Very nice Pairing…
thanks for the great photos!
Hello, I show you a small but effective modification, a trustfire t70 that had 1860lm and 220,000CD from stock. Now after stacking a resistor R091 on top of the stock R020 it is giving 2100lm and 250,000CD. The measurements in the tail with the current clamp changed from the 3.7A of stock to the current 4.8A; I don’t know how many will get to the led, maybe half? also I also gave the MCPCB some sandpaper and put new thermal paste
the color and the projection of the led is very good, I think the tint is warmer than what I have seen in other reviews
since I show the olight m3xs-ut javelot I tell you the modification that I made, very similar to that of the t70. I stacked two R500 + R100 resistors on top of the stock R030, I measured on the tail with the stock 2.04A clamp meter, and after the modification I measure 2.82A. This javelot is one of the latest, it has an xpl-hi, I think V3 because before the modification it gave me almost 1400lm and now almost 1800lm
I would be careful with this Olight.
It’s a very popular model locally and I often get it for a repair, models with older driver (2 board version) hardly ever had a driver issue, in 90% of cases it was an issue with the LED (easy fix).
Opposite to this, I had about 5 light with this new driver sent for a repair and it was alway an driver issue + I only managed to repair one of them.
Thanks I will take it into account although I can do little, the day it explodes I will put another driver and an sft40. by the way do you know what version of xplhi it has?
The modded pair are complete! D1s (sft40, 7.5a driver) D1 (CULPM1, 7.5a driver) . Also attached is the before and after of the D1s beam, I modified a 4040 centering ring and the beam is nearly perfect now!
sorry for the huge pictures, did this on the phone..
Good work on the focusing. The result looks good. If you take a bit over exposed picture you can see even better that your new beam is very parallel lines on the edge of the main hot spot.
Great work on the beam Artie! Knew you could do it
What a big improvement in the beam, how did you get it? I have some beams like this and I don’t know whether to sand the centering ring from above or below
I got around to trying the SST-20 4000K 95 CRI FD2 bin emitters I had laying around. Wow! Great tint. Not green even at low power levels. Much better than any other SST-20s I’d tried.
I had 8 of them, and over the last week installed all of them into the following lights:
- Zebralight SC52w triple
- Sofirn SC21 - big improvement in tint, color temp and CRI over the stock 90 CRI 5000K LH351D.
- Jetbeam TCR-01 - this light is using the 2020 RRT-01 driver. The SST-20 looks much better than the sliced Dogfarts LH351 that I previously had in this light.
- Lumintop Tool AA Ti
- Eagletac D25a Ti early version (no brass pill) - high output since this light also had a driver swap to a FET driver. Head gets quite hot.
- Eagletac D25a Ti late version (brass pill) - dimmer, but still looks good.
In every case, the new emitter was a noticeable improvement over what I had in the light. Big improvement over the XPL HI and sliced Dogfarts those lights used to sport. I’m quite happy with these emitters. So happy that I just ordered 15 more.
Where from?
Kaidomain
Stock its not HI version, just regular CW XPL dedomed but they have a good dedoming recipe so the tint shift is not huge.
thank you! And thank you for the advice I didn't know that. I know very little woth the photography aspect of things lol
thanks JaredM! :))
so I shaped the inside bottom (the side of the centering ring that touches the mcpcb) with a dremel so that I widened the centering ring to fit around the sft40. The problem was that every 4040 centering ring I had wouldn't fit around the very slightly larger sft40. The 5050 ones fit but we're too large. So I slightly widened the bottom of the 4040 CR, into like a cone shape so it became pressure fit into the emitter corners when I put the bezel on. Worked very well and automatically centered itself because of the pressure fit / cone shape
Sometimes I have to sand the top of the centering ring so it doesn't protrude past the reflector opening, as that causes wierd beam effects too. The need to be flush with the opening of the reflector. Not above or below, usually.
my olight did come with a stock xpl-hi
I thought the D25a was not moddable, since no bezel. Can the pill be popped out?
There are actually 2 versions of the Eagletac D25a Ti, one with pill and one without. Both can be modded.
The early version D25a Ti has a bezel and no pill and is easier to mod
- The battery tube screws into the head.
- It is entirely made of Titanium.
- The bezel is not glued and unscrews so emitter swaps are easy. There is room for a standard Noctigon star with the edges filed down slightly.
- The one downside is the driver wires are thin and have PVC insulation which tends to melt when soldering the leads to the star.
- The aluminum version D25a also followed this same construction, except the head was aluminum and the bezel was blackened steel.
The revised version of the D25a Ti has a brass pill
- The head (with glued in pill) screws into the battery tube.
- This revision was done to eliminate the gritty feeling users complained of when swapping mode groups in the first version (which required slightly unscrewing the head). Instead of Ti-on-Ti it is now Brass-on-Ti.
- The revised version contains a brass pill. The top half of the pill’s threads screw into the titanium head. The bottom half screws into the battery tube when changing batteries. Both sides have o-rings to provide waterproofing.
- The head is secured to the brass pill with a small amount of red threadlocker. I believe this was done to eliminate the chance the user might accidentally unscrew the head when they wanted to change the battery.
- It is possible to mod the revised version D25a by forcefully unscrewing the head from the pill to break the threadlocker.
- To break the threadlocker I used 3M safety walk tape on the head coupled with pliers on the brass threads of the pill. The pliers left a few minor scratches in the pill, but this isn’t an issue since it does not affect operation and they are not visible when the battery tube is screwed on.
- Once the threadlocker is broken, changing emitters is easy. Just unscrew the head from the pill. The star sits exposed on the top of the pill.
- The light comes with a thin aluminum star. Unfortunately, it is not practical to use a thicker copper star as that would cause the head to not screw in all the way. And if it doesn’t screw in all the way it won’t cover its o-ring. Without the o-ring covered, the head won’t tighten onto the pill. Without that, when you change the battery the head will come apart rather than the battery tube coming off. I recommend using the stock star and reflowing your choice of XPG footprint emitter onto it.
- It is not necessary to replace the threadlocker after modding. Just screw the head really tightly onto the pill and don’t tighten the battery tube as tightly.
- The revised D25a has the same issue of PVC insulated wires. Mine were good for probably 5 or 6 emitter swaps before I had issues and replaced them with Silicone wires. The driver is press-fit and can be levered out with the edge of a knife.
- I believe these revisions were also done to the D25c. And all current model similar Eagletacs such as the D3A and D3C also use the same design.
