Same principle like using a razor to scrape your old registration sticker off your windshield. Glass might be brittle, but it’s incredibly hard. Steel wool works nice, but it’s tedious to do, and you gotta get both sides if it’s coated on both sides, too.
DON’T use sandpaper of any kind, not even fine grit, as that is harder than glass, and will frost it.
I only tried it (steel wool) because I was okay if it’d frost it, as I’d likely be using diffusion film anyway if I wanted a flooder. Wasn’t an S2/S2+, but I vaguely vaguely vaguely recall it was one of the older Sofirn SPs that had AR coating on the glass. Might be mistaken, though.
Anyway, it came out fine, enough so that I can’t even recall which light it was. Ie, not “damn, I ruined the glass on that light…” or anything.
Sit back and veg out watching teevee while doing it, as it’s tedious and takes quite a while.
Hey Funtastic whats your plans?
I was looking at buying a Z1 and fitting one of those 10w 850nm IR led into it and see how it goes as I think my IR is the weak link with my old scope.
Before I go out and buy a new NV scope for my new Air gun “rabbit hunting”. I would like to try a better IR light on my old trusty Photon XT.
As my IR “sensor” is a cheap mini-“action”-camera, I can’t use it at more than 50 meters (the camera doesn’t show anything useful further): I mainly use it as a very close range flood light
You may get 100-150m, but I can’t tell…
Many people dislikes anti-reflective coatings. I dislike them too. This is because the standard anti-reflective coating used for flashlight lenses is λ/4 MgF2 centered at 550nm, which being centered at 550nm, a frequency of green, boosts this frequency and those around it more than the remaining frequencies in the visible spectrum. This can be seen in the following graph chart at Edmund Optics:
In the above graph it can be clearly seen how the λ/4 MgF2 550nm curve is lowest around 550nm, and goes higher (higher reflection, or less effective) around it. Therefore, the gains of this AR-coating are unbalanced and noticeably screw up the tint and even the CRI of emitters to some extent.
What does this mean? Many customers would buy plain lenses anytime, lenses without anti-reflective coating. Customers of high-CRI lights and emitters, namely.
I agree and am willing to buy extra lenses that are either uncoated or that have a green coating. Tint is so important and noticeable to most users while transmission losses are not.
To make things worse, recent AR coatings have been causing magenta artifacts around the periphery of the beam. This is terrible.
Please offer uncoated glass, especially for hi cri lights.
From a cost perspective, I’d rather put the money into better (clearer) glass than coatings.
