Okay, I will pay attention. But compared to the high price, what is worse is that the chip is out of production.
Hi. If someone have idea can I order that black version of S2+ metal switch. I ordered my new red S2+ yestarday and I want it to have one of this black metal switches
I wanted a Black S2+ with metal switch too. But no, it doesn’t have.
I ended up buying the Lighted Metal Switch as an accessories and put it in… The Lighted Metal Switch can only fix on Rubber Tailcap S2+…
icpart:Hi. If someone have idea can I order that black version of S2+ metal switch. I ordered my new red S2+ yestarday and I want it to have one of this black metal switches
I know for that metal switch conversion kit for S2+ but I wanted that black metal finish button not raw metal color from picture.
Oh I see… That’s possible. I guess Simon can do it easily for you. Just add a note in your order. Now that you have ordered, maybe message Simon at AX Store if it has not send out.
LTC:I wanted a Black S2+ with metal switch too. But no, it doesn’t have.
I know for that metal switch conversion kit for S2+ but I wanted that black metal finish not raw metal color.
I wanted a Black S2+ with metal switch too. But no, it doesn’t have.[…]
Not from Convoy, but check this:
https://www.aliexpress.com/item/33018646981.html
icpart:I wanted a Black S2+ with metal switch too. But no, it doesn’t have.[…]
Page Not Found - Aliexpress.com
Oops
I mispronounced. I wanted metal switch with black color, not flashlight color body.
MascaratumB: icpart:I wanted a Black S2+ with metal switch too. But no, it doesn’t have.[…]
Page Not Found - Aliexpress.comOops
Ok, now I get it! My bad, I understood it wrong :zipper_mouth_face:
I would ask Simon if can sell you one! The shiny ones are for sale out there, but I am not sure about the black one.
I wonder if Simon will ever sell a triple S2+… I would love one but don’t have the skills to build it myself.
It would be a must have.
I think an S21A triple is in the works
driver for M21E with KW CULPM1.T/SFT40 in production now
That’s excellent news!!
Hey! just noticed the presale for 940nm IR S2+ (https://fr.aliexpress.com/item/1005003202811071.html)
I will take it as soon as it is available
Will it work with lighted metal switch ? (https://fr.aliexpress.com/item/1005002370385808.html) : is the driver compatible? and the body ?
Hello Simon,
Since I modded my Z1 with a 4 LEDs 10W IR emitter … so now I’d like to “know” when it lighten up or turned off (without looking directly at the LEDs which emit a dim red when ON) : could it be possible to get a lighted switch that would fit the Z1?thank you
How did that light perform ? I need a IR light was looking at the Z1.
Can you show a photo of your modded Z1 with 4x IR?
m47mu74nt:Hello Simon,
Quite nicely going all the way from super floody to the ‘LED’ picture on the subject , got the 4 LED pcb and driver here : 1.15€ 10% de réduction|CloLight Diode émetteur LED haute puissance, 3535 4 puces, 4 gible, 3V, 6V, 12V, 10W, infrarouge, IR 850nm, 940nm, 730nm, PCB en cuivre 20mm | AliExpress
I’m not a big fan of zoomy, and the Z1 is quite bigger than I really need, that’s why a S2+ would be better for me, but I was too lazy for the mod.
yeah, next time I use it
it’s nothing fancy, I had quite some trouble reassembling the head though (the o-ring messed up a few times)
Don’t bother showing me then, no need to take it apart again
Thank you for the link, that’s what I needed.
What range roughly are you getting?
Is there a way of removing the AR coating from the glass on my convoy s2+?
I have the convoy s2+ with the 219b sw45k emitter and I noticed that when I remove the glass, the tint looks slightly better. When lighting up white objects with the glass in place they look a little green, and I suspect it has to do with the AR coating.
Scrub, scrub, scrub.
Seriously.
