring halfway up the bezel with one hand, while providing extra grip in order to rotate the light on & off, also with one hand. I find it's an ideal, low-profile, unobtrusive solution to secure even the loosest bezel-to-battery tube junctions. The way it enhances your ability to activate the light with one hand by improving the grip is a bonus. .
Wow. Iāve been pocket EDCāing Maratac AAA twisties for a decade, and I added a Sofirn C01S to the mix about a year ago, but Iāve never had a problem like you describe.
I lubed the Maratac threads with No-Ox-Id. The Sofirn just has factory lube at this time.
I1R2 has the captive head, but I have been using both on key chain and havenāt had either separate. For the new year I decided to try the TINI on the keys but in the mode that lasts only 30 seconds before shutdown cause I know this thing is gonna turn on.
Thanks for the replies everyone. I hadn't thought about teflon tape. I'll give that a try. Also like KnotSoMuch O-ring suggestion & will play with that next time I'm in a hdwe store.
Iāve never had Teflon tape make for a great experience for threads that need to be turned frequently. My advice would be to pony up for a tube of Nyogel 760G, the good thing is itāll last you literally decades.
I retired my Thrunite Ti in titanium because of this. Reached into my pocket to find a disassembled light or a dead battery too many times. Thicker grease didnāt help me, the threads were way too loose (probably so they didnāt gall like my 4sevens Mini II does)
Iāve never had this happen or come close to being an issue, and Iāve edcās different twisties since forever. The threaded section is always long enough that it doesnāt ever loosen. I wonder if you are just using lights with crappy machining, and/or body tubes that are too short or cells that are too long. Maybe the answer is get better lights, but failing that, check your O ring.
