Nicron N7 w/rotating head $12.99. It's been a little cheaper in the past but not by much. Worked fine as a bump to qualify for free ship for the $15 motion lights posted by will34 above.
Thanks for the heads up. Just purchased these under counter LED lights. My wife has been asking for LED lighting just like this.
She wanted them for a closet and one under a counter in the kitchen. I’m sure she’ll be happy when they arrive.
I stopped using mine because the batteries were to hot to touch before they were fully charged. I put them in my PowerEx MAHA MH-C9000 charger
and set to charge at 200mAh and they don’t get hot. It wasn’t like I even needed the charger anyway. The upside is all 8 “AA” are good and none were
defective.
Followup, yeah, might’ve been only partially charged (ie, sketchy “I’m charged” indicator). They all clocked in about 2050mAH on average, so all is well.
Yikes! I got the 2 for deal in august and been using one in my garage since - it's been doing fine, and my son-n-law is using the other. Haven't checked the heat but I don't really leave it on long either.
Yeah, the EBL batteries seem fine… time will only tell if they are capable of a reasonable low self discharge. And who knows if they’ll live for as many charging cycles as claimed. But that charger is a bit suspect. I like the compact size and very readable charging status display, but I’m finding it tends to overcharge cells. I charged an older Eneloop AA on it… got 1.52v. However, I’ve yet to find any cells feeling appreciably warm or hot. The fact that at least a few people here are seeing hot cells means the QC is spotty on this stuff. Figures!
checkout AVE on youtube, for tool reviews he opens the box w/ the proper version. they seem useless to me tbh, or at least only useful for very specific cases, which admittedly some people have…
I don’t get it. Why a chainsaw vs a sawzall-type recip?
I’d rather replace a blade to suit (wood, metal, demo, etc.) vs replace a chain, and even then it’s iffy that you’d be able to get any beyond the spare(s) in the kit.
I’ll give it a shot — I’ve only bought 2 DMM in the last few days —— This cheap one was around $16 through Vipon —It’s big though —I’d hate to be hit over the head with it —pretty accurate compared to my Fluke
280Wh/400W power station, has 100W PD input/output and regulated 12V DC output (says 13.3V 10A). That makes it better than the aftime, however the aftime has MPPT input and this one only has PWM, which is not a big deal unless you plan to charge it via solar.
I received my EBL batteries and charger — I went ahead and top them off in m y Powerex Charger —they top off easily —but today when I ran a capacity test they all tested around 2000 mah —- then they all charged up to that same capacity except one — that one cell was still charging after putting 2900 mah in it —- on a battery that size I usually charge at 800-1000 ma — I think thats what’s happening with the supplied charger —- I tried out the EBL charger with some Turnigy batteries and it worked fine
