As Lux-Perpetua said there are a number of pros in the ability to use a 26650 battery. Do they outweigh the larger diameter? That’s of course up to the individual to decide. Better stability against tipping over was discussed at length and for me that’s an important thing. And something to consider is that Sofirn is going to be marketing the mini to people other than us. I suspect that the ability to use AAA batteries in an emergency will be a plus for many non-BLF members.
It’s too bad that 26650 batteries don’t have any more capacity than 21700’s, but that’s a subject for another conversation.
Exactly! in a pinch, a 3-AAA cell holder can run it. Having the LT1M able to use either 21700, 18650, 26650, or a 3-AAA holder even from a dollar store light in an emergency adds to its versatility. (Also being slightly wider at the base makes it more stable. :+1:
Since the head is wider than the base, a circular plate could be unscrewed from the top of the head and screwed on the bottom of the battery tube. Narrow for packing but a wide base when needed. Adds a part you can lose through.
I like this change, but feel like the stability issue is just inherent to the design being a lantern head on the end of a flashlight, instead of a lantern designed from the ground up as a lantern. Maybe in a future project we could see a design without a separate body at all, with a single cell in the center of the head surrounded by the emitters? I’m picturing something like a BLF-ified Fenix CL26R. I get that there are costs and manufacturing issues and all that associated with building a new design from scratch, and I’m definitely not complaining about the LT1M, but maybe that’s an idea someone much more qualified than I am could tinker with eventually.
If there is a poll then I’d argue for a short one. Say a week at most?
One of the things I’m concerned about is a never ending serious of comments on what changes should be made to the design. If you recall on the LT project the final design was held up for months because various people were arguing for things they just had to have (USB C springs to mind).
My preference is that we accept a design and go-forward with it, and if people are happy with it then they’ll buy it.
That’s certainly up to Sofirn but I think that would needlessly complicate things for them as well as their supply chain. But that’s up to them of course.
Yes, make a poll. I’d vote for a 21700 body. I have a number of aa lights that I have bought for emergency purposes, but I just don’t use them after all. To be honest I always have extra 18650 cells and a suoer compact charger with me wherever I go, so the idea of being able to find aa batteries anywhere is a moot point. I’ll gladly buy some 21700 cells to go with this light, and possibly a 21700 pocket flashlight too.
Even though i have a few 26650 cells too, i wouldnt neccesarily want my mini lantern to use those. Too heavy and large in diameter.
I think the idea of the base that screws off of the head to be able to reinstall on the base is a GREAT idea. I also thought of 3 thin legs that fold down from the handle to form a tripod of sorts.
One of the things that I really like about the IF25 is the symmetry of the design, The wide, flared tailcap balances the wide head on the narrower tube.
Making the battery tube wider does not enhance a light’s tail standing stability. Making the tailcap wider is what enhances the tail standing stability. Just flare the tailcap out wider and make it a bit thicker so you can install a magnet strong enough to really hold the light against ferrous surfaces so it doesn’t slide down, or fall off.
Sounds very sensible. Having that 3xAAA battery carrier option is a terrific fall-back, so you can have at least some light if somehow your primary lithium cell became damaged or lost. AAA is so ubiquitous! Will a good 21700 to 18650 adapter tube be available for purchase with it? It’s a real pain having to track down ones from other companies and most are junk. Fireflies came up with a good one with a removable contact button for protected cell support.
I expected the tube to be a 18650 so that it’s easy to carry. More like the sofirn Pro. The LT1 uses 18650 batteries. I thought the mini would use the same battery type. I find it easier to maintain 18650 batteries. Plus it’s easier to gift. The idea of a mini is that its smaller. An adapter is wasting space.
For me the width of the prototype looks OK. What surprises me is more the length. It looks very long and having a smaller diameter with cells smaller than 26650 should make it more unstable. An alternative short tube for a 26350 cell would make it looks more like the little brother of LT1.
