I had one of those Dell monsters at work. They’re worth their money. Saves you a second monitor.
agree with sp5it:
Anything over 27
is too big and
useless for me.
So i’m with 21” a midget? Or too old?
I’m likely in the minority. I use 3x Dell U2412M’s at the house and don’t ever really moving away from 16:10 aspect ratios for the foreseeable future. Really happy with my setup for WFH productivity (A mix of coding and document review).
I’m not a huge gamer so 1080* is typically good enough for me for the little gaming I do. Also I prefer multiple monitors for the physical delineation of screens as well as being able to angle individual screens to my taste.
Due to corona and working from home i have bought 2* HP Elitedisplay E243i monitors last year. (16:10)
I use them next to my laptop, since working on a laptop is pretty useless for longer periods.
I would love to have bought the larger ones, but the HP U27 4K is pretty expensive…
Without the video card to drive it, it’s worthless.
I don’t have any recommendations myself but I’m interested to hear from people using large monitors.
After several yeas of using two 24 inch 1920x1080 monitors I switched to one 32 inch 2560x1440. I found that with two monitors I was turning my neck a lot which was quite uncomfortable.
I would like a bit more space, but I don’t think I could use 4K resolution without a larger physical screen, and I’m not sure how much bigger I could go without experiencing discomfort from having to turn my head.
My TV is 40 inches, and I can’t imagine using a monitor that big. On the other hand, my last TV was 32 inches and it seemed big when I got it and now a monitor of the same size is starting to feel small.
I’ve been mostly working from home since the start of the COVID-19 pandemic, and during that time my employer has introduced hot-seeking. Now instead of having my own 32 inch monitor in the office or even my old employer-provided 2 x 24 inch IPS screens, I have to use whatever 22 inch screens are on the desk I’m able to book. At least most are new 1920x1080 IPS panes, but some are lower resolution TN panels. It’s not the end of the world, but it certainly makes me even less enthusiastic about coming into the office and less productive when I’m there.
The built-in screen on my Alienware 17” laptop is all I have. I am so easy to please with some things.
My Asus Republic of Gamers laptop has a 17" screen, but I frequently have it hooked up to my 32" monitor or TV.
17" is too small for me.
I do not play games so that is one reason screen size is not important to me. The only reason I have a gamer computer is that I get hand-me-downs from my son. He gets a new one, top of the line every couple years and I get the old one. It may be 2+ years old but still better than any I would buy for myself new. Nice for editing photos.
My current favourite monitor is a 1998 Iiyama Vision Master Pro 400 CRT. I do like flat screens as well, but there’s something about a CRT that’s hard to replace
I used a Samsung 2443BW for the 1920x1200 goodness for many, many years. Earlier this year I purchased an Asus VG279 27” IPS 144Hz for my sons computer, main purpose gaming with a GTX970. Didn’t get full 144Hz FPS advantage with that card but just using it in desktop got me hooked on smooth frames so I got one for my PC as well.
I miss the extra lines but it’s a great screen and my GTX980 won’t cope that well with higher resolution so didn’t see the point in going over 1080 for a new screen.
New GPU’s are stupid exxy so my son got very lucky when, a month or so after we got the 1st VG279, my colleague at work scored a 3070 and let us have their old Asus Strix GTX1070 for below market rates. We still on oldish hardware, 4690K @ 4.2GHz but it does the job.
I’ve only bought one monitor in over 10 years so i have none for comparison.
But i can say avoid Dell, the quality control sucks (this is the 4th monitor, the 3 previous replaced under warranty) and their customer service is extremely outsourced and feeble and a headache to deal with.
Still using my HP 2159 21.5 inch monitor. I am not looking for a replacement, as it still works fine for my needs.
As I said above, I use an LG 43” 4K screen at work and I like it a lot.
Tips:
- Some monitors only support their highest refresh rate over DisplayPort. Make sure the monitor you want will do 60Hz over a connection your computer supports natively. (adapter cables exist but may cause display driver weirdness)
- Have a deep desk so the monitor isn’t too close making you crane your neck and blasting your eyes with light
- Adjust the HDR settings of Windows to be comfortable for you too look at.
- Be comfortable managing windows using the Snap feature in your OS. I don’t recommend the third party software included for tiling windows; it can make things more awkward at times.
- Make use of virtual desktops for applications that benefit from being full screen on a 43” monitor and learn the keystrokes for flipping between the virtual desktops
High refresh rate and low-blur is important to me, so several years ago I scored a Dell 2716DGR on sale at Micro Center. Now it over 2X as expensive as what I paid!! No way I’d buy it for that price, but glad I stepped up to 1440p when I did.
With slight tweaking of the RGB balance it has scored fairly well on color for a TN display when tested, and the viewing angle is well within what I need for a monitor that I stay fairly close to when using it.
Absolutely no way I would go back to 60hz unless absolutely necessary. The monitors at work seem atrocious now in comparison after years of using 120hz+ at home.
Is your primary application gaming or productivity? I plan to upgrade to a higher refresh rate for gaming at home eventually. I don’t see how it would help me at work though.
What a coincidence topic, one of my 4yr old Samsung monitor went quietly dead on me yesterday. Display was well taken care of.without a single dead or dark pixels. Strangely, they were no tell tale signs of failing either.
Does it show signs of getting power? I’d swap out the power supply and use a different outlet just to be sure it is truly dead.
Got the high-refresh/low latency for gaming, but it just feels so much better for everything else too. Like going from a constant current light to one with pretty bad PWM honestly. Once you’ve experienced the better one you can’t help but constantly notice the difference when going back to the worse, even if it’s not really a “usability” issue.
Doesn’t help at work that the mice they have hooked up on several machines have the feet super worn and seem to have terrible sensors. I really do have problems clicking on small buttons, etc. sometimes lol
