Luminus SFT40 test
Sounds too good to be true, but I bought two. Did you get them as well?
I ordered 2 bare and 1 mounted on a 20 mm 2 mm copper MCPCB.
They say 3000 lumens. :open_mouth:
JaredM, that led looks Great! i think, how does the round phosphor work? it says 8000ma max output? thats great! and 5000k?
Are these only good for aspherics?
Size comparison with the SFT40 and a CSLPM1
Should be pretty interesting if it meets its specifications.
I ordered two on 5000k
My order got canceled. Listing has changed to a new product. :cry:
EDIT: There is something weird about the mobile version of the site. I’ll try clearing cache and what not and see if that changes anything, but the desktop version of the site still has the emitter listed. Ordered again, this time w/o a mcpcb. Fingers crossed!
I still see it here: https://www.aliexpress.com/item/1005003246180028.html?spm=a2g0s.12269583.0.0.1922f481t1weW1
My order not cancelled... yet
Previous post updated. Mobile site issue
djozz, I just noticed that you have yet to add this test to your directory thread linked in your signature. Thanks again for all these years of work, BLF wouldn’t be the same without you! :beer:
SFT40 is 5050
Sadly, out of stock.
I’ll be using TA FET+1+15 for my GT->90, which works because I don’t need 9A regulated. Suppose you could stack 7135s…
Thanks :beer:
And added.
Djozz I also love you man :beer: You are BLF…
Indeed. :beer:
+1 !!
:blush:
Does Anybody know what is going on with the availability of this led? it seems to be rather disappearing then getting common.
Can it be such a huge demand on the market so everybody has sold out?
It was there, now it's gone. Dunno why but seen this before with new LED's. First batch goes quick, no 2nd batch for a while.
I only knew of one place to buy them - Convoy. Don't think KD got them at all, and Cutter doesn't carry the Luminus line of LED's, and Hank just doesn't list many LED's he will sell to us.
This is the most interesting emitter lately so I don’t doubt that Hank or Simon will stock it soon.
I seen from the thread that plenty of guys have those Black Dots Of Death or BDOD… That will led to emitter destruction, and not to mention you can’t sell that kind of flashlight to anyone(if you are seller).
So what happens here? Hot flux particles mixed with some solder particles explode into silicone protective layer of led emitter(situation when you flux contact pads, and then you do final touch up with rosin core flux solder wire). Certain flux(fluid, pen, paste) “explode” more or less and permanently bonds with silicone and even worse if it penetrates enough into phosphor… GAME OVER.
I got one flux pen from premium brand and that is the worse one I have. It literary explodes each time i touch it with solder wire. I guess this happens when incompatible flux like rosin core flux in solder wire and lets say generic liquid flux meet each other on solder tab. So proper flux combination needs to be used or to not use flux at all(i always prefer flux).
The key is in protecting emitter from hot FLUX splash. I use some kind of small lens over emitter for that purpose but you can be creative and think your own way of protecting emitter. Some kind of protective barrier. While isopropyl alcohol can help if it did not penetrated deep enough it is better to not let anything happen to emitter.
When you do whole process by yourself (reflowing and soldering) you have full control, all the time in a world and you can only blame yourself for fail. When factory makes light which workers are timed to make certain minimum order quantity per working day you can really expect problems.
Woow, thanks for explanation. Anyway I want them :innocent:
Badly :smiling_imp:
