Maybe I do not understand the question
but why work to get 8 ?
https://www.fasttech.com/products/1612/10001751/1127403-8-amc7135-4-group-2-5-modes-led-flashlight-driver
Regards Xandre
Regards Xandre
’Cause he’d have to unsolder the µC, which is tedious, and why buy something you’re going to do without?
If you’re okay with the extra expense, I think those 8-fers have pads set up where you can short the enable line to the + voltage (solder-bridge) to keep it forced on. The µC and all other crap are still there, doing what they’re supposed to, but the 7135s are Just On.
You can connect the third leg of any of the 7135s to the positive led pad. No need to unsolder anything.
Why dont you just design your own PCB?
4$ for 5 PCBs which fits your device perfectly … and if its 1 sided it can be made on aluminum ;))
For 2$ I get a board with half the chips already soldered on it :)
Lookit https://flashlightwiki.com/images/a/a3/Nanjg_105C.\_600.jpg and zoom in.
(So much for linking the pic…)
I forgot which pin is which, but to bypass the enables, just crowbar them to positive, and there’s no need to unsolder anything. Just a solder bridge should do it.
Where are you from?
I am on the oposite side, I need old good Convoy V2 driver all together with attiny A13 mcu and 8x7135 chips but it is discontinued :rage: and I cant buy it anymore.
New wersion is using some weard chinese mcu that I cant program like I did with A13 based drivers
So I will probably have to find pcb on OSHpark or similar PCB service and get all components to build drivers from 0 :weary:
Nanjg 105C can do the job but Convoy V2 was just that better to be my favorite driver.
Nanjg has 7135 chips on the spring side soldered a bit wider so when you screw on the retaining ring it hits the center,
wide contact on 7135 chips and start spinning entire driver as you screw in mentioned ring.
On Convoy V2 this was not an issue.
Also price is not that affordable when you want to buy 50 drivers. Maybe OSH park solution could be cheaper?
’Cause for now it seems the exact critter doesn’t exist commercially.
Either get the 4-fer and piggyback some 7135s to make an 8-fer, or get the brainy 8-fer but just don’t use the brains.
I used the 4-fers in a few lights (usually XP-E2s, and/or high-rel lights whose pills I’d pot), and wanted something with a bit more oomf, but nope, couldn’t find any.
Anything on the flip-side, though, and it’s no more flat contact, but a spring would now be a must, so that’s another consideration.
They are selling double sided slave boards at OSH Park, 2$ for 3pcs of the 16mm:
16mm 12x7135: OSH Park ~
19mm 16x7135: OSH Park ~
26mm 20x7135: OSH Park ~
