yes, will soon update to Anduril 2.0 with reverse charging
New color already with Anduril 2
Where is the new color?
So let’s say I have 2 TS21s with the proper C-C cable, and I plug each one into it. Which one charges which? Do they fight over it? Who wins?
Unno, use a phone to charge a flashlight, use a flashlight to charge a phone. My head hurts trying to figure it out.
Why not just take the temperature of the light, then use that figure for the calibration? Tweak the input a bit to compensate if desired. Instant read thermometers are cheap and plentiful.
Waiting for the light to settle at room temperature, then using the indirect ambient air temperature figure, assuming it’s accurate, and correlates to that of the light, seems to introduce a lot more time and potential error into the measurement than necessary.
The aim is to ensure that the light’s sensor reading corresponds to the temperature of the light itself, not the air, and that measurement can be taken at any point in time.
The space-time continuum will rupture. Do not attempt.
What would you say if you plugged a TS21 with 50% battery to a phone with 50% battery and after two hours they were both fully 100% charged.
Are they for sale yet?
Maybe it’s just me being all about budget, but I think 45.99 is a bit too much for this light.
Got mine for $29.42 to my door @ Amazon, after coupon code.
Trust me- this light is more than worth every penny.
You know what color is even more boring than black? Gray. Gray is the color of the office where I work. Gray carpet, gray chairs, gray cubicles, grey painted walls, grey doors. Every shade of grey you could ever want. Just like these boring Wurkkos flashlights.
Almost as bad as all the different versions of tacticool brown: flat dark earth, desert, camel, dirt, etc.
I like purple. And pink. Could leave ’em out and no “manly men” would steal a pink light. Too girly.
get it with a code
Now TS21 grey and sand color are available on Wurkkos.com, programmed Anduril 2.0 UI.
With discharging and charging function.
This time only 500pcs each color
Ok cool
Wonder why no red or purple?
Thanks timbo114.
Question: The choices are "Champagne" & "Metal Gray". Whether it's my eyes or my browser, to me they are "Light Gray" & "Dark Gray". Can I assume the Light Gray is considered Champagne?
And don’t forget, in general, if you’re doing thermal recalibration, have a thermometer set right next to the light, and leave both overnight to equilibrate. Then hit it fast so you don’t warm up the insides by either holding the light too long, or having the light on for too long. That itself could bump it up a few degrees in a very short time.
What do you use for a thermometer? I’ve been putting off configuring a bunch of lights because I don’t own one. :person_facepalming:
Clock/thermometer/hygrometer, like right next to the light.
Only have to be within a couple degrees. Most important thing is to let it cool down to room temp before trying again. Get it right the first time to avoid a long wait.
