Just got mine. Very happy with the quality. Thank you freeme. I cannot distinguish the high from the turbo at all, which is not surprising and not important since the differential is relatively small.
I have ordered one,thank you.
When you double click from low to turbo you can clearly see the difference between high and turbo.
Robert
I put a type c cable to charge the battery,but I hadn’t seen any green/red light to show if the battery is charging,or it is in low voltage stage.Is it OK?
Is it USB Type-C to USB-A or Type-C to Type-C cable?
Type C to type A.
Is the battery close to 4v? Try discharge the capacity by activating Turbo for a minute or two first?.
It was 3.6V,so I put the battery in a charger at 2.5A to charge it.
By right it should work if inserted battery is 3.6V. It is better to identify the issue first. You might want to try different battery, cable, and input source?
Trying to buy it from Banggood but none of the coupons available seem to be working, am i too late for the sale or is something up with the codes?
I have already replied your pm.
For those who received my earlier pm. Perform these steps to reveal our latest code:
Could I please have a group buy coupon code? Interested in this WP3 for the specs alone.
Interested
Review in on 1lumen!
Sustained throw for quite a while, compared to maxtoch it’s not much, but a huge improvement over wp2 and other competitors if you seek good sustained usable power for an hour.
Have mine at the post office, just going to have to find an excuse to get there and smuggle in the package…
I tried the light yesterday night,and it is awesome. I pointed at three blocks distance,and I saw like it was a anti-aircraft searchlight.
I’m also interested in the aluminium WP3.
@freeme: Could you please send me the current code by PM? Many thanks!
All replied.
Order placed.
Thanks freeme.
I received mine from the first batch and I don’t believe it has a turbo mode. I didn’t really expect it to because the original description was just hi/lo/strobe. My only complaint is that the light is quite a bite more yellow/green than I was expecting. Other than that a fun light to spotlight things with.
