While I could be flippant and ridiculous and state, “Imalent R90TS and Imalent DX80” I’ll be serious here (in a fun thread of course )
Of all the LED flashlights I have used over the course of my life, the only one that never failed (including the tailcap getting stuck to the point you can’t twist it open - SL PROTAC® EMS Aaargh!) ; bright enough ; good runtime ; consistent brightness; takes conventional AA alkaline or Energizer Ultimate Lithium batteries; etc.
Streamlight’s 4AA PROPOLYMER® LUX is the choice if I were to actually go into the Catacombs right now.
To put how good and useful the Streamlight’s 4AA Propolymer Luxeon flashlight is into context: I started with using the vintage Surefires. The E2D defender, E2O Outdoorsman, G2Z combatlight, A2 Aviator and so on. I would reach the bottom of a dark, scary, twisty, wooded night hike trail, and I would turn around and hike back the same way.
One day, when the aforementioned SL 4AA Propolymer Luxeon came out, it intrigued me with its 100 Lumens (I believe it was less, like 60 or 80 when it first came out) with 4 hours consistent brightness, not dropping below 80% and on 4 AA batteries. I bought it and hiked the same trail.
It was consistently brighter than any of my Surefires! To my surprise, I spotted an opening that took the trail upwards like a “V” from the previous path!
The 4AA Propolymer Luxeon allowed me to find an otherwise hidden continuation of the long, twisty, mountainous trail.
I have no doubt this is the flashlight I want as the baseline for my lighting when I go into the Paris Catacombs. After 15 years since its first release, it is still the perfect life preserving torch!
Never been to the catacombs but whenever I’m exploring underground somewhere I’m technically not supposed to be then I always bring at least 3 or 4 lights. If I went to the catacombs then I’d probably bring 5 or 6.
Ones I’d pick from my current collection:
Zebralight H53 - AA headlamp
Armytek Elf C2 - 18650 headlamp with USB charging
Emisar D4V2 - 18650 hotrod, with moonlight, beacon, etc
Manker MC13 - 18650 hotrod
Imalent R60C - my brightest soda can flashlight
Lumintop Thor II - 18650 LEP, just in case
Other stuff I’d bring:
XTAR PB2S so any 18650 or 21700 could charge any other one (using the Elf and R60C)
Water, food, first aid, compass, map, rope, an experienced guide
I kind of don’t get this, the catacombs aren’t remote and unexplored caves, they’re basically a tourist attraction now. They have daily visit schedules, stopped temporarily for Covid but now going again, as long as you wear a mask. If you get in trouble, your cell phone might even work.
So: headlamp, backup headlamp, D4v2 in my pocket because why not, and a Photon Freedom on a neck lanyard under my shirt just in case. Plus my phone has a built-in light. Seems like enough.
i guess i would just throw in some sofirns convoy and lumintop in a backpack i guess… u need have spares doing that stuff in case u run out of power lol… what a nightmare :s
There are the ossuaries Catacombes, with signage and I assume lighting for the most part. And there are the rest of the underground quarries, usually also referred as Catacombes, where you’re on your own and you need to be equipped like for any caving expedition. The ossuaries only account 0.5% of the caves according to Wikipedia.
Primary Headlamp: Armytek Wizard Pro
Backup Headlamp: Sporttac PH10LC2, or possibly Thrunite TH20 if weight/space factors. I’d rather have redundant batteries, though.
Primary Handheld: Tough one. To be honest I’d probably use my Zebralight sc63w but I might grab the Seraph-6 with Malkoff M361-N219W.
Backup handheld: Couple here for sure. I’d have my EDC Thrunite Ti3/219b on my keys and probably 1-2x Sofirn C01/C01S. Maybe I’d double up and bring both the ZL and the Malkoff discussed above.
SHTF: Well, might be good to bring some chem sticks, too. Don’t want to die down there because China decided to hit Europe with an HAEMP strike.
Edit: Now that I think about it, might be good to have one dedicated thrower. Any flood is going to wash out on the walls and make it hard to spot down a tunnel…
Yes realistically a good headlamp is a critical illumination tool for spelunking. I went on a one hour quick night hike yesterday, carrying my new Imalent R90TS. It was all I could do because the local authorities lock up the steel gate and start towing cars at 9:00 PM. The Imalent R90TS is surprisingly well-designed with regards to User Interface, mode spacing, size and weight. It was pleasant to carry in spite of its 8 X 21700 battery pack.
I suppose based upon this, I would use a long-running headlamp with two spare headlamps securely fastened to my body. For experimental purposes, as a flashlight enthusiast, I would bring along my current Imalent R90TS; for curiosity sake.
Unfortunately, I have never been in the Parisian catacombs. My dream is to visit Odessa and Paris ones. But there are a lot of mines near Moscow. They are not very long. Longest one is 18km. One of the main rules there is not to go alone. I only take 2 headlamps with me and spare 18650, one for every day I am underground. I usually bring with me the same flashlights I use in the caves Panda 3 and Skulhunt H03 with 4*E21A.
Dear dealgrabber2002, I do with regards to the hand torch. I’m a really curious person when it comes to illumination. The Imalent R90TS is surprisingly pleasant to carry compared to other mega-sized flashlights. The shape is subtly tapered. There are no unpleasant protrusions, weird shapes, or sharp fins. Its LEDs generate a lot of heat. The active cooling fans are essential when running the light at higher levels when the batteries are fully charged. You can feel the hot air as it’s being blown out.
It is, unfortunately. For a sensible choice go with the Streamlight 4AA Lux from Brightguy. Only $39.xx and maintains a throwy but useable beam of 100 lumens for 4 hours. Uses AA batteries.
What a coincidence! Just yesterday I did a web search for catacombs (non flashlight reason) and one of the photos that came up had a brightly lit circle of pure white light… I immediately thought that’s a hot rod light! Then began thinking of what light I would use in there myself, now today I find this thread!
Something to think about for all flashaholics! Is this for lights we already own?
I’ve also recently been considering a tour of a 1.25 mile long abandoned highway tunnel, so I’ve already been thinking about this lately…
Here are the best 2 lights I have for this type of adventure (Handheld & Headlamp) :
1. Q8
2. Thrunite TH30
If the Q8 were too cumbersome I’d take my Thrunite TC20 instead (or for a 3rd)
I also have on order a Manker MC13 90.2 Limited Edition I would consider taking.
I’d have to buy a headlamp since I only own a shitty incandescent one that I received as gift and has never been used. I guess that efficiency would be super important so I’d bring at least one Zebralight, probably several. Not sure if throw is a concern in such a scenario? I don’t have a true pocket thrower yet. The Catapult V6 is a stretch to call a pocket light. Either way, I’d make sure I had 3-4 of each cell I was using.
Oh boy, now I’m picturing flashaholics trying to keister their batteries. :person_facepalming: 18650s, 26650, 26800s…oh, the humanity!
