Looking at new work headlamp and have some questions
Right now I use REDLITHIUM USB Hard Hat Headlamp | Milwaukee Tool
And I LOVE IT. I love the color/cri the beam pattern etc. the only 3 things I want to change is
:the runtime for the 300 lumen setting to last 8.5-10 hours
Dual switch spot land flood
More spot settings
Now I was looking at the Fenix HM65R And Fenix HP25R V2.0. Both have the longer runtime I want. I was looking at a 21700 battery for the longer one time. But I’m confused as it seems the HM65 has longer run times than the HP25 all things being equal. Even though the in theory has a larger battery?
But when I look at the specs see it does appear that the 25 has a higher candela per lumens setting.
Does this mean it’s not quite as floody or that it has a better quality light? I also don’t necessarily need a true high CRI light but I would like it to edge closer to that. So I’m just confused why one with a larger battery has what seems like lower run times.
I also really like that the 25 battery in the back. To distribute the weight.
I’ve also looked at the stream light ENDURO® PRO USB HEADLAMP
Flashlight Requirements
Purpose -This will only live in my hard hat. No other use. I work as a plumber with 10 hour days usually.
Size -just needs to fit comfortably on my hard hat. I think I’d prefer a light that balances the light and battery weight to the front and back. I prioritize Battery life, performance, and durability over weight compared to most people probably. But I’ll happily pay extra for good lights that are lighter weight than their competitors.
Battery Type & Quantity - 18650 or 21700, I don’t mind non standard battery’s if I get longer life or better form factor.
Price Range - price isn’t really a concern. I want the best light for my use. $100-150 no problem $200 I’ll want a good reason
Type - Headlamp, not really interested in the L-shape lights. I’m not going to detach it, I’ve got other lights for handheld use.
Lumens - the headlamp I use now has has several flood settings and a spotlight. I mainly use the 150 lumen setting but would like to be able to use the 300-400 setting more if it didn’t drain the battery
Switch Type - I want buttons that are easy to press while wearing gloves. Dual switch sounds kinda nice
