Why not just take the temperature of the light, then use that figure for the calibration? Tweak the input a bit to compensate if desired. Instant read thermometers are cheap and plentiful.
Waiting for the light to settle at room temperature, then using the indirect ambient air temperature figure, assuming it’s accurate, and correlates to that of the light, seems to introduce a lot more time and potential error into the measurement than necessary.
The aim is to ensure that the light’s sensor reading corresponds to the temperature of the light itself, not the air, and that measurement can be taken at any point in time.
The space-time continuum will rupture. Do not attempt.
You know what color is even more boring than black? Gray. Gray is the color of the office where I work. Gray carpet, gray chairs, gray cubicles, grey painted walls, grey doors. Every shade of grey you could ever want. Just like these boring Wurkkos flashlights.
Almost as bad as all the different versions of tacticool brown: flat dark earth, desert, camel, dirt, etc.
Now TS21 grey and sand color are available on Wurkkos.com, programmed Anduril 2.0 UI.
With discharging and charging function.
This time only 500pcs each color
Question: The choices are "Champagne" & "Metal Gray". Whether it's my eyes or my browser, to me they are "Light Gray" & "Dark Gray". Can I assume the Light Gray is considered Champagne?
Only have to be within a couple degrees. Most important thing is to let it cool down to room temp before trying again. Get it right the first time to avoid a long wait.
Question: The choices are “Champagne” & “Metal Gray”. Whether it’s my eyes or my browser, to me they are “Light Gray” & “Dark Gray”. Can I assume the Light Gray is considered Champagne?
[/quote]
Far left in photo is champagne.
Center is gunmetal gray.
Right end is normal black.
Wurkkos and Sofirn are related companies.
I own a Sofirn light in champagne color … it is nicely done rich and distinguished light bronze tone.
