The lights I mentioned from “other stores” include that one, and others.
However, this is my wake up call for Skilhunt. If one wants to get lights from them, it will become more expensive, and the will sell less.
So, as a person who cares (slightly), I would like to hear from them what will happen if I want to get my lights from them.
There are plenty stores selling their lights cheaper, or without fees, but this time I’d prefer to go to the source. But I will not do that in case the conditions for me, as a customer, are not as good as I can get from others!
It does look like the pebbled lens has some kind of ringed bit in the center. Head is more rounded and now the body has a flared out segment at the head base. Also, looks like they may have modified the magnetic charging port?
Wow, a good amount of options: black vs grey, reflector vs TIR, 6500K or 5000K, no battery vs 3100 mAh vs 3500 mAh. And UI looks good: click for on/off, long press for low, double click for turbo, 4 click = lockout with optional indicator. I’m liking the looks of that optic. Can’t wait to try it out
Big fan of Skilhunt, I have more than ten Skilhunt flashlights , most of them from M-serie, plus one headlamp.
But, I count like five UI incarnations in the last three years in M-serie and headlamps.
Here we are:
M200 - 1.gen. : 2x4 modes
M150 - 1.gen: 2 UI groups (the second one non-programmable)
M150, M200 - 2.gen: 2UI groups, the second one is programmable
H300 - 7 modes
H04old to H04new - like H300
Thats simply too much. Where is the continuity, where is the stability? Looks like Skilhunt dont know, what they want. Its really bad, because otherwise they produce great lights.
535 lm T2 and 395 lm H… Why? Why…!?
It would be MUCH better to replace the old XM-L2 to higher efficiency SST40 or Osram PUSTA1 first.
Then turbo levels can be also higher which makes sense.
Isolated charging port. Stronger tailcap magnet. these are also good modifications.
I personally love the option to set the number and power of the levels. You could leave it this the “new” Armytek-like UI. It’s only programming.
My skilhunt H04 RC is my most used headlamp.The thing I dislike is the extra long press from off goes into lockout which appears to be fixed.
The biggest complaint is that I can’t cycle up from moonlight into low, medium etc. You have to turn it off and rely on last used mode which may be too bright.
