Amazon Deal Alerts & Discussion Thread
Any experience with this handheld mini cordless chainsaw?
https://m.myvipon.com/#/product/8850968?sl=
checkout AVE on youtube, for tool reviews he opens the box w/ the proper version. they seem useless to me tbh, or at least only useful for very specific cases, which admittedly some people have…
I don’t get it. Why a chainsaw vs a sawzall-type recip?
I’d rather replace a blade to suit (wood, metal, demo, etc.) vs replace a chain, and even then it’s iffy that you’d be able to get any beyond the spare(s) in the kit.
Looks tres kewl, though.
Digital Clamp Meter, Smart T-RMS 6000 Counts Multimeter Voltage Tester Auto-ranging, Measures Current Voltage Temperature Capacitance Resistance Diodes Continuity Duty-Cycle, AC/DC Current
Coupon will save an extra 50% of $35.99.
It has all functions like Uni-T UT210E + temp measurement.
I’ll give it a shot — I’ve only bought 2 DMM in the last few days —— This cheap one was around $16 through Vipon —It’s big though —I’d hate to be hit over the head with it —pretty accurate compared to my Fluke
https://www.amazon.com/gp/product/B08Y5HKF2B
What coupon?
slmjim
Another Poweradd product with 50% off = $130
280Wh/400W power station, has 100W PD input/output and regulated 12V DC output (says 13.3V 10A). That makes it better than the aftime, however the aftime has MPPT input and this one only has PWM, which is not a big deal unless you plan to charge it via solar.
https://www.amazon.com/Portable-78000mAh-Generator-Outdoors-Emergency/dp/B09BJPYC5N
I’m starting to wonder if these are in fact genuine poweradd stuff…
I received my EBL batteries and charger — I went ahead and top them off in m y Powerex Charger —they top off easily —but today when I ran a capacity test they all tested around 2000 mah —- then they all charged up to that same capacity except one — that one cell was still charging after putting 2900 mah in it —- on a battery that size I usually charge at 800-1000 ma — I think thats what’s happening with the supplied charger —- I tried out the EBL charger with some Turnigy batteries and it worked fine
I don’t see a coupon on the Amazon page either… and no results when searching on Vipon
Hold up on that meter if you want it for flashlights. That Zoyi does not have a low DC range and the 60A setting has a resolution of just 10mA. Much worse accuracy at 2% + 30 (thirty!!!!!) digits. Maybe fine for general stuff although I have no idea of that brand's/product's quality.
That low DC range is the only thing that makes the Uni-T 210 a standout in the world of cheap meters (has 2A, 20A, and 100A with better resolution and accuracy all around). Other units that will do that cost an arm and a leg.
Can peek at the manual and specs here: https://zotektools.com/products/zt-qb9/
Edit: If you really want this, looks like you can buy it on Ali for $26 here, or $34 on their official store: https://www.aliexpress.com/item/4000943578993.html
Sorry, they may ran out of coupon (check box) on Amazon …
Here is another good deal of multimeter:
Digital Multimeter TRMS 6000 Counts Auto-Ranging, NCV with AC/DC Voltage Test, Resistance, Continuity, Capacitance, Diodes Temperature Measure, Case and Battery Included
Save 50% of $34.99 (check box under the price)
Good luck!
$20
https://www.amazon.com/Schrade-SCHF36-Outdoor-Survival-Everyday/dp/B00PGZ0130/ref=sr_1_2?dchild=1&keywords=schrade+schf36&qid=1631716822&s=sporting-goods&sr=1-2
Bluetooth headphones $10
https://www.myvipon.com/product/8857894-Active-Noise-Cancelling-Headphones-with-45Hrs-amazon-coupons
https://www.amazon.com/dp/B09C8K3F4C
These appear to be rebranded Mpow H17 headphones.
At this point, I think everything is a rebranded MPOW. :laughing:
Just about everything I post in this thread is.
I look for headphones that are a good deal on a daily basis, and most of what appeals to me are rebranded Mpow.
Can’t beat them. I’ve been using mine for a year now and they are still working great.
One set (H10s or H12s, forgot which) just stopped charging, so I have to use them unpowered only.
I just received mine also…. thought it was nice of them to send the extra charging ‘adapters’. I was about to post asking how you were supposed to swap them… then I found my glasses and a flashlight :wink: I hate getting old ………… Charging now.
Good deal.
I just ordered the 059 Lite for $10 for my kid for school. Thinking I might cancel that order and order these H17s instead since they have ANC. Alas the Vipon coupon has ran out for today.
EDIT: Looks like it’s too late to cancel.
Got one of these, very well build, very basic UI… wish I could have bought a pair at that price.
