What did you mod today?
I finally got around to fixing my L6 today.
A while back I flashed Anduril to the L6. In the process, I managed to put tension on the Switch signal wire to the switch board, which ripped the last remaining scrap of the solder pad off the board. I had damaged it when I first installed the switch in 2018 (too much heat, insufficient flux).
As a patch, I routed a wire to the leg of the switch on the front of the board. However, this always interfered with the switch’s rubber boot fitting properly, and the action of the switch itself. It was unreliable, with non-presses and double-presses occurring regularly when attempting single clicks. In anduril, obviously that’s a no-go.
So I found Lexel’s old shared oshpark boards and recognized the switch PCB, and ordered two at some point. Today I set about the repair.
Step one, I removed the switch board. I also decided to replace and lengthen all three switch board leads today. I set the new and old board on my hot plate and set it for 200°C. While that was heating, I removed the switch leads from the driver. I carefully cut three new longer leads, a blue LED+ lead in 30 gauge silicone insulated, and red switch signal and black ground leads in 24 gauge silicone insulated. Stripped, tinned, installed, and threaded back out the switch hole. Driver put back down and retaining ring reinstalled - I never undid LED± leads.
The hot plate was ready. I carefully transferred the 0402 (thanks Lexel - I probably should have moved to 0603 as the pads would’ve supported it) and managed not to lose any to things like faint indoor draughts, sticky tweezers, or shaky hands. I lined up the boards ahead of time to avoid having to worry about polarity (since I didn’t drop any, luckily). I transferred the microswitch as well.
I flipped off the hot plate and poked around BLF a bit waiting for it to cool. Then I flipped the boards. First mistake, the original board’s resistors on the backside had shifted. Luckily only one of each value (four total, two for the pink and two for the blue LEDs) had remained in place so I could figure things out (and read the markings with magnification). I taped the boards to the hot plate with kapton tape so they wouldn’t move on me, and nothing would fall off the back of the new board (hopefully). I then used hot air (250°C, lowest airflow) to carefully transfer the stupid tiny 0402 resistors. Nothing did fall off the back.
I installed the leads to the switch board. I inspected it visually, cleaned it with 99% isopropyl, and inspected again. It looked good to me. I really should’ve checked it with a power supply but I didn’t, I just hooked it up and powered the light while it dangled.
The switch didn’t work. Nor did the LEDs light up. First things first, the microswitch was buggered. I have more - replaced. Tested and working. Now for troubleshooting the LEDs.
I poked around the switch board with my multimeter for a while before noticing that LED+ had continuity with ground. I looked everywhere, including referencing my spare blank board for ideas, and could not figure out where the short was. I also couldn’t figure out how the driver would be working with pin 8 of the ATTiny85 shorted to ground…
And that’s how I figured it out. I looked back at the driver, and I’d soldered the LED+ lead to the wrong side of the capacitator that goes from Pin 8 to ground. I double-checked and the other side had continuity to pin 8, and the side I was on went to ground. Moved the lead over and tested, and I had light!
Last of all I had to reassemble. I was a bit overzealous with the switch leads, they were a bit tough to stuff back into the L6 driver cavity despite its cavernous size. Then the switch board didn’t quite fit down into its hole, so I had to file it down a bit all the way around the circumference (and stuff the wires back in again when I was done). But now it’s all finished and I’m quite pleased to have one of my absolute favorite lights back in action!
Of course I neglected to take even a single photograph during this process. Sorry.
Put a guppydrv v2 in my enogear SS light. Finally it has moonlight mode now.
Any details?
I still have a defective one lying around, definitely worth upgrading
Ordered this mountain electronics driver. Just a little bit of filing is needed. No spring, just a brass button.
You will also want a better MCPCB going this route. FET is too much for that tiny alu one.
Sure is. I already had a copper mcpcb with 2700k sst-20 in mine.
Thanks jon_slider :+1:
I just ordered some HERE
I have a few cheap zoomies to practice on before modding a Haikelite HT35 :smiling_imp:
Thanks, very tempting, but the shipping costs are holding me from ordering.
Are you ordering anything from MTN soon?
Maybe we can save some shipping costs by ordering more things together
Making progress in modding my Zebralight SC52w.
A few weeks ago I destroyed the stock driver attempting to remove it for an LED swap. Zebralight no longer has any driver boards available for the SC52w, so they can’t fix it. This left me with a nice host with no electronics.
I’m in the process of turning it into a triple. My plan is to use a copper platform to hold the star in position, while the driver floats in the space below the platform. I’ll use the stock switch and it should not be necessary to modify the body of the light.
Steps completed so far:
  • Carclo 10507 optic modified to fit in available space in the head.
  • Noctigon 20mm triple star filed down to fit into available space in head.
  • Copper platform made from sheet copper for star to sit on.
  • Fit-tested copper platform, star, optic, lens and retaining ring.
  • Inserted wire and contact for positive contact in battery compartment. This still needs a bit more work.
  • 15mm Mountain Electronics driver flashed with Anduril and tested for function outside the light.
Still to do:
  • Fully insulate the underside of the copper platform with Kapton tape.
  • Connect the wires from the battery compartment to the driver. This is probably the toughest step since space inside is very limited. Hardest part is probably the positive wire from the battery compartment to the driver, and the negative wire from the screw to the driver. Both will be underneath the driver and there isn’t much room to lift up the driver.
  • Insulate bottom of star except for contact points with battery tube wires.
  • Connect the switch to the driver. One of the switch contacts will be right next to the edge of the driver. I think a solder bridge should work without wire. The other will be only a few mm from the switch contact, so maybe a short jumper wire from the ATiny.
  • Connect the driver to the star. Should be relatively straightforward.
  • Place LEDs on the star. My resupply of LEDs from Kaidomain arrived. Thinking of either 3x SST20 FD2, or maybe 3x XPL HI using 2 high CRI XPL HI and one cool white low-cri XPL HI.
I hope my Arctic Alumina adhesive is still good. I think I’m down to my last tube and they no longer sell the stuff anymore. If it’s not good, I’ll probably end up trying UV super-glue and hope it’s good enough.
I’m trying to go slow and take my time with this mod. I don’t have any spare drivers and the host is irreplaceable.
I recently ordered quite a bit on mountain electronics so I am good for a while. But if I ever order again there, I will let you know.
Finished modding my broken Zebralight SC52w into a triple.
It now features:
  • Anduril driver
  • Triple 4000K SST-20 95 CRI FD2 bin emitters.
  • Spring bypass in tail.
I quite like it. It’s not much bigger than than an FWAA, but has a great clip, excellent button, and is much throwier due to the larger optic.
I’ve never seen such a mod before, congrats :slight_smile:
Yep congrats, looks like a challenging mod, any pics of the inside ?
Thanks.
I was expecting a difficult mod due to the tiny irregular space in the head for all the new electronics.
However, the mod went surprisingly smoothly and the light worked on the first try. The hardest parts were filing the star and optic down to fit in the cavity and then figuring out the best way to attach the positive and negative wires to the body under the star.
For the positive wire I ended up using the stock contact board. I strung a long piece of 24 gauge wire through the pass-through hole in the shelf, all the way through outside the bottom of the light. I then soldered it to the contact board and added a bit of thermal epoxy around the solder to help insulate it. Then I pulled it back up into position at the top of the battery compartment, cut it off and then soldered it to the board.
For the negative wire I inserted one of the original driver retaining screws, wrapped a short piece of 24 gauge wire to it and soldered it directly to one of the contacts on the bottom of the switch.
When I inserted the driver (15mm Mountain DD driver flashed with Anduril) I used a solder bridge to connect the edge of the driver to the switch with the negative wire. I used a 26 gauge wire to connect the pin on the Atiny to the other switch contact.
I took more pictures and plan to post a build thread later today.
Looking forward to it, Thanks!
Nice save!
Here is a link to my build thread on modding the SC52w
Jetbeam TCR-1 mod to 219b 3000k
started by reflowing a triple mcpcb
after reflowing the LEDs I realized the MCPCB is too big… will need grinding
meanwhile decided to install a single 219b 3000k
Very happy with the warm 3000k… for camping and full dark use, I personally I like 3000k better than 3500k.
Good choice. My favorite emitter in my favorite light :beer:
thanks! You have very good taste :beer:
