That is the 1st thing I checked … nuttin.
I’ll charge it again for gits and shiggles.
I just tested a random car charger with LCD voltage readout and it’s working. It seems redundant since the device itself has USB but it’s the quickest thing I could find.
Curious what devices are you trying to plug in?
For the penlight Check that the the charge light comes on. One of mine has a weird port and is super fussy.
These were my first rovyvon lights and I’m becoming less impressed with the overall quality. Was looking at a copper A9 because it’s on sale but not feeling like its worth it at this point
Don’t waste your money on that A9.
Disappointed in mine.
Just tested mine with a low draw and old dashCam and also an 8 year old O2 Cool 10” 12v and also rechargeable fan. Both worked perfectly. Sorry to hear you’re having a problem with yours.
Oh well I bought both the A9 and the A9 Pro in copper —that’s the beauty part about Amazon — Return Policy
Thank you forum members "koss" and "Richie086" for your results from testing the "12V cigarette lighter socket" on the AFTIME Power Station.
The devices I have (~1A max load) that do not initially work and cause the AFTIME Power Station to display the "ERR" DC Output message, but that do start to work after I reboot the AFTIME Power Station with the device still connected are two different Anker USB car chargers two different OPUS battery chargers and my Garmin Car GPS.
The devices I have that will not work at all with the "12V cigarette lighter socket" on the AFTIME Power Station(even after a reboot while connected) are a Chain Saw Sharpener (a miniature Die Grinder) and a Sony CD Boom Box.
The only device I really want to work is the Chain Saw Sharpener. The other devices were used for testing to try and figure out why the Chain Saw Sharpener (~5A max load at startup) would not work on this particular Power Station when it works fine on other similar size Power Stations.
Maybe the "12V cigarette lighter socket" on my particular AFTIME cannot support the 10A advertised load specification, but what surprised me the most was the flashing "ERR" failure message when I plug in a device if the AFTIME is "ON", but I do not get the failure or failure message if I plug in while the AFTIME is "OFF" and then turn it "ON", and I do not get the failure after a reboot when the failure message is displayed. The failure occurs even when the devices I am plugging in do not have their normal load applied (the USB car chargers are not connected to anything and the OPUS and Garmin vehicle power cords are not connected to their devices).
So you have something like this? Amazon.com
Do you have a cord with a barrel plug you can sacrifice and either use the alligator clips or jerry rig it to the 12 DC out plug?
Kind of sounds like something is wrong with your unit, you can see if they’ll swap if not buy another the the higher current price and return the bad one one in its place.
There’s a coupon for $150 total right now JLXGOSEF Amazon.com
Yes that's exactly the sharpener I use, but I don't have a barrel plug to test the other DC outlet jack on the AFTIME Power Station.
I have sent a message to AFTIME through Amazon about this issue and will see what happens. Was just curious if anyone else had this problem. Other than that the power station works fine.
$3.40 with code 9EIQUKQP
rechargeable stocking-stuffer.
Hmm...
It says it has a CREE emitter, but not which one.
Also, no lumen estimates, and no reviews.
Still, might be good.
Thanks! Ever since the og inova x5, I’m a sucker for a smooth stick of light. I’ll post what it’s like when it arrives.
2-In-1 Type-C Audio Cable, 2in1 USB Type-C To 3.5mm Jack AUX Audio Splitter Converter Adapter + Type C Female Splitter Adapter Connector Cable $3 with code on page.
Cheap solder station. vipon Coupon and amazon coupon. 16$
《Ddtohan #926LED V2 80W Soldering Iron Station Kit, 392℉-896℉ Adjustable Temperature, Temperature Lock, LED Digital Display, 10 Minute Sleep Function, Auto Cool Down, (C/F) Switch》
I’d like to say that this light arrived in 2 days instead of the quoted 1-2 months. I’m shocked. For the light, I can indeed confirm that it is exactly one metric flashlight.
Cheap solder station. vipon Coupon and amazon coupon. 16$ 《Ddtohan #926LED V2 80W Soldering Iron Station Kit, 392℉-896℉ Adjustable Temperature, Temperature Lock, LED Digital Display, 10 Minute Sleep Function, Auto Cool Down, (C/F) Switch》 Ddtohan #926LED V2 80W Soldering Iron Station Kit, 392℉-896℉ Adjustable Temperature, Temperature Lock, LED Digital Display, 10 Minute Sleep Function, Auto Cool Down, (C/F) Switch'
Wow, $16 is a heck of a deal. Just ordered one, THANK YOU !
Lightning deal.
$29.24 for a 10 Port USB 3.0 Hub (with 10% off box clicked.)
https://www.amazon.com/dp/B086W45YHX
I've been waiting for the price to drop on this for a while now, so I just snagged one.
Insanely low price for something like this. Originally $26.99. Just $3. And it’s free shipping. It’s fulfilled by the seller, not Amazon too. Sometimes when you get a good deal like that, the original price counts towards the shipping, so you can add on a few small items and still enjoy free shipping. Not so with this. So I placed an order, totaled to $3.20 with tax. I don’t know how they make any money on it!
It’ll be interesting to see how is the compatibility. Some of these USB-C to 3.5mm jacks don’t work, or sound crappy. I have a Baseus one that’s quite good. Also the Apple one and that works fine on my Google Pixel.
$17.21 was my deal and a deal it is! Thanks for the heads-up!
$16.95 for me. Looks like a deal.
