Doesn’t show up for me. Maybe they turned it off. I’ve seen coupons like this come/go on Amazon.
Pretty nice looking lamp, but there’s no indication of wattage. Oddly, there’s a comparison chart at the lower end of the images that shows wattage, but they don’t even include the Moko light being offered! It’s surprising what a difference 6w to 12w makes. We also don’t get a lumens output figure.
Just got my 2 sets of LOFTER motion sensor magnetic light from the deal I posted a couple pages back. Ended up paying $29.99 for all 4 lights and I’m happy with what I got:
The good:
–3 tint to choose from, no green in WW and no blue in CW, variable ramping brightness. Excellent beam and output. No PWM in any level.
-Accurate motion sensor with option to have it turn on only when dark
-As expected it uses a 18650 inside instead of a pouch cell. There is room for another 18650 to be installed.
-Build quality is pretty good and the diffuser is not overly thick.
The bad:
–20s auto off is a bit short, I wish there was an option for 60s
-Long hold to manually turn on/off makes it impractical to use without the motion sensor.
-Micro USB charging
Despite the negatives these are the nicest motion sensing lamps I have bought, and I have tried quite a few.
Excuse the messy workspace, but sometimes I feel I get more done this way, a la AvE
Enough room in the LOFER light for a 21700 you think?
I converted one of the thin ones to a 1S4P 18650 external pack for a basement light. It’s a kludge, but works fine for what it is. The “large gum-stick” battery they come with is simply not up to the job. Other than that I like it.
21700 not possible… there is only ~2mm room with the 18650. But the MCPCB is just inserted in a slot in the extruded aluminum and you could probably fix it on top of the battery with some epoxy.
Yeah the lipo packs these movement lights normally comes with are designed to fail. Not a single one lasted me more than a year until severe capacity loss or swelling up. And even worse no way to get replacement batteries at decent prices. 18650 is the way to go…
Wuben E6 - 14,500 batteries included and a 30 % off coupon
“Compatible with two batteries: WUBEN E6 is a flashlight compatible with 14500 batteries and AA batteries. The flashlight purchased will be equipped with 14,500 batteries. Not to buy quickly yet! ! ! ! ! ”
The radio is decent enough considering the price. The included 2200mAh “Li Lon” battery tested ~1400mAh at 1A discharge. Anyone else? I don’t care if it’s just a low capacity battery but I’ll drain and throw it out if it’s damaged.
Yeah, that’s my main complaint about Wubens (the TO46R being a major exception), awesome hardware, but UIs that cause slow but cumulative brain-damage.
