New "Custom 5050 Red 620nm LED"
14 posts / 0 new
Funtastic
Funtastic's picture
Last seen: 1 day 17 hours ago
I found this Custom Red 5050 LED on Kaidomain and just received a sample for testing.
Initially purchased some to test in the Convoy H1 headlamp, but they haven’t arrived yet, so I installed one in the Convoy L21B. Just waiting till dark to see what it’s like.
Started off with Convoy’s 5A driver which is actually running at 5.5A for 460 lumens, then decided I better try something lower in case it’s being overdriven. Installed a 12*7135 driver and started removing chips
4.2A – 520 lumens
3.8A – 515
3.5A – 506
2.8A – 440
Specsheet is rated 3A max. I started off at 5A since the review on Kaidomain says it handled 6.7A fine.
Looks like 3.5A is the sweet spot.
I’ll test range tonight, but this is quite a decent chip, since it doesn’t require a special driver like the Osram Red. Great for lighting up a larger area.
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
Edited by: Funtastic on 09/23/2021 - 03:21
id30209
id30209's picture
Last seen: 8 hours 42 min ago
Too bad they don't have 660nm version
WTB Titanium 4sevens 2xAA tube
Funtastic
Funtastic's picture
id30209 wrote:
Too bad they don’t have 660nm version
How much of a lumen reduction would 660nm be? I’m sure a darker red would reduce performance significantly.
id30209
id30209's picture
Funtastic wrote:
How much of a lumen reduction would 660nm be? I'm sure a darker red would reduce performance significantly.
Not much that you'd be worried or notice (some of us)
Unlike 620nm, 660nm has some more weight in regards eyes healing and not to mention not detectable by some animals like 620nm is (as per several hunters feedback I got)
thefreeman
thefreeman's picture
Last seen: 3 hours 32 min ago
According to Osram Color Calculator, 10 times less Shocked (I generated a 620nm and 660nm of 1W radiant power, got 216lm and 22.6lm)
id30209
id30209's picture
Ouch!
Funtastic
Funtastic's picture
Thanks for your input, I’ll just stick to 620-630nm if that’s the case.
Funtastic
Funtastic's picture
This LED looks exactly like this old post
I have asked Kaidomain if theirs is Epileds, but their response was no. I reckon they just don’t want to tell me because its appearance is 100% identical. The only difference is that this has a forward voltage of 3-3.7v, whereas the Epileds is spec’d at 2.2-2.4v
id30209
id30209's picture
 Gents let's not jump to conclusions. I have 620nm XP-E2 and 660nm XP-E2 and I must say that Osram and Cree Color Calculator is not correct in this case.
I do not see any output drop as stated by Freeman!
What can be explained by these numbers is 730nm which is so dim that it's hard to use.
620nm and 660nm doesn't have such a big difference.
thefreeman
Actually I made a mistake, Osram Color Cacl generates a pure color LED from a dominant wavelength not peak, dominant is the color that appears to the eyes, for a red led the peak will be at a higher wavelength because the eyes sensitivity decrease as wavelength increases, anyway I generated sources with 620 and 660n peak this time and got 262 and 64lm, so about 75% reduction.
thefreeman
id30209 wrote:
 Gents let’s not jump to conclusions. I have 620nm XP-E2 and 660nm XP-E2 and I must say that Osram and Cree Color Calculator is not correct in this case.
What can be explained by these numbers is 730nm which is so dim that it’s hard to use.
620nm and 660nm doesn’t have such a big difference.
No difference at all to the eyes ?
It’s annoying because Cree use luminous flux for red and radiant flux for photo red so we can’t directly compare the numbers.
id30209
id30209's picture
I will post photos of 620nm and 660nm next to each other next week when I get home, but believe me it's not that different as in your calculator for sure...
 EDIT: just to speed up the resolution and Funtastic doubts, check Sofirm C01R posts and tests ....
Sirius9
Sirius9's picture
Last seen: 15 hours 38 min ago
I think I see the dome overthere! Even from XP-E2 I removed dome for better thorw…
Osram red is not bad, I just use 3.2V driver for them, stilll no died leds.
Unheard
Unheard's picture
Last seen: 7 min 18 sec ago
Visibility is highly increased at 620 nm, but it’s not a “deep red”. Looks a little orange to me, so I would not be interested. It all depends on the use case.
Smile, you cannot kill them all.
